Viejo 09/06/10, 23:51:19
Guillo16 Guillo16 is offline
Dump ABAP ejecucióRAISE_EXCEPTION
buenas tardes,
Acudo al foro pues no se mucho de abap y me gustaria tener un poco de ayuda.
De antemano gracias por su atención.
Exception condition "NO_BATCH" raised.
Anál.errores
A RAISE statement in the program "SAPLGRAP" raised the exception
condition "NO_BATCH".
Since the exception was not intercepted by a superior program
in the hierarchy, processing was terminated.
Short description of exception condition:
Front-End Function Cannot Be Executed in Backgrnd
For detailed documentation of the exception condition, use
Transaction SE37 (Function Library). You can take the called
function module from the display of active calls.
Notas para corregir errores
You may able to find an interim solution to the problem
in the SAP note system. If you have access to the note system yourself,
use the following search criteria:
"RAISE_EXCEPTION" C
"SAPLGRAP" or "LGRAPU08"
"WS_DOWNLOAD"
or
"SAPLGRAP" "NO_BATCH"
or
"ZJAPON_EMBAR2 " "NO_BATCH"
Info posición de cancelación
The termination occurred in the ABAP program "SAPLGRAP" in "WS_DOWNLOAD".
The main program was "ZJAPON_EMBAR2 ".
The termination occurred in line 45 of the source code of the (Include)
program "LGRAPU08"
of the source code of program "LGRAPU08" (when calling the editor 450).
The program "SAPLGRAP" was started as a background job.
Detalle código fuente
000150 *" VALUE(COL_SELECTMASK) DEFAULT SPACE
000160 *" VALUE(NO_AUTH_CHECK) TYPE C DEFAULT SPACE
000170 *" EXPORTING
000180 *" VALUE(FILELENGTH)
000190 *" TABLES
000200 *" DATA_TAB
000210 *" FIELDNAMES OPTIONAL
000220 *" EXCEPTIONS
000230 *" FILE_OPEN_ERROR
000240 *" FILE_WRITE_ERROR
000250 *" INVALID_FILESIZE
000260 *" INVALID_TYPE
000270 *" NO_BATCH
000280 *" UNKNOWN_ERROR
000290 *" INVALID_TABLE_WIDTH
000300 *" GUI_REFUSE_FILETRANSFER
000310 *" CUSTOMER_ERROR
000320 *" NO_AUTHORITY
000330 *"----------------------------------------------------------------------
000340
000350 * Check DIAG_NOGRAPH
000360 * GL 19.07.96
000370 data: loop type i.
000380 data: winsystem(4).
000390 data: typ, is_bin.
000400 data: binfilesize_int type i.
000410 field-symbols: <f4>.
000420
000430 * Darf nicht im Batch ausgeführt werden
000440 IF SY-BATCH NE SPACE.
-----> RAISE NO_BATCH.
000460 ENDIF.
000470
000480 * filetype parameter gültig ?
000490 CASE FILETYPE.
000500 WHEN 'BIN' OR 'DAT' OR 'ASC' OR 'VSS' OR 'IBM' OR 'WK1' OR 'DBF'
000510 OR 'HQX'.
000520 WHEN OTHERS.
000530 MESSAGE I132 RAISING INVALID_TYPE.
000540 ENDCASE.
000550
000560 * SECURITY-Stuff
000570 * GL 9.1.95
000580
000590 DATA: RESULT.
000600 CLEAR RESULT.
000610
000620 if no_auth_check = ' '.
000630 authority-check object 'S_GUI'
000640 ID 'ACTVT'
Gracias por su atención
Úlima edición por Guillo16 fecha: 10/06/10 a las 00:08:37.
Viejo 10/06/10, 14:13:02
bisonye bisonye is offline
Guillo16 no dices lo que estás haciendo, así es dificil contestarte. Parece que el programa está intentando descargar un fichero pero la ejecución es es fondo y eso no es posible.
Husos Horarios son GMT. La hora en este momento es 20:46:40.
