Viejo 16/09/08, 17:49:52
wilcom wilcom is offline
Talking Programa para generar claves para Instalaciones SAP
Adjunto les dejo un programa que permite crear las claves para la instalación de SAP sin necesidad de generarlas por el SOLMAN.... Espero les sea de utilidad.
*& Report ZSLM_KEY *
*& ??SOLUTION MANAGER KEY *
REPORT ZSLM_KEY.
types: begin of dswpclientkey,
INSTNO type num10,
DBID(3),
BUNDLE_ID(8),
SERVICE_KEY(40),
end of dswpclientkey.
*data: dswpclientkey_w type standard table of dswpclientkey.
DATA: P_VALUE(10),
P_INSTNO(10).
PARAMETERS: P_SID(3),
P_SYSNO(2),
P_SERVER(15).
START-OF-SELECTION.
PERFORM GET_SP_VALUE USING P_SID
P_SYSNO
P_SERVER
P_INSTNO
CHANGING P_VALUE.
END-OF-SELECTION.
WRITE P_VALUE.
*& Form get_sp_value
* text
* -->P_PF_SID text
* -->P_PF_SYSNO text
* -->P_PF_SERVER text
* <--P_PF_VALUE text
FORM get_sp_value USING P_PF_SID
P_PF_SYSNO
P_PF_SERVER
P_PF_INSTNO
CHANGING P_PF_VALUE.
CONSTANTS: lc_part_len TYPE i VALUE 5,
lc_pw_len TYPE i VALUE 10,
lc_allowed_chars(38) TYPE c VALUE
'-0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ_'.
data: lf_string(20) type c,
lf_key type i,
ls_key type dswpclientkey,
lf_part(lc_part_len) type c,
lf_finalf(lc_pw_len) type c,
lf_finalx type xstring,
lf_xbuffer type xstring,
lf_opf(10) type c,
lf_langu like sy-langu,
lf_subrc like sy-subrc,
lf_len type i,
lo_conv_to_x TYPE REF TO cl_abap_conv_out_ce.
clear: lf_string, lf_finalx, lf_opf.
concatenate p_pf_sid p_pf_sysno p_pf_server into lf_string.
* Large letters only
translate lf_string to upper case.
lf_langu = sy-langu.
SET LOCALE LANGUAGE 'E'.
lo_conv_to_x = cl_abap_conv_out_ce=>create( encoding = '1100' ).
lf_len = STRLEN( lf_string ).
IF lf_string(lf_len) CN lc_allowed_chars.
else.
* Fold the input string to a lc_part_len long string
WHILE lf_len > 0.
lf_part = lf_string(lc_part_len).
SHIFT lf_string BY lc_part_len PLACES.
CALL METHOD lo_conv_to_x->reset.
CALL METHOD lo_conv_to_x->write( data = lf_part n = -1 ).
lf_xbuffer = lo_conv_to_x->get_buffer( ).
lf_finalx = lf_finalx BIT-XOR lf_xbuffer.
ENDWHILE.
lf_key = 12.
PERFORM scramble USING lf_finalx
lf_key
lc_part_len
CHANGING lf_finalf
lf_subrc.
if not lf_finalf is initial.
p_pf_value = lf_finalf.
ls_key-dbid = p_pf_sid.
ls_key-instno = p_pf_instno.
ls_key-bundle_id = 'SM_KEY'.
ls_key-service_key = lf_finalf.
if not p_pf_instno is initial.
* insert dswpclientkey_w from ls_key.
if sy-subrc <> 0.
* update dswpclientkey_w from ls_key.
endif.
endif.
else.
clear p_pf_value.
endif.
endif.
ENDFORM. " get_sp_value
*& Form scramble
* text
* -->P_LF_FINALX text
* -->P_LF_KEY text
* -->P_LC_PART_LEN text
* <--P_LF_finalf text
* <--P_LF_SUBRC text
FORM scramble USING iv_xstring TYPE xstring
iv_key TYPE i
iv_src_len TYPE i
CHANGING lf_finalf
lf_subrc LIKE sy-subrc.
CONSTANTS: lc_max_len TYPE i VALUE 20,
lc_mask(4) TYPE x VALUE '0000003F',
lc_random(64) TYPE x VALUE
'F0ED53B83244F1F876C67959FD4F13A2' &
'C15195EC5483C234774943A27DE26596' &
'5E5398789A17A33CD383A8B829FBDCA5' &
'55D702778413ACDDF9B83116610E6DFA'.
DATA: lv_key_index(4) TYPE x,
lv_rand_index(4) TYPE x,
lv_xkey(4) TYPE x,
lv_xkey_shl_1(4) TYPE x,
lv_xkey_shr_5(4) TYPE x,
lv_scramble_byte TYPE x,
lv_dest(lc_max_len) TYPE x,
lv_index TYPE i,
lv_len TYPE i.
CLEAR lf_subrc.
IF iv_src_len EQ 0. EXIT. ENDIF.
lv_len = XSTRLEN( iv_xstring ).
IF iv_src_len GT lc_max_len OR
iv_src_len GT lv_len.
lf_subrc = 2.
EXIT.
ENDIF.
lv_xkey = iv_key.
lv_xkey_shl_1 = iv_key * 2.
lv_xkey_shr_5 = iv_key DIV 32.
lv_rand_index = lv_xkey BIT-XOR lv_xkey_shr_5 BIT-XOR lv_xkey_shl_1.
lv_rand_index = lv_rand_index BIT-AND lc_mask.
lv_index = 0.
DO iv_src_len TIMES.
CATCH SYSTEM-EXCEPTIONS compute_int_times_overflow = 1.
lv_key_index = ( iv_key * lv_index * lv_index ) - lv_index.
ENDCATCH.
IF sy-subrc <> 0.
lf_subrc = 1.
EXIT.
ENDIF.
lv_scramble_byte = lc_random+lv_rand_index(1) BIT-XOR
lv_key_index+3(1).
lv_dest+lv_index(1) = iv_xstring+lv_index(1) BIT-XOR
lv_scramble_byte.
lv_index = lv_index + 1.
lv_rand_index = lv_rand_index + 1.
ENDDO.
IF lf_subrc <> 0.
EXIT.
ENDIF.
WRITE lv_dest(iv_src_len) TO lf_finalf.
ENDFORM.
Husos Horarios son GMT. La hora en este momento es 04:33:55.
