Viejo 13/07/09, 21:45:56
Avatar de rikardote
rikardote rikardote is offline
Talking Solution Manager Key.
Se que posiblemente algunos de ustedes no tengan a la mano un solution manager, por lo que me permito el darles esta erramienta:
Toma todo el codigo y pegalo en un TXT.
Dim SIDs, SNs, SERVs, msg, ENDs, KEYs
msg="Numero de Sistema (3 Digitos.)"
SIDs=InputBox(msg,"Solution Manager Key Generator")
msg="Numero de Sistema (2 Digitos.)"
SNs=InputBox(msg,"Solution Manager Key Generator")
msg="Nombre de servidor (Maximo. 15 Digitos.)"
SERVs=InputBox(msg,"Solution Manager Key Generator")
KEYs=SolManKeyGen(SIDs, SNs, SERVs)
msg="Solution Manager Key"
ENDs=InputBox(msg,"Solution Manager Key Generator",KEYs)
Function SolManKeyGen(SIDst, SNst, SERVst)
Dim SIDSNhex(5)
Dim SERVhex(15)
Dim reshex(5)
SIDSNstr = UCase(SIDst) + UCase(SNst)
SERVstr = UCase(SERVst)
For arrcnt = 1 To 5
SIDSNhex(arrcnt) = Asc(Mid(SIDSNstr, arrcnt, 1))
Next
For arrcnt = 1 To Len(SERVstr)
SERVhex(arrcnt) = Asc(Mid(SERVstr, arrcnt, 1))
Next
For arrcnt = Len(SERVstr) + 1 To 15
SERVhex(arrcnt) = 0
Next
If (Len(SERVstr) > 0) Then
If (Len(SERVstr) < 5) Then
For arrcnt = Len(SERVstr) + 1 To 5
SERVhex(arrcnt) = Asc(" ")
Next
End If
End If
If (Len(SERVstr) > 5) Then
If (Len(SERVstr) < 10) Then
For arrcnt = Len(SERVstr) + 1 To 10
Next
End If
End If
If (Len(SERVstr) > 10) Then
If (Len(SERVstr) < 15) Then
Next
End If
End If
For arrcnt = 1 To 5
reshex(arrcnt) = ((((0 Xor SIDSNhex(arrcnt)) Xor SERVhex(arrcnt)) Xor SERVhex(arrcnt + 5)) Xor SERVhex(arrcnt + 10))
Next
reshex(1) = reshex(1) Xor 84 Xor 0
reshex(2) = reshex(2) Xor 131 Xor 11
reshex(3) = reshex(3) Xor 194 Xor 46
reshex(4) = reshex(4) Xor 52 Xor 105
reshex(5) = reshex(5) Xor 119 Xor 188
hexstr = "0123456789ABCDEF"
resstr = ""
For arrcnt = 1 To 5
hihex = reshex(arrcnt) \ 16
lohex = reshex(arrcnt) Mod 16
resstr = resstr + Mid(hexstr, hihex + 1, 1) + Mid(hexstr, lohex + 1, 1)
Next
SolManKeyGen = resstr
End Function
Guarda el TXT y cambiale la extencion a vbs
Ejemplo: tool.txt a tool.vbs
Ejecutalo y listo.
Dale los datos y te generara tu llave del solution manager.
Úlima edición por johangonz fecha: 05/05/10 a las 02:22:31. Razón: Colocar el Post como fijo
Viejo 14/07/09, 07:31:40
Javier.Garcia Javier.Garcia is offline
Muy buen aporte...
Viejo 15/07/09, 06:41:05
lluiski lluiski is offline
Fantastico, supongo que solo funciona para Solution Manager no????
Admin SAP-BASIS y puede con un futura persona de Branding & SEO/SEM
Viejo 19/01/10, 05:15:58
Avatar de BREZHNEV
BREZHNEV BREZHNEV is offline
Muy buen aporte, me sirvio, muchas gracias!!
==»BREZHNEV«==
Viejo 20/01/10, 13:25:00
koletas koletas is offline
Localización: Aranda De Duero, España
Un lujazo, gracias
SAP Basis Consultant
Viejo 21/01/10, 17:58:19
alejandrovb28 alejandrovb28 is offline
Te Sacaste un 1000! con este programita...
Gracias!
Mercy!
Danke!
Thank You!
Grazie!
Viejo 22/04/10, 14:50:34
jgsanz jgsanz is offline
Muyyyy Bueno
Viejo 05/05/10, 02:21:04
Avatar de johangonz
JAJAJAJA... habrá que colocarlo como fijo!
Johan González
CEO
NW Consulting Services
Siguenos en Facebook:
Moderador
Viejo 09/06/10, 10:51:46
kuatroka kuatroka is offline
Eres un autentico crack tio! Y encima apoyando la comunidad! un monton de gracias!! yo tuve que instalar un SM local para poder hincharme a generar las claves para el futuro
un saludo y na vez mas gracias por el gran aporte!
  #10
Viejo 11/06/10, 22:47:31
jalexvides jalexvides is offline
Thumbs up
Viejo, que excelente aporte has hecho. Muchas Gracias, fue de gran ayuda.
Husos Horarios son GMT. La hora en este momento es 14:54:53.
