Viejo 22/07/10, 15:02:39
Yessica Suarez Yessica Suarez is offline
Red face optimizar mi programa
Tengo estas dos rutinas me gustaria mejorarlas ya que duran ucho en la ejecucion, me podrian ayudar?
FORM buscar_datos.
SELECT banfn bnfpo sakto kostl lstar
INTO CORRESPONDING FIELDS OF TABLE t_ebkn FROM ebkn
WHERE kostl IN p_ceco.
SORT t_ebkn.
DESCRIBE TABLE t_ebkn LINES v_cont.
CHECK v_cont NE 0. CLEAR v_cont.
SELECT banfn bnfpo loekz txz01 menge badat lfdat preis ebeln ebelp
bedat waers
INTO CORRESPONDING FIELDS OF TABLE t_eban FROM eban
FOR ALL ENTRIES IN t_ebkn
WHERE banfn = t_ebkn-banfn AND
bnfpo = t_ebkn-bnfpo AND
BADAT IN p_fech.
* lfdat IN p_fech.
SORT t_eban.
DESCRIBE TABLE t_eban LINES v_cont.
SORT t_ebkn BY banfn bnfpo.
LOOP AT t_ebkn.
CLEAR t_eban.
READ TABLE t_eban WITH KEY banfn = t_ebkn-banfn
bnfpo = t_ebkn-bnfpo.
IF sy-subrc EQ 0.
PERFORM blanquea.
IF NOT t_eban-ebeln IS INITIAL.
PERFORM buscar_pedido.
IF w_ent EQ 0.
PERFORM validar_partidas.
ENDIF.
ELSE.
ENDIF.
ENDIF.
ENDLOOP.
ENDFORM. " BUSCAR_DATOS
FORM buscar_pedido.
SELECT * FROM eket WHERE ebeln = t_eban-ebeln AND
ebelp = t_eban-ebelp AND
banfn = t_eban-banfn AND
bnfpo = t_eban-bnfpo.
MOVE eket-eindt TO w_eindt.
EXIT.
ENDSELECT.
SELECT SINGLE * FROM ekpo WHERE ebeln = t_eban-ebeln AND
ebelp = t_eban-ebelp.
IF sy-subrc EQ 0.
MOVE ekpo-ebeln TO w_ebeln.
MOVE ekpo-ebelp TO w_ebelp.
MOVE ekpo-txz01 TO w_txz01.
MOVE ekpo-netwr TO w_netwr.
MOVE ekpo-loekz TO w_loekz.
SELECT SINGLE * FROM ekko WHERE ebeln = ekpo-ebeln.
IF sy-subrc EQ 0.
MOVE ekko-waers TO w_waers.
SELECT SINGLE * FROM lfa1 WHERE lifnr = ekko-lifnr.
IF sy-subrc EQ 0.
MOVE ekko-lifnr TO w_lifnr.
MOVE lfa1-name1 TO w_name1.
ENDIF.
ENDIF.
ENDIF.
SELECT * FROM ekkn WHERE ebeln = t_eban-ebeln AND
MOVE ekkn-loekz TO w_loekz1.
IF t_eban-ebeln+0(2) EQ '51'.
MOVE t_eban-bedat TO w_aedat.
ELSE.
MOVE ekkn-aedat TO w_aedat.
ENDIF.
EXIT.
ENDSELECT.
REFRESH: t_ekbe,
t_ekbe1,
t_ekbe2,
t_ekbe3.
CLEAR: t_ekbe,
t_ekbe1,
t_ekbe2,
t_ekbe3.
SELECT ebeln ebelp vgabe gjahr belnr buzei bwart
budat wrbtr waers lfbnr
INTO CORRESPONDING FIELDS OF TABLE t_ekbe2 FROM ekbe
vgabe = '1' AND
bwart = '101' AND
wrbtr <> 0.
INTO CORRESPONDING FIELDS OF TABLE t_ekbe3 FROM ekbe
vgabe = '1' AND
bwart = '102' AND
wrbtr <> 0.
MOVE 1 TO w_index.
LOOP AT t_ekbe2.
READ TABLE t_ekbe3 INDEX w_index.
IF sy-subrc NE 0.
MOVE-CORRESPONDING t_ekbe2 TO t_ekbe.
APPEND t_ekbe.
ENDIF.
ADD 1 TO w_index.
ENDLOOP.
DESCRIBE TABLE t_ekbe LINES v_cont1.
INTO CORRESPONDING FIELDS OF TABLE t_ekbe1 FROM ekbe
( vgabe = '2' OR
vgabe = 'P' ).
DESCRIBE TABLE t_ekbe1 LINES v_cont2.
LOOP AT t_ekbe1.
SELECT SINGLE * FROM rbkp WHERE gjahr = t_ekbe1-gjahr AND
belnr = t_ekbe1-belnr.
IF sy-subrc EQ 0.
IF rbkp-stblg NE space.
DELETE t_ekbe1.
ENDIF.
ENDIF.
ENDLOOP.
SORT t_ekbe BY lfbnr.
MOVE 1 TO w_index.
LOOP AT t_ekbe.
MOVE space TO w_belnr.
MOVE 0 TO w_wrbtr1.
MOVE 0 TO w_dif.
LOOP AT t_ekbe1 WHERE lfbnr = t_ekbe-lfbnr.
IF t_ekbe-wrbtr GT t_ekbe1-wrbtr.
w_dif = t_ekbe-wrbtr - t_ekbe1-wrbtr.
ELSE.
IF t_ekbe-wrbtr LT t_ekbe1-wrbtr.
w_dif = t_ekbe1-wrbtr - t_ekbe-wrbtr.
