Viejo 07/07/14, 00:11:19
roberto.mejia roberto.mejia is offline
Problema con REUSE_ALV_COMMENTARY_WRITE
Buenas noches:
Tengo el problema con REUSE_ALV_COMMENTARY_WRITE no muestra la cabecera nose cual es el problema.
REPORT ZALV02.
INITIALIZATION.
TABLES : spfli.
DATA: BEGIN OF ti_tabla OCCURS 0, " crea una variable estructura
carrid LIKE spfli-carrid,
cityfrom LIKE spfli-cityfrom,
distance LIKE spfli-distance,
END OF ti_tabla.
type-POOLS : slis.
DATA: wa_layout TYPE slis_layout_alv.
DATA: ti_fieldcat TYPE slis_t_fieldcat_alv WITH HEADER LINE. "tabla, con un registro por cada campo
DATA: it_listheader TYPE slis_t_listheader,
wa_listheader TYPE slis_listheader.
START-OF-SELECTION.
PERFORM carga.
PERFORM layout.
PERFORM armadosalida.
end-of-SELECTION.
PERFORM build_alv_header.
PERFORM salida.
*& Form CARGA
* text
* --> p1 text
* <-- p2 text
FORM CARGA .
SELECT * FROM spfli INTO CORRESPONDING FIELDS OF TABLE ti_tabla.
ENDFORM. " CARGA
*& Form ARMADOSALIDA
* text
* --> p1 text
* <-- p2 text
FORM ARMADOSALIDA .
CLEAR ti_fieldcat.
ti_fieldcat-fieldname = 'CARRID'.
ti_fieldcat-tabname = 'TI_TABLA'.
ti_fieldcat-seltext_m = 'CARRID'.
ti_FIELDCAT-EMPHASIZE = 'C710'.
ti_fieldcat-col_pos = 2.
APPEND ti_fieldcat.
CLEAR ti_fieldcat.
ti_fieldcat-fieldname = 'CITYFROM'.
ti_fieldcat-seltext_s = 'CIUDAD'. " descripcion corta
ti_fieldcat-seltext_l = 'CIUDAD GRANDE'. " descripcion larga
ti_fieldcat-seltext_m = 'CIUDAD MED'. " descripcion media
ti_fieldcat-outputlen = 8.
ti_fieldcat-col_pos = 3.
APPEND ti_fieldcat.
CLEAR ti_fieldcat.
ti_fieldcat-fieldname = 'DISTANCE'. " NOMBRE DEL CAMPO DE LA TI
ti_fieldcat-tabname = 'TI_TABLA'. " NOMBRE DE LA TABLA INTERNA
ti_fieldcat-seltext_l = 'DISTANCIAA'. " NOMBRE A MOSTRAR EN EL MENU
ti_fieldcat-outputlen = 20. " longitud del campo
ti_fieldcat-col_pos = 1. " posicion en que columna va estar
APPEND ti_fieldcat.
ENDFORM. " ARMADOSALIDA
*& Form SALIDA
* text
* --> p1 text
* <-- p2 text
FORM SALIDA .
CALL FUNCTION 'REUSE_ALV_GRID_DISPLAY'
EXPORTING
* I_INTERFACE_CHECK = ' '
* I_BYPASSING_BUFFER = ' '
* I_BUFFER_ACTIVE = ' '
I_CALLBACK_PROGRAM = sy-repid
* I_CALLBACK_PF_STATUS_SET = ' '
* I_CALLBACK_USER_COMMAND = ' '
I_CALLBACK_TOP_OF_PAGE = 'top_of_page'
* I_CALLBACK_HTML_TOP_OF_PAGE = ' '
* I_CALLBACK_HTML_END_OF_LIST = ' '
* I_STRUCTURE_NAME =
* I_BACKGROUND_ID = 'IMAGEN_PRUBA' " nombre de la imagen
* I_GRID_TITLE =
* I_GRID_SETTINGS =
IS_LAYOUT = wa_layout
IT_FIELDCAT = ti_fieldcat[] " nombre de tabla alv
* IT_EXCLUDING =
* IT_SPECIAL_GROUPS =
* IT_SORT =
* IT_FILTER =
* IS_SEL_HIDE =
* I_DEFAULT = 'X'
* I_SAVE = ' '
* IS_VARIANT =
* IT_EVENTS =
* IT_EVENT_EXIT =
* IS_PRINT =
* IS_REPREP_ID =
* I_SCREEN_START_COLUMN = 0
* I_SCREEN_START_LINE = 0
* I_SCREEN_END_COLUMN = 0
* I_SCREEN_END_LINE = 0
* I_HTML_HEIGHT_TOP = 0
* I_HTML_HEIGHT_END = 0
* IT_ALV_GRAPHICS =
* IT_HYPERLINK =
* IT_ADD_FIELDCAT =
* IT_EXCEPT_QINFO =
* IR_SALV_FULLSCREEN_ADAPTER =
* IMPORTING
* E_EXIT_CAUSED_BY_CALLER =
* ES_EXIT_CAUSED_BY_USER =
TABLES
T_OUTTAB = ti_tabla " nombre de la taba interna
EXCEPTIONS
PROGRAM_ERROR = 1
OTHERS = 2
IF SY-SUBRC <> 0.
* MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO
* WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4.
ENDIF.
ENDFORM. " SALIDA
*& Form LAYOUT
* text
* --> p1 text
* <-- p2 text
FORM LAYOUT .
wa_layout-zebra = 'X'.
wa_layout-Lights_fieldname = '2'.
wa_layout-Window_titlebar = 'Reporte ALV PRUEBA'.
