Viejo 24/02/10, 15:39:49
Yanett Ponce Seares Yanett Ponce Seares is offline
Unhappy Problema al exportar un ALV a Excel
Hola !!!!
Ojala alguien me pueda ayudar, tengo un alv con varias vistas y niveles, al tratar de exportar a excel los datos que tienen como moneda GEWEI y su valor es 0, donde en pantalla lo muestra en blanco y al tratar de exportarlo se cae dando error de ejecución, al parecer trata de interpretar un blanco y debería ser un 0, y en el mismo ALV con moneda WAERK y habiendo 0 no se cae al tratar de exportar ... Alguien sabe que puede ser????
Se Agradece ....
YPonce
Viejo 24/02/10, 15:47:03
Avatar de Alfredosite
Alfredosite Alfredosite is offline
Localización: Lima-Perú
Thumbs up
Seria bueno que publiques en DUMP para saber de que se trata
Viejo 24/02/10, 16:48:47
oka tienes razón ahí va parte del dump ... no se como traspasarlo entero .... que sea mas amigable ...
Err.tmpo.ejec. GETWA_NOT_ASSIGNED
Fecha y hora 24.02.2010 14:43:40
Texto breve
Field symbol has not yet been assigned.
¿Qué ha sucedido?
Error in the ABAP Application Program
The current ABAP program "SAPLKKBL" had to be terminated because it has
come across a statement that unfortunately cannot be executed.
¿Qué puede hacer?
Note down which actions and inputs caused the error.
To process the problem further, contact you SAP system
administrator.
Using Transaction ST22 for ABAP Dump Analysis, you can look
at and manage termination messages, and you can also
keep them for a long time.
Anál.errores
You attempted to access an unassigned field symbol
(data segment 69).
This error may occur if
- You address a typed field symbol before it has been set with
ASSIGN
- You address a field symbol that pointed to the line of an
internal table that was deleted
- You address a field symbol that was previously reset using
UNASSIGN or that pointed to a local field that no
longer exists
- You address a global function interface, although the
respective function module is not active - that is, is
not in the list of active calls. The list of active calls
can be taken from this short dump.
Notas para corregir errores
If the error occures in a non-modified SAP program, you may be able to
find an interim solution in an SAP Note.
If you have access to SAP Notes, carry out a search with the following
keywords:
YPonce
Viejo 24/02/10, 17:30:27
Avatar de stormshadow
stormshadow stormshadow is offline
Bueno allí según el texto dice que un field symbol todavía no a sido asignado, en mi humilde opinión probablemente se está brincando alguna parte del código donde te asigna datos al field symbol y así vacio quieres manipular o hacer algo con el...
Serìa cuestiòn de darle una leve chekada al code ya intentaste debuggear?
"Si quieres resultados distintos, no hagas siempre lo mismo" .... Einstein
Viejo 24/02/10, 17:57:44
GRacias por responder, lo que pasa que manejo el catalago igual para todas las vistas y en ellas le paso los valores de esta forma ...
lwa_fieldcat-tabname = p_tabla.
lwa_fieldcat-fieldname = p_campo.
lwa_fieldcat-cfieldname = p_moneda. " Acá le pongo solo GEWEI (NUMERO ENTERO CON DECIMALES) O WERKS ( PESOS)
lwa_fieldcat-edit = p_nombre.
lwa_fieldcat-checkbox = p_check.
lwa_fieldcat-coltext = p_texto.
lwa_fieldcat-seltext = p_texto.
lwa_fieldcat-reptext = p_texto.
lwa_fieldcat-outputlen = p_largo.
lwa_fieldcat-emphasize = p_colorea.
lwa_fieldcat-hotspot = p_hotspot.
lwa_fieldcat-do_sum = p_suma.
lwa_fieldcat-fix_column = p_fija.
lwa_fieldcat-no_merging = p_nomerge.
ALOMEJOR ME FALTA ALGO EN EL CATALOGO ... CREES?
YPonce
Viejo 24/02/10, 18:24:44
Avatar de seimeinomi
seimeinomi seimeinomi is offline
hola,
Comenta la linea de p_moneda y proba que sucede.
Seimeinomi.
Úlima edición por seimeinomi fecha: 24/02/10 a las 18:26:55.
Viejo 24/02/10, 19:07:13
Lo hice y me funciono impeque, lo que si al sacar la moneda aquellos valores que debo mostrar como pesos sin decimal, me lo dividia por 1000 entonces hice dos catologos uno con moneda y el otro sin ..... Me funciona!!!! muchas gracias ... y sabes el trasfondo de pq' pasa?
YPonce
Viejo 26/02/10, 17:24:30
hanzzou hanzzou is offline
Localización: Moreno, Bs. As. Argentina
Cool
el problema es con el armado del catalogo..
tendrias que referenciar el campo p_moneda que usas en el catalogo a un campo tipo de moneda del diccionario.
wa_fieldcat-ref_fieldname =
es por eso el error... si me habra echo renegar eso..
Viejo 13/03/11, 09:29:44
zlatan24 zlatan24 is offline
A mi juicio la utiliza actual sabe ayudar en esta problema igual que ayude me unos semanas antes - .
  #10
Viejo 23/03/11, 18:53:27
Ariel-StaFe Ariel-StaFe is offline
Localización: Santa Fe - Argentina
Por las dudas
Por las dudas.. yo te diria que verifiques si escribiste bien el nombre del campo de la tabla cuando armas el catalogo.
Ese error me dio cuando x ejemplo tuve algun campo mal escrito, o en minusculas.
Ss
Ariel-StaFe
Analista Programador Abap Senior
Santa Fe Capital
Pcia de Santa Fe
Argentina
Husos Horarios son GMT. La hora en este momento es 20:25:52.