ELSE.
ENDIF.
ENDIF.
IF w_dif GE 0 AND
w_dif LE 1.
MOVE t_ekbe1-belnr TO w_belnr.
MOVE t_ekbe1-wrbtr TO w_wrbtr1.
PERFORM buscar_doccont.
EXIT.
ENDIF.
ENDLOOP.
** MOVE t_ekbe-lfbnr TO w_lfbnr.
MOVE t_ekbe-belnr TO w_belnr1.
MOVE t_ekbe-budat TO w_budat.
MOVE t_ekbe-waers TO w_waers1.
MOVE t_ekbe-wrbtr TO w_wrbtr.
MOVE 1 TO w_ent.
ADD 1 TO w_index.
ENDLOOP.
IF v_cont1 EQ 0 AND v_cont2 NE 0.
LOOP AT t_ekbe1.
MOVE 1 TO w_ent.
ENDLOOP.
ENDIF.
ENDFORM. " buscar_pedido
Viejo 22/07/10, 15:23:51
Avatar de mysmb2
mysmb2 mysmb2 is offline
Localización: Cordoba
primero tenes que sacar los CORRESPONDING FIELDS OF TABLE ya que se consume tiempo buscando que campo seleccionado corresponde con con cada campo de la tabla interna.
En cuanto a los FOR ALL ENTRIES IN t_tabla debes tener ordenada dicha tabla por los campos a comparar y borrar los duplicados si los puede haber.
Tambien veo que en la segunda rutina tenes un Select dentro de un loop. aca deberias reemplazarlo por un FOR ALL ENTRIES a esa tabla que haces el loop.
Por ultimo hay loops anidados, deberias tratar de evitarlo de ser posible.
Espero te sirva de ayuda para mejorar el rendimiento.
Sebastián Chiavia
Viejo 22/07/10, 21:23:50
Avatar de Fabian leonardo velasquez
Fabian leonardo velasquez Fabian leonardo velasquez is offline
Localización: Facatativa
Lightbulb Premisas
Programar es un arte. Compañero para tu experiencia, cuando se programa se hace mas o menos así:
1. Definir lo elementos a utilizar
2. Inicializar variables i son necesarias.
3. CONSULTAS A LA BASE DE DATOS ( en tu ejemplo ), para esto debes utilizar areas de trabajo, tablas internas. el select *** end select consume mucho mas tiempo que hacer un FOR ALL Entries (Primero organiza las tablas por campos clave) para poderlos organizar en un area de trabajo, luego no tendras que acceder a la base de datos( ahorro de tiempo) , si requieres un dato ya esta en la TI. y para eso puedes aplicar read tables o loop los cuales tambien puedes anidar pero para manejar la eficiencia debes discriminar con sentencias where y/o check para evitar quedar inmerso en ciclos innecesarios.
4. Luego de tener los datos listos y organizados ya puedes imprimir o hacer lo que requieras.
Viejo 23/07/10, 09:57:46
jarabas jarabas is offline
evita los into corresponding field. create estructuras internas con los campos en el mismo orden en el que los pongas en la select.
TYPES: BEGIN OF ty_ejemplo,
campo1 TYPE el_que_sea,
campo2 type el_que_sea,
END OF ty_ejemplo.
data: it_ejemplo type standard table of ty_ejemplo.
select campo1 campo2 ...
into table it_ejemplo
from tabla
where condicion.
Evita las tablas con cabeceras, procura utilizar workings.
no uses los Select ... endselect.
tú código:
SELECT *
FROM eket
EXIT.
ENDSELECT.
si sólo quieres el campo "eindt", haz lo siguiente:
SELECT eindt
INTO w_eindt
FROM eket
tú código:
IF sy-subrc EQ 0.
Mejor así:
TYPES: BEGIN OF ty_ekpo,
ebeln TYPE EBELN,
ebelp TYPE EBELP,
txz01 TYPE TXZ01,
netwr TYPE BWERT,
loekz TYPE eloek,
END OF ty_ekpo.
data: wa_ekpo type ty_ekpo.
SELECT SINGLE ebeln ebelp txz01 netwr loekz
INTO wa_ekpo
FROM ekpo
IF sy-subrc EQ 0.
ya tienes los datos en la working area (WA_EKPO)
ENDIF.
Espero haberte ayudado.
Úlima edición por jarabas fecha: 23/07/10 a las 10:07:12.
Viejo 26/07/10, 22:53:01
Avatar de DavidXD_XD
Localización: Lima - Perú
Hola Yessica, aki he mejorado un poco el codigo ... con los tips que comentaron jarabas, Fabian y mysmb2 ademas algunos tips mas ...
Primero: declarar bien las variables, asumi que t_ekbe, t_ekbe1, t_ekbe2 y t_ekbe3 tenian la misma estructura y todos se trabajaban para construir la informacion en t_ekbe
Segundo: ahi va la modificacion de las subrutinas, como te aconsejaron les quite los CORRESPONDING FIELDS y uni las tablas EKKO, EKPO, LFA1 ya que esas 3 tablas estan relacionadas directamente a excepcion de la tabla EKKN porque una orden de compra no necesariamente tiene datos de imputacion
Primera Subrutina
Segunda Subrutina
Espero te pueda ayudar
David Carballido Córdova
Viejo 26/01/17, 22:00:11
Karla V. Karla V. is offline
-_-
Hola, todo el mundo dice que no usen "into corresponding fields of table" yo lo uso todo el tiempo porque no se que otra cosa usar, ¿me pueden dar un ejemplo de un codigo que sustituya al "into corresponding fields of table" ?
Husos Horarios son GMT. La hora en este momento es 16:33:28.
