Regresar   MUNDOSAP > DESARROLLO > Trucos, Consejos y Advertencias
Viejo 24/03/09, 22:51:30
oscar.munoz oscar.munoz is offline
Error al instalar SAP IDES 4.7
Estimados.
Si alguien me puede ayudar con este tema, estoy instalando SAP IDES sobre Windows 2003 Server SP2 y Oracle 9i., y cuando estoy empezando a instalar me arroja el siguiente error:
INFO 2014-03-23 01:19:18
Processing of host operation t_HostInfo_SHARED succeeded.
INFO[E] 2014-03-23 01:19:49
The file system export (share) saploc does not exist.
INFO 2014-03-23 01:21:03
Copying file E:/dump/ker/NT/COMMON/OraVolatileDatabaseParameters.xml to: OraVolatileDatabaseParameters.xml.
Creating file C:\SAPinst ORACLE KERNEL\OraVolatileDatabaseParameters.xml.
PHASE 2014-03-23 01:22:18
SAP R/3 Enterprise 4.70 for Oracle
SAP Web Application Server
Request common parameters of SAP System
Create operating system accounts
INFO 2014-03-23 01:22:18
Copying file C:/SAPinst ORACLE KERNEL/keydb.xml to: C:/SAPinst ORACLE KERNEL/keydb.1.xml.
Creating file C:\SAPinst ORACLE KERNEL\keydb.1.xml.
Copying file C:/SAPinst ORACLE KERNEL/OraVolatileDatabaseParameters.xml to: C:/SAPinst ORACLE KERNEL/OraVolatileDatabaseParameters.1.xml.
Creating file C:\SAPinst ORACLE KERNEL\OraVolatileDatabaseParameters.1.xml.
INFO[E] 2014-03-23 01:22:21
Account group="starr3\SAP_LocalAdmin" does not exist. <#1>
INFO 2014-03-23 01:22:23
Account SAP_LocalAdmin has been created.
Changing account ACCOUNTNAME=starr3\SAP_LocalAdmin ACCOUNTTYPE=GROUP DESCRIPTION=SAP Local Administration Group MEMBERSHIPSEPARATOR=, OPMODE=CREATE succeeded.
Creating account ACCOUNTNAME=starr3\SAP_LocalAdmin ACCOUNTTYPE=GROUP DESCRIPTION=SAP Local Administration Group MEMBERSHIPSEPARATOR=, OPMODE=CREATE succeeded.
INFO[E] 2014-03-23 01:22:25
Account group="starr3\SAP_DRS_LocalAdmin" does not exist. <#1>
INFO 2014-03-23 01:22:28
Account SAP_DRS_LocalAdmin has been created.
Changing account ACCOUNTNAME=starr3\SAP_DRS_LocalAdmin ACCOUNTTYPE=GROUP DESCRIPTION=SAP Local Administration Group MEMBERSHIPSEPARATOR=, OPMODE=CREATE succeeded.
Creating account ACCOUNTNAME=starr3\SAP_DRS_LocalAdmin ACCOUNTTYPE=GROUP DESCRIPTION=SAP Local Administration Group MEMBERSHIPSEPARATOR=, OPMODE=CREATE succeeded.
INFO[E] 2014-03-23 01:22:30
Account group="starr3\SAP_DRS_GlobalAdmin" does not exist. <#1>
INFO 2014-03-23 01:22:33
Account SAP_DRS_GlobalAdmin has been created.
Changing account ACCOUNTNAME=starr3\SAP_DRS_GlobalAdmin ACCOUNTTYPE=GROUP DESCRIPTION=SAP Global Administration Group MEMBERSHIPSEPARATOR=, OPMODE=CREATE succeeded.
Creating account ACCOUNTNAME=starr3\SAP_DRS_GlobalAdmin ACCOUNTTYPE=GROUP DESCRIPTION=SAP Global Administration Group MEMBERSHIPSEPARATOR=, OPMODE=CREATE succeeded.
