Viejo 26/01/10, 10:12:05
vlg1971 vlg1971 is offline
Duda en Nota 1415481 (RH)
Tengo una duda en el punto nº 4 de la nota 1415481, esta dice los siguiente
The note says the following:
In order to verify if there is some wrong information stored in the Fiscal Data infotype (IT0062), and in order to adjust this wrong data as well, it is possible to create an own report, a "Z" report, where you can follow the following steps:
1) Read the active employees to a determined period;
2) Create a repetition structure (loop) in order to read the fiscal
data information of the infotype 0062, of the selected employees
in the previous step, only in the cases where the Applied Decrease
field (IT0062-MINOP) is different of zero (IT0062-MINOP <> 0);
3) From this entry on (once found, all records after should be
considered, for each employee), use the function
HR_E_GET_TAX_PERCENTAGE to determine the regularization reason;
4) If found some entry with the regularization reason 11 (Other
reasons) then probably you have found an error;
De los parametros que retorna la fucion donde tengo que buscar la razon de regularizacion 11
La estructura de la funcion es la siguiente:
CALL FUNCTION 'HR_E_GET_TAX_PERCENTAGE'
EXPORTING
p_pernr = pernr-pernr
p_begda = p0000-begda
p_endda = p0000-endda
p_waers = 'EUR'
* P_CALLING_CONTEXT =
IMPORTING
P_TIPO = l_TIPO
P_PORCL = l_PORCL
P_BONCA = l_BONCA
P_PPGES = l_PPGES
* P_BASEL_RESULT =
* P_TIPO_IRPF_1_RESULT =
* P_F_PAP =
tables
t0062 = p0062
t0002 = p0002
p_tipos = P_TIPOS
t0000 = p0000
t0001 = p0001
t0006 = p0006
t0016 = p0016
t0061 = p0061
* T0021 =
* TEWT_DAT =
* EXCEPTIONS
* ERROR = 1
* OTHERS = 2
Gracias por la atencionon ization
Husos Horarios son GMT. La hora en este momento es 10:47:38.
