Prev Mensaje Previo   Próximo Mensaje Próx
Viejo 04/03/10, 20:45:12
yosoydekaslimon yosoydekaslimon is offline
disp+work.exe stopped
Buenas tardes
Soy nuevo en el mundo sap, pero estoy encontrando bastantes inconvenientes para instalar SAPNWABAP701SR1_TRIAL
Llevo ya cerca de 2 meses intentando instalar la aplicación y he observado peor nio ha sido posibl, he observado que al levantar la instancia, queda parada disp+work.exe
Ruego vuestra ayuda, estoy bastante desesperado.
La traza es la siguiente
trc file: "dev_disp", trc level: 1, release: "701"
sysno 02
sid NSP
systemid 560 (PC with Windows NT)
relno 7010
patchlevel 0
patchno 29
intno 20020600
make: multithreaded, Unicode, optimized
pid 936
Thu Mar 04 22:38:37 2010
kernel runs with dp version 241000(ext=110000) (@(#) DPLIB-INT-VERSION-241000-UC)
length of sys_adm_ext is 576 bytes
*** SWITCH TRC-HIDE on ***
***LOG Q00=> DpSapEnvInit, DPStart (02 936) [dpxxdisp.c 1261]
shared lib "dw_xml.dll" version 29 successfully loaded
shared lib "dw_xtc.dll" version 29 successfully loaded
shared lib "dw_stl.dll" version 29 successfully loaded
shared lib "dw_gui.dll" version 29 successfully loaded
shared lib "dw_mdm.dll" version 29 successfully loaded
rdisp/softcancel_sequence : -> 0,5,-1
use internal message server connection to port 3902
Thu Mar 04 22:38:41 2010
*** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 4 seconds
***LOG GZZ=> 1 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 5529]
MtxInit: 30000 0 0
DpSysAdmExtInit: ABAP is active
DpSysAdmExtInit: VMC (JAVA VM in WP) is not active
DpIPCInit2: start server >localhost_NSP_02 <
DpShMCreate: sizeof(wp_adm) 13632 (1704)
DpShMCreate: sizeof(tm_adm) 4415616 (21968)
DpShMCreate: sizeof(wp_ca_adm) 1664 (80)
DpShMCreate: sizeof(appc_ca_adm) 1600 (80)
DpCommTableSize: max/headSize/ftSize/tableSize=500/8/528056/528064
DpShMCreate: sizeof(comm_adm) 528064 (1048)
DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
DpShMCreate: sizeof(slock_adm) 0 (96)
DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
DpShMCreate: sizeof(file_adm) 0 (72)
DpShMCreate: sizeof(vmc_adm) 0 (1544)
DpShMCreate: sizeof(wall_adm) (38456/34360/64/184)
DpShMCreate: sizeof(gw_adm) 48
DpShMCreate: SHM_DP_ADM_KEY (addr: 060D0040, size: 5042120)
DpShMCreate: allocated sys_adm at 060D0040
DpShMCreate: allocated wp_adm at 060D2170
DpShMCreate: allocated tm_adm_list at 060D56B0
DpShMCreate: allocated tm_adm at 060D56E0
DpShMCreate: allocated wp_ca_adm at 0650B760
DpShMCreate: allocated appc_ca_adm at 0650BDE0
DpShMCreate: allocated comm_adm at 0650C420
DpShMCreate: system runs without slock table
DpShMCreate: system runs without file table
DpShMCreate: allocated vmc_adm_list at 0658D2E0
DpShMCreate: allocated gw_adm at 0658D320
DpShMCreate: system runs without vmc_adm
DpShMCreate: allocated ca_info at 0658D350
DpShMCreate: allocated wall_adm at 0658D358
MBUF state OFF
DpCommInitTable: init table for 500 entries
rdisp/queue_size_check_value : -> off
ThTaskStatus: rdisp/reset_online_during_debug 0
*** ERROR => ztta/cua_area is 180000. [sapinit.c 975]
*** ERROR => ztta/cua_area adjusted to 500000. [sapinit.c 979]
EmInit: MmSetImplementation( 2 ).
MM global diagnostic options set: 0
<ES> client 0 initializing ....
<ES> InitFreeList
<ES> block size is 1024 kByte.
Using implementation view
<EsNT> Using memory model view.
<EsNT> Memory Reset disabled as NT default
<ES> 1023 blocks reserved for free list.
ES initialized.
Thu Mar 04 22:38:42 2010
rdisp/http_min_wait_dia_wp : 1 -> 1
***LOG CPS=> DpLoopInit, ICU ( 3.0 3.0 4.0.1) [dpxxdisp.c 1656]
***LOG Q0K=> DpMsAttach, mscon ( localhost) [dpxxdisp.c 12362]
*** DP_FATAL_ERROR => DpMsAttach: local hostname 'localhost' is resolved to loopback address (cf. SAP note 1054467 for details)
*** DISPATCHER EMERGENCY SHUTDOWN ***
increase tracelevel of WPs
[DpWpDied] W0 lives (PID:3600 HANDLE:1576)
killing W0-3600 (SIGUSR2)
*** ERROR => DpWpKill(3600, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W1 lives (PID:3496 HANDLE:1568)
killing W1-3496 (SIGUSR2)
*** ERROR => DpWpKill(3496, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W2 lives (PID:672 HANDLE:1564)
killing W2-672 (SIGUSR2)
*** ERROR => DpWpKill(672, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W3 lives (PID:2012 HANDLE:1560)
killing W3-2012 (SIGUSR2)
*** ERROR => DpWpKill(2012, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W4 lives (PID:1716 HANDLE:1556)
killing W4-1716 (SIGUSR2)
*** ERROR => DpWpKill(1716, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W5 lives (PID:1800 HANDLE:1552)
killing W5-1800 (SIGUSR2)
*** ERROR => DpWpKill(1800, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W6 lives (PID:3868 HANDLE:1548)
killing W6-3868 (SIGUSR2)
*** ERROR => DpWpKill(3868, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W7 lives (PID:3824 HANDLE:1544)
killing W7-3824 (SIGUSR2)
*** ERROR => DpWpKill(3824, SIGUSR2) failed [dpxxtool.c 2549]
NiWait: sleep (10000ms) ...
NiISelect: timeout 10000ms
NiISelect: maximum fd=1617
NiISelect: read-mask is NULL
NiISelect: write-mask is NULL
Husos Horarios son GMT. La hora en este momento es 05:55:10.