INFO[E] 2014-03-23 01:22:35
Account group="ORA_DRS_DBA" does not exist. <#1>
INFO 2014-03-23 01:22:37
Account ORA_DRS_DBA has been created.
Changing account ACCOUNTNAME=ORA_DRS_DBA ACCOUNTTYPE=GROUP CONDITION=YES DESCRIPTION=Database Operator Group MEMBERSHIPSEPARATOR=, OPMODE=CREATE succeeded.
Creating account ACCOUNTNAME=ORA_DRS_DBA ACCOUNTTYPE=GROUP CONDITION=YES DESCRIPTION=Database Operator Group MEMBERSHIPSEPARATOR=, OPMODE=CREATE succeeded.
INFO[E] 2014-03-23 01:22:40
Account group="ORA_DRS_OPER" does not exist. <#1>
INFO 2014-03-23 01:22:42
Account ORA_DRS_OPER has been created.
Changing account ACCOUNTNAME=ORA_DRS_OPER ACCOUNTTYPE=GROUP CONDITION=YES DESCRIPTION=Database Administration Group MEMBERSHIPSEPARATOR=, OPMODE=CREATE succeeded.
Creating account ACCOUNTNAME=ORA_DRS_OPER ACCOUNTTYPE=GROUP CONDITION=YES DESCRIPTION=Database Administration Group MEMBERSHIPSEPARATOR=, OPMODE=CREATE succeeded.
Processing of all account operations of table t_SAPComponent_Accounts_Accounts_SHARED succeeded (operation CREATE).
INFO[E] 2014-03-23 01:22:44
Account user="starr3\drsadm" does not exist. <#1>
INFO 2014-03-23 01:22:50
Account drsadm has been added to group SAP_DRS_GlobalAdmin.
ERROR 2014-03-23 01:22:52
FSL-01027 Account group="starr3\Users" does not exist. <#1>
MOS-01131 Unable to create account ACCOUNTNAME=starr3\drsadm ACCOUNTTYPE=USER DESCRIPTION=SAP System Administrator MEMBERSHIP=starr3\SAP_DRS_GlobalAdmin,starr3\Users,Administrators,ORA_DRS_DBA,ORA_DRS_OPER,starr3\SAP_LocalAdmin,starr3\SAP_DRS_LocalAdmin MEMBERSHIPSEPARATOR=, OPMODE=CREATE USERPASSWORD=*... . SOLUTION: Check if you have permissions to create accounts.
MOS-01165 Processing of one or more account operations of table t_SAPComponent_Accounts_Accounts_SHARED failed (operation CREATE).
FJS-00012 Error when executing script.
INFO 2014-03-23 01:30:32
ERROR 2014-03-23 01:30:37
MOS-01135 Unable to set the membership of user ACCOUNTNAME=starr3\drsadm ACCOUNTTYPE=USER DESCRIPTION=SAP System Administrator MEMBERSHIP=starr3\SAP_DRS_GlobalAdmin,starr3\Users,Administrators,ORA_DRS_DBA,ORA_DRS_OPER,starr3\SAP_LocalAdmin,starr3\SAP_DRS_LocalAdmin MEMBERSHIPSEPARATOR=, OPMODE=CREATE USERPASSWORD=*... .
Por favor si alguien me puede orientar para ver cual es el problema
Oscar.
Viejo 26/02/10, 18:08:49
alejandrovb28 alejandrovb28 is offline
ahi lo que veo es problema de usuarios...checa que exista el usuario que dice ahi..y el grupo...en caso que no lo cree la instalacion..ayudalo y crealo tu.....por otro lado checa los permisos sean los correctos con el usuario que estas corriendo la instalacion , espero te sirva...saludos
Viejo 05/03/10, 22:57:55
Gforze Gforze is offline
Suena a que falta un usuario o posiblemente que no coinciden la confirmacion del password, nunca me ha salido algo similar, si gustas puedes escribirme a y con mucho gusto te ayudo.
Saludos y suerte!!
Código HTML está On
Husos Horarios son GMT. La hora en este momento es 06:53:17.
