Viejo 19/06/10, 20:59:30
belen6183 belen6183 is offline
Localización: Buenos Aires, Capital Federal
Question Servicio ITS
Buenas Tardes!!
Estoy intentando configurar el servicio WEBGUI que pertenece al servicio de ITS para la version 6.0
En la version 5.0 me funciona pero en la 6.0 no.
Los servicios estan todos activos en la SICF, nose si al ITS le falta algun parametro o alguna clase.
Cuando ejecuto el servicio WEBGUI me tirra error de usario.
Alguien tiene idea de que puede pasar? O algun manual que me ayude a poder terminar la configuracion?
Muchas Gracias!!!
Viejo 19/06/10, 23:37:40
Avatar de johangonz
Ejecuta la transaccion SIAC_PUBLISH_ALL_INTERNAL y luego intenta nuevamente.
Debes poner el error porqué es IMPOSIBLE ayudarte sin mostra nada
Johan González
CEO
NW Consulting Services
Siguenos en Facebook:
Moderador
Viejo 22/06/10, 16:24:12
Hola Johan
Te paso el error que me da cuando ejecuto el webgui
Error when processing your request
What has happened?
The URL was not called due to an error.
Note
The following error text was processed in the system DEV : Log on with a dialog user
The error occurred on the application server srvsap60_DEV_00 and in the work process 0 .
The termination type was: ERROR_MESSAGE_STATE
The ABAP call stack was:
Module: %_HTTP_START of program SAPMHTTP
What can I do?
If the termination type was RABAX_STATE, then you can find more information on the cause of the termination in the system DEV in transaction ST22.
If the termination type was ABORT_MESSAGE_STATE, then you can find more information on the cause of the termination on the application server srvsap60_DEV_00 in transaction SM21.
If the termination type was ERROR_MESSAGE_STATE, then you can search for more information in the trace file for the work process 0 in transaction ST11 on the application server srvsap60_DEV_00 . In some situations, you may also need to analyze the trace files of other work processes.
If you do not yet have a user ID, contact your system administrator.
Error code: ICF-IE-http -c: 000 -u: SAPSYS -l: E -s: DEV -i: srvsap60_DEV_00 -w: 0 -d: 20100622 -t: 130604 -v: ERROR_MESSAGE_STATE -e: Log on with a dialog user
HTTP 500 - Internal Server Error
Your SAP Internet Communication Framework Team
Viejo 24/06/10, 20:35:07
Avatar de johangonz
Belen?
Con que usuario te estás intentando loguear? Que tipo de usuario es ese usuario? Servicio?
Johan González
CEO
Moderador
Husos Horarios son GMT. La hora en este momento es 18:40:05.
