Viejo 28/06/11, 02:22:15
aan2073 aan2073 is offline
Problema Instalacion Netweaver 7.02
Que alguien me ayude por favor
Que tal...soy nuevo en SAP. Estoy tratando de instalar la version 7.02 trial en una maquina virtual WinXP:
y me da el siguiente error:
Caught a known exception during service selection. Errortext: At line 701 file synxcfile.cpp Call stack: sixxbserviceselection.cpp: 928: CSapInst::copyDirectory() synxcfile.cpp: 507: CSyFileImpl::copy(const CSyPath & C:/Archivos de programa/sapinst_instdir/NW702/AS-ABAP/ADA/CENTRAL, ISyNode::CopyMoveMode_t 0x1, ISyProgressObserver*) const System call failed. Error 87 (El parámetro no es correcto. ) in execution of system call 'CopyFile' with parameter (D:\NWASABAPTRIAL70206\SAP_NetWeaver_702e_Installation_Master\IM_WINDOWS_I386\NW702\WEBAS\IND\control.xml, C:\Archivos de programa\sapinst_instdir\NW702\AS-ABAP\ADA\CENTRAL\control.xml, FALSE), line (698) in file (synxcfile.cpp), stack trace: sixxbserviceselection.cpp: 928: CSapInst::copyDirectory() synxcfile.cpp: 507: CSyFileImpl::copy(const CSyPath & C:/Archivos de programa/sapinst_instdir/NW702/AS-ABAP/ADA/CENTRAL, ISyNode::CopyMoveMode_t 0x1, ISyProgressObserver*) const . Message stack: Opened sylib721.dll exe dir is C:\DOCUME~1\XPMUser\CONFIG~1\Temp\sapinst_exe.1908.1309227560 MessageLib initialized successfully. Creating file C:\Documents and Settings\XPMUser\Configuración local\Temp\sapinst_exe.1908.1309227560\dev_sap_kernel_test_27_Jun_2011_23_19_40. Removed file C:\Documents and Settings\XPMUser\Configuración local\Temp\sapinst_exe.1908.1309227560\dev_sap_kernel_test_27_Jun_2011_23_19_40. Initialized SAP kernel tracing to file C:\DOCUME~1\XPMUser\CONFIG~1\Temp\sapinst_exe.1908.1309227560\dev_sap_kernel Creating file C:\Documents and Settings\XPMUser\Configuración local\Temp\sapinst_exe.1908.1309227560\dev_sap_kernel_test_27_Jun_2011_23_19_40. Removed file C:\Documents and Settings\XPMUser\Configuración local\Temp\sapinst_exe.1908.1309227560\dev_sap_kernel_test_27_Jun_2011_23_19_40. Initialized SAP kernel tracing to file C:\DOCUME~1\XPMUser\CONFIG~1\Temp\sapinst_exe.1908.1309227560\dev_sap_kernel Opened C:\DOCUME~1\XPMUser\CONFIG~1\Temp\sapinst_exe.1908.1309227560/iaguieng721.dll receiving and sending on port 21200 Environment variable SAPINST_JRE_HOME set to value 'C:/DOCUME~1/XPMUser/CONFIG~1/Temp/sapinst_exe.1908.1309227560/jre'. exe dir is C:/DOCUME~1/XPMUser/CONFIG~1/Temp/sapinst_exe.1908.1309227560 Creating file C:\Archivos de programa\sapinst_instdir\x. Removed file C:\Archivos de programa\sapinst_instdir\x. Opened C:\DOCUME~1\XPMUser\CONFIG~1\Temp\sapinst_exe.1908.1309227560/iakdblib721.dll SAPinst build information: -------------------------- abi version : 721 make variant: 720_REL build : 1128529 compile time: Jan 20 2010 03:41:04 showing dlg diProductChoice <dialog sid="diProductChoice"> <title>Welcome to SAP Installation Master</title> <dialog/> Login in progress Connection request to guiengine backend by host 10.10.0.10 Protocol version is 3.1 Send connect information client logged on Waiting for an answer from GUI CDialogHandler: ACTION_NEXT requested <dialog sid="diProductChoice"> <dialog/> Creating file C:\Archivos de programa\sapinst_instdir\NW702\AS-ABAP\ADA\CENTRAL\x. Removed file C:\Archivos de programa\sapinst_instdir\NW702\AS-ABAP\ADA\CENTRAL\x. Target node does not exists and (mode & ISyNode::MISSING) ==> I will copy/move. Copying file D:/NWASABAPTRIAL70206/SAP_NetWeaver_702e_Installation_Master/IM_WINDOWS_I386/NW702/WEBAS/IND/control.xml to C:/Archivos de programa/sapinst_instdir/NW702/AS-ABAP/ADA/CENTRAL System call failed. Error 87 (El parámetro no es correcto. ) in execution of system call 'CopyFile' with parameter (D:\NWASABAPTRIAL70206\SAP_NetWeaver_702e_Installation_Master\IM_WINDOWS_I386\NW702\WEBAS\IND\control.xml, C:\Archivos de programa\sapinst_instdir\NW702\AS-ABAP\ADA\CENTRAL\control.xml, FALSE), line (698) in file (synxcfile.cpp), stack trace: sixxbserviceselection.cpp: 928: CSapInst::copyDirectory() synxcfile.cpp: 507: CSyFileImpl::copy(const CSyPath & C:/Archivos de programa/sapinst_instdir/NW702/AS-ABAP/ADA/CENTRAL, ISyNode::CopyMoveMode_t 0x1, ISyProgressObserver*) const . Exception thrown near line 701 in file synxcfile.cpp Stack trace: sixxbserviceselection.cpp: 928: CSapInst::copyDirectory() synxcfile.cpp: 507: CSyFileImpl::copy(const CSyPath & C:/Archivos de programa/sapinst_instdir/NW702/AS-ABAP/ADA/CENTRAL, ISyNode::CopyMoveMode_t 0x1, ISyProgressObserver*) const At line 701 file synxcfile.cpp Call stack: sixxbserviceselection.cpp: 928: CSapInst::copyDirectory() synxcfile.cpp: 507: CSyFileImpl::copy(const CSyPath & C:/Archivos de programa/sapinst_instdir/NW702/AS-ABAP/ADA/CENTRAL, ISyNode::CopyMoveMode_t 0x1, ISyProgressObserver*) const System call failed. Error 87 (El parámetro no es correcto. ) in execution of system call 'CopyFile' with parameter (D:\NWASABAPTRIAL70206\SAP_NetWeaver_702e_Installation_Master\IM_WINDOWS_I386\NW702\WEBAS\IND\control.xml, C:\Archivos de programa\sapinst_instdir\NW702\AS-ABAP\ADA\CENTRAL\control.xml, FALSE), line (698) in file (synxcfile.cpp), stack trace: sixxbserviceselection.cpp: 928: CSapInst::copyDirectory() synxcfile.cpp: 507: CSyFileImpl::copy(const CSyPath & C:/Archivos de programa/sapinst_instdir/NW702/AS-ABAP/ADA/CENTRAL, ISyNode::CopyMoveMode_t 0x1, ISyProgressObserver*) const . Failed action: with parameters Error number 0 error type NONE
Husos Horarios son GMT. La hora en este momento es 23:22:28.
