Viejo 07/11/08, 20:01:10
ElmerRodriguez ElmerRodriguez is offline
Problema extendiendo interactive form
Estoy extendiendo un Interactive form, que es el medruck con su respectiva interfaz, los copie a z cada uno.. los active y funcinan perfectamente.. entonces en mi interfaz zmedruck_po le declare un estructura de tabla y la lleno con los datos que necesito.. lo activo y todo bien hasta ahi, sin errores... cuando voy al formulario entonces desde los datos globales, lo paso al contexto y cuando consumo los datos me da un dump.
What happened?
Error in the ABAP Application Program
The current ABAP program "SAPFM06P" had to be te
come across a statement that unfortunately canno
The following syntax error occurred in program "
include "/1BCDWB/LSM00000004F01 " in
line 1902:
"Field "RV61A-AWEI1" is unknown. It is neither i
"tables nor defined by a "DATA" statement . . .
The include has been created and last changed by
Created by: "ERODRIGUEZ "
Last changed by: "ERODRIGUEZ "
Error analysis
The following syntax error was found in the prog
99 OTHERS = 5.
100 IF sy-subrc <> 0.
101 MESSAGE ID sy-msgid TYPE sy-msgty NUMBER sy-msgno
102 WITH sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4.
103 ENDIF.
104
105 CLEAR: fp_docparams.
106 fp_docparams-langu = nast-tdspras.
107 fp_docparams-country = nast-tland.
108 IF nast-kappl = 'EF'.
>>>>> call function ls_function
110 EXPORTING
111 /1bcdwb/docparams = fp_docparams
112 mode = cl_output_po->mode
113 header = cl_output_po->is_ekko
114 addressinfo = cl_output_po->is_t024e
115 headerinfo = cl_output_po->is_t166u
116 contactinfo = cl_output_po->is_t024
117 headertext = cl_output_po->it_t166k
118 paymentterms = cl_output_po->it_payment
119 item = cl_output_po->it_ekpo
120 itemline = cl_output_po->it_item
121 schedule = cl_output_po->it_eket
122 conditions = cl_output_po->it_komvd
123 manfdetails = cl_output_po->it_htnmat
124 changetext = cl_output_po->it_t166t
125 account = cl_output_po->it_ekkn
126 qmtext = cl_output_po->it_qmtext
127 texts = cl_output_po->it_t166p
128 documents = cl_output_po->it_drad
Husos Horarios son GMT. La hora en este momento es 23:58:23.