ENDFORM. " LAYOUT
*& Form BUILD_ALV_HEADER
* text
* --> p1 text
* <-- p2 text
FORM build_alv_header .
* Type H is used to display headers i.e. big font
wa_listheader-typ = 'H'.
wa_listheader-info ='Flight Details'.
APPEND wa_listheader TO it_listheader.
CLEAR wa_listheader.
* Type S is used to display key and value pairs
wa_listheader-typ = 'S'.
wa_listheader-key = 'Date :' .
CONCATENATE sy-datum+6(2)
sy-datum+4(2)
sy-datum(4)
INTO wa_listheader-info
SEPARATED BY '/'.
* Type A is used to display italic font
wa_listheader-typ = 'A'.
wa_listheader-info ='SAP ALV Report'.
ENDFORM. " BUILD_ALV_HEADER
*& Form top_of_page
FORM top_of_page.
CALL FUNCTION 'REUSE_ALV_COMMENTARY_WRITE'
EXPORTING
it_list_commentary = it_listheader.
ENDFORM. "top_of_page
Viejo 07/07/14, 13:11:43
omegaotaku omegaotaku is offline
Buenos dias, dentro del PERFORM build_alv_header. al finalizar tenes que hacer un PERFORM top_of_page.
Viejo 07/07/14, 13:28:35
Ahora me doy cuenta, en lo que vos copiaste, que no esta el evento, por eso no te anda.
Te lo paso completo:
REPORT ZALV02.
INITIALIZATION.
TABLES : spfli.
END OF ti_tabla.
type-POOLS : slis.
wa_listheader TYPE slis_listheader,
gt_events TYPE slis_t_event.
CONSTANTS: g_top_of_page TYPE slis_formname VALUE 'TOP_OF_PAGE'.
START-OF-SELECTION.
PERFORM carga.
PERFORM layout.
end-of-SELECTION.
PERFORM eventtab_build CHANGING gt_events[].
PERFORM salida.
*& Form CARGA
* text
* --> p1 text
* <-- p2 text
FORM CARGA .
ENDFORM. " CARGA
* text
* --> p1 text
* <-- p2 text
FORM ARMADOSALIDA .
CLEAR ti_fieldcat.
APPEND ti_fieldcat.
CLEAR ti_fieldcat.
APPEND ti_fieldcat.
CLEAR ti_fieldcat.
APPEND ti_fieldcat.
*& Form SALIDA
* text
* --> p1 text
* <-- p2 text
FORM SALIDA .
EXPORTING
* I_GRID_TITLE =
* I_GRID_SETTINGS =
* IT_EXCLUDING =
* IT_SORT =
* IT_FILTER =
* IS_SEL_HIDE =
* I_DEFAULT = 'X'
* I_SAVE = ' '
* IS_VARIANT =
it_events = gt_events[]
* IT_EVENT_EXIT =
* IS_PRINT =
* IS_REPREP_ID =
* IT_ALV_GRAPHICS =
* IT_HYPERLINK =
* IT_ADD_FIELDCAT =
* IT_EXCEPT_QINFO =
* IMPORTING
TABLES
EXCEPTIONS
PROGRAM_ERROR = 1
OTHERS = 2
IF SY-SUBRC <> 0.
ENDIF.
ENDFORM. " SALIDA
*& Form LAYOUT
* text
* --> p1 text
* <-- p2 text
FORM LAYOUT .
ENDFORM. " LAYOUT
* text
* --> p1 text
* <-- p2 text
wa_listheader-key = ''.
sy-datum+4(2)
sy-datum(4)
SEPARATED BY '/'.
*& Form top_of_page
FORM top_of_page.
EXPORTING
FORM eventtab_build USING rt_events TYPE slis_t_event.
*"Registration of events to happen during list display
DATA: ls_event TYPE slis_alv_event.
CALL FUNCTION 'REUSE_ALV_EVENTS_GET'
EXPORTING
i_list_type = 0
IMPORTING
et_events = rt_events.
READ TABLE rt_events WITH KEY name = slis_ev_top_of_page INTO ls_event.
IF sy-subrc = 0.
MOVE g_top_of_page TO ls_event-FORM.
APPEND ls_event TO rt_events.
ENDIF.
ENDFORM. "EVENTTAB_BUILD
Viejo 27/07/14, 19:57:26
Ya me salió pero no entiendo eso del evento que pusiste puedes pasarme algún problema sencillo y/o material sobre ese tema para poder entenderlo
Viejo 29/07/14, 13:55:19
En esta tabla ( IT_EVENTS) se especificarán ante qué eventos la respuesta será de nuestro programa y no
implementado por la función. Para obtener los eventos que pueden ser codificados por el
programa, es decir, aquellos para los cuales la función nos devuelve el control, basta con
ejecutar la función REUSE_ALV_EVENTS_GET, importando una tabla interna en el
parámetro ET_EVENTS, definida como SLIS_ALV_EVENT, estructura que viene definida en
el type-pool SLIS incluido al inicio del programa.
Cuando se llame a la función que va a mostrar el report se le pasará esta tabla interna con el
nombre de los eventos y el nombre de la subrutina donde irán implementados dichos
eventos.
De todos los eventos que podemos implementar en nuestro programa, los más
utilizados o los más comunes son dos: ‘Top-of-page’ y ‘At user command’.
Husos Horarios son GMT. La hora en este momento es 23:23:00.
