Viejo 27/03/17, 20:21:31
mesk-one mesk-one is offline
Script SAP para exportar datos a Excel
Viejo 30/03/17, 13:30:50
Este es el Script que tengo, solo necesito que me evalue el valor de un numero que muestra SAP para si es 0 no haga la transaccion, pero no se como referirme a ese valor. Dondoe pone "zzzzzz" es donde me falta la linea de codigo que no consigo sacar
If Not IsObject(application) Then
Set SapGuiAuto = GetObject("SAPGUI")
Set application = SapGuiAuto.GetScriptingEngine
End If
If Not IsObject(connection) Then
Set connection = application.Children(0)
End If
If Not IsObject(session) Then
Set session = connection.Children(0)
End If
If IsObject(WScript) Then
WScript.ConnectObject session, "on"
WScript.ConnectObject application, "on"
End If
Set objShell = WScript.CreateObject("WScript.Shell")
Set objVariableEntorno = objShell.Environment("Process")
Set xclapp = GetObject(, "Excel.Application")
Set hoja = xclapp.Sheets("Macro")
fechaInicio = hoja.Cells(1, 5).Value
fechaFin = hoja.Cells(2, 5).Value
CCA350S19 = hoja.Cells(2, 2).Value
session.findById("wnd[0]").resizeWorkingPane 113,27,false
session.findById("wnd[0]/tbar[0]/okcd").text = "ZPP_HORAS_ESTANDAR_N"
session.findById("wnd[0]/tbar[0]/btn[0]").press
session.findById("wnd[0]/usr/ctxtP_CECO").text = CCA350S19
session.findById("wnd[0]/usr/txtP_INI").text = fechaInicio
session.findById("wnd[0]/usr/txtP_FIN").text = fechaFin
session.findById("wnd[0]/usr/txtP_FIN").setFocus
session.findById("wnd[0]/usr/txtP_FIN").caretPosition = 10
session.findById("wnd[0]/tbar[1]/btn[8]").press
session.findById("wnd[0]/usr/tblZPPR_INC_SAPI_0026_V2GBP_SUMAS").getAbsoluteRow(0).selected = true
session.findById("wnd[0]/usr/tblZPPR_INC_SAPI_0026_V2GBP_SUMAS/txtR_DATOS_GBP-GBP[0,0]").setFocus
session.findById("wnd[0]/usr/tblZPPR_INC_SAPI_0026_V2GBP_SUMAS/txtR_DATOS_GBP-GBP[0,0]").caretPosition = 0
session.findById("wnd[0]/usr/btnVER_DET").press
If( zzzzzzzz ) Then
session.findById("wnd[0]/usr/subSUB_DETALLE:ZPPR_INC_SAPI_0026_V2:9000/btnBOT_HINC").press
session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").setCurrentCell -1,"INCU"
session.findById("wnd[0]/usr/cntlGRID1/shellcont/shell/shellcont[1]/shell").selectColumn "INCU"
session.findById("wnd[0]/tbar[1]/btn[30]").press
session.findById("wnd[0]/tbar[1]/btn[45]").press
session.findById("wnd[1]/usr/sub:SAPLSPO5:0101/radSPOPLI-SELFLAG[1,0]").select
session.findById("wnd[1]/usr/sub:SAPLSPO5:0101/radSPOPLI-SELFLAG[1,0]").setFocus
session.findById("wnd[1]/tbar[0]/btn[0]").press
session.findById("wnd[1]/usr/ctxtRLGRAP-FILENAME").text = "C:\Users\NG612C7\Documents\SAP\SAP GUI\IncurridasA350S19.xls"
session.findById("wnd[1]/usr/ctxtRLGRAP-FILENAME").caretPosition = 60
session.findById("wnd[0]/tbar[0]/btn[3]").press
End If
Viejo 19/04/17, 13:38:46
cardama cardama is offline
Localización: Luxembourg
Saludos mesk-one.
Una respuesta exacta no te puedo dar, pero si una idea de como podrías controlarlo.
La idea que se me ocurre es que justo cuando vas a lanzar la consulta que te muestra esa ventana con el mensaje de que no hay ficheros, actives la grabación del script y pares justo la grabación después de pulsar el botón de aceptar ese mensaje.
En ese script posiblemente te aparezca algo similar a lo siguiente:
Session.findById("wnd[1]/tbar[1].bth[8]").press
El tema seria probar si puedes controlarlo de la forma:
if session.findById("wnd[1]").visible then ....
no se si es correcto hacerlo de esta forma, pero es una idea.
Tengo muchos años de experiencia en programación en vba pero muy poca en desarrollar script para controlar SAP.
Espero que te sirva la idea y ya indicaras si era posible.
Un saludo.
Viejo 21/04/17, 09:51:52
Es una buena idea, he intenado ponerlo así, pero no he conseguido que funciones, quizas las sintaxis del condicional no sea la correcta.
If (session.findById("wnd[1]").visible) Then
End If
Muchas gracias
Este es el codigo al apretar el botón:
session.findById("wnd[0]").resizeWorkingPane 96,28,false
session.findById("wnd[0]/usr/subSUB_DETALLE:ZPPR_INC_SAPI_0026_V2:9000/btnBOT_HSUB").press
Viejo 06/12/17, 10:59:29
ricky_uy ricky_uy is offline
Podes poner codigo vbs
Podrias poner codigo VBS dentro del script, en donde estas tomando la variable del excel,
inclusive podrias porner un "imput box" que te pregunte despliege el valor y tu decidas como continuar
la sentencia del if en vba es la siguiente:
if Variable >= 0 Then
else msgbox ("Variable es igual o menor que cero")
end if
(no necesitas cerrar cada sentencia con ";")
espero te sirva
Husos Horarios son GMT. La hora en este momento es 13:36:33.
