Viejo 05/06/13, 16:37:47
minerva0112 minerva0112 is offline
Question Formulario en smartforms a pdf
Hola estoy haciendo lo siguiente:
* Funcion para llamar el formulario
CALL FUNCTION 'SSF_FUNCTION_MODULE_NAME'
EXPORTING
formname = 'ZHRO_LSTD_NTFCCNS'(031)
IMPORTING
fm_name = g_funcion
EXCEPTIONS
no_form = 1
no_function_module = 2
OTHERS = 3.
g_control_parameters-no_dialog = 'X'.
g_output_options-tddest = 'PDF '.
g_output_options-tdnewid = 'X'.
g_output_options-tdimmed = 'X'.
CALL FUNCTION g_funcion
EXPORTING
indicador = g_indicador
texto = g_texto
output_options = g_output_options
control_parameters = g_control_parameters
user_settings = ' '
TABLES
it_data = it_data
EXCEPTIONS
formatting_error = 1
internal_error = 2
send_error = 3
user_canceled = 4
OTHERS = 5.
* Busqueda de Orden de Spool
SELECT SINGLE rqowner MAX( rqident ) AS rqident INTO (g_uname, g_n_spool)
FROM tsp01
GROUP BY rqowner
HAVING rqowner = sy-uname.
SELECT SINGLE rqclient rqo1name INTO (g_client, g_name)
FROM tsp01
WHERE rqident = g_n_spool.
CALL FUNCTION 'RSTS_GET_ATTRIBUTES'
EXPORTING
authority = 'SP01'
client = g_client
name = g_name
part = 1
IMPORTING
type = g_tipo
objtype = g_tipo_obejto
EXCEPTIONS
fb_error = 1
fb_rsts_other = 2
no_object = 3
no_permission = 4.
IF g_tipo_obejto(3) = 'OTF'.
* Convertir el spool en pdf, desde un fomulario
CALL FUNCTION 'CONVERT_OTFSPOOLJOB_2_PDF'
EXPORTING
src_spoolid = g_n_spool
no_dialog = ' '
IMPORTING
pdf_bytecount = g_numbytes_pdf
pdf_spoolid = g_pdf_spool_id
btc_jobname = g_job_name
btc_jobcount = g_job_id
TABLES
pdf = it_pdf
EXCEPTIONS
err_no_otf_spooljob = 1
err_no_spooljob = 2
err_no_permission = 3
err_conv_not_possible = 4
err_bad_dstdevice = 5
user_cancelled = 6
err_spoolerror = 7
err_temseerror = 8
err_btcjob_open_failed = 9
err_btcjob_submit_failed = 10
err_btcjob_close_failed = 11.
ELSE.
* Convertir el spool en pdf, desde una tabla de sap
CALL FUNCTION 'CONVERT_ABAPSPOOLJOB_2_PDF'
EXPORTING
no_dialog = ' '
IMPORTING
TABLES
pdf = it_pdf
EXCEPTIONS
err_no_abap_spooljob = 1
err_no_spooljob = 2
err_bad_destdevice = 5
user_cancelled = 6
err_spoolerror = 7
err_temseerror = 8
ENDIF.
lo cual me funciona perfectamente en desarrollo, pero cuando lo transporto a calidad simplemente no me genera la orden de spool.
realizando el debuging observo que es la variable g_funcion que no me trae ningún dato en calidad
que me falta?????
Viejo 06/06/13, 10:53:41
manu_lolo27 manu_lolo27 is offline
Localización: Madrid -España
hola Minerva,
Esta de mas preguntar que el formulario esta transportado no???
Supongo que es un smartforms (si no lo es, cuentanos que tipo de formulario es), prueba lo PRIMERO en ejecutar solo el formulario con la tx. smartforms, con esto te creará el MODULO DE FUNCIONES QUE ES LO QUE NO te esta devolviendo en la función 'SSF_FUNCTION_MODULE_NAME'
espero haberte ayudado,
Manuel H.
Viejo 06/06/13, 15:45:41
Question
Hola si en efecto todo esta en calidad, si trae el valor nombre del smartform, pero no me genera la orden de spool, cosa que si hace en el ambiente de desarrollo y en calidad no.
realmente no tengo idea de lo que pueda ser porque comparo los parametros con otro reporte que tiene los mismos moulo de funcion y se genera perfectamente.
gracias por tu ayuda.
Viejo 06/06/13, 19:22:55
Kope Kope is offline
Probaste ejecutar la función desde la SE37 para ver que devolvería la variable g_funcion ?
Estos 2 post te pueden ser de utilidad:
Saludos!
Viejo 13/06/13, 16:06:30
EvaBeas EvaBeas is offline
Hola Minerva,
Has mirado si tu usuario en desarrollo e integración son iguales?? SU01 y pestaña Valores fijos.
Viejo 14/06/13, 12:40:57
daniel1050 daniel1050 is offline
Buenas.
Te fijaste que "sy-subrc" te devuelve la función:
CALL FUNCTION 'SSF_FUNCTION_MODULE_NAME' ?
Husos Horarios son GMT. La hora en este momento es 19:14:21.
