Viejo 14/07/08, 21:31:58
jeanficetola jeanficetola is offline
Localización: Venezuela
Smile Como colocar los titulos de un ALV Jerarquico (las posiciones en la Cabecera)
FORM append_alv_for_documents .
DATA: ls_layout TYPE slis_layout_alv,
lt_fieldcat TYPE slis_t_fieldcat_alv,
lt_fieldcat_all TYPE slis_t_fieldcat_alv,
lt_eventtab TYPE slis_t_event,
ls_key TYPE slis_keyinfo_alv,
ls_events TYPE slis_alv_event.
FIELD-SYMBOLS:
<ls_fieldcat> TYPE slis_fieldcat_alv.
CALL FUNCTION 'REUSE_ALV_FIELDCATALOG_MERGE'
EXPORTING
i_program_name = sy-repid
i_structure_name = 'FAGL_S_RFBELJ10_DOCUMENTS_HEAD'
CHANGING
ct_fieldcat = lt_fieldcat
EXCEPTIONS
inconsistent_interface = 1
program_error = 2
OTHERS = 3.
IF sy-subrc <> 0.
MESSAGE ID sy-msgid TYPE sy-msgty NUMBER sy-msgno
WITH sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4.
ENDIF.
LOOP AT lt_fieldcat ASSIGNING <ls_fieldcat>.
<ls_fieldcat>-tabname = 'HEAD'.
CASE <ls_fieldcat>-fieldname.
* WHEN 'USNAM'.
* <ls_fieldcat>-no_out = 'X'.
* if poland is initial.
* endif.
WHEN 'BUKRS' OR 'GJAHR'.
* WHEN 'NUMBR'.
* <ls_fieldcat>-seltext_l = text-140.
* <ls_fieldcat>-seltext_m = text-140.
* <ls_fieldcat>-seltext_s = text-140.
* <ls_fieldcat>-reptext_ddic = text-140.
* <ls_fieldcat>-no_zero = 'X'.
WHEN 'WAERS'.
WHEN 'CPUDT'.
WHEN 'BLDAT'.
WHEN 'BLAR'.
WHEN 'DOCNR'.
WHEN 'RYEAR'.
WHEN 'STBLG'.
WHEN 'STJAH'.
ENDCASE.
ENDLOOP.
APPEND LINES OF lt_fieldcat TO lt_fieldcat_all.
REFRESH lt_fieldcat.
EXPORTING
i_structure_name = 'FAGL_S_RFBELJ10_DOCUMENTS_ITEM'
CHANGING
EXCEPTIONS
program_error = 2
OTHERS = 3.
<ls_fieldcat>-tabname = 'ITEM'.
WHEN 'BUKRS' OR 'GJAHR' OR 'BELNR' OR 'NUMBR' OR 'HWAER'
OR 'NAME2' OR 'PSTLZ' OR 'ORT01' OR 'STRAS'
OR 'SGTXT'.
WHEN 'WRSHB'.
WHEN 'BUZEI'.
WHEN 'DOCLN'.
WHEN 'GSBER'.
WHEN 'BSCHL'.
WHEN 'UMSKZ'.
WHEN ' XNEGP'.
WHEN 'KOART'.
<ls_fieldcat>-no_out = 'X'. "note955881
WHEN 'XNEGP'.
WHEN 'DMHAB'. "HABER
<ls_fieldcat>-do_sum = 'X'.
IF italy IS INITIAL. "note955881
<ls_fieldcat>-seltext_l = text-131.
<ls_fieldcat>-seltext_m = text-131.
<ls_fieldcat>-seltext_s = text-131.
<ls_fieldcat>-reptext_ddic = text-131.
ENDIF.
* <ls_fieldcat>-outputlen = 15.
WHEN 'DMSOL'. "DEBE
<ls_fieldcat>-seltext_l = text-130.
<ls_fieldcat>-seltext_m = text-130.
<ls_fieldcat>-seltext_s = text-130.
<ls_fieldcat>-reptext_ddic = text-130.
ENDIF.
WHEN 'DOCLN'.
IF NOT fagl_active IS INITIAL
AND par_docc IS INITIAL.
ELSE.
ENDIF.
ENDCASE.
ENDLOOP.
ls_layout-list_append = 'X'.
ls_layout-min_linesize = 255.
ls_layout-info_fieldname = 'COLOR'.
ls_events-name = 'END_OF_LIST'.
ls_events-form = 'OUTPUT_EOL'.
append ls_events to lt_eventtab.
ls_events-name = 'TOP_OF_PAGE'.
ls_events-form = 'TOP_OF_PAGE'.
APPEND ls_events TO lt_eventtab.
ls_events-name = 'END_OF_PAGE'.
ls_events-form = 'END_OF_PAGE'.
ls_key-header01 = 'BUKRS'.
ls_key-item01 = 'BUKRS'.
ls_key-header02 = 'BELNR'.
ls_key-item02 = 'BELNR'.
ls_key-header03 = 'GJAHR'.
ls_key-item03 = 'GJAHR'.
gs_variant-report = sy-repid.
gs_variant-variant = par_var1.
CALL FUNCTION 'REUSE_ALV_HIERSEQ_LIST_DISPLAY'
EXPORTING
i_callback_program = sy-repid
is_layout = ls_layout
it_fieldcat = lt_fieldcat_all
* it_sort = lt_sort_acc
is_variant = gs_variant
i_save = 'A'
it_events = lt_eventtab
i_tabname_header = 'HEAD'
i_tabname_item = 'ITEM'
is_keyinfo = ls_key
is_print = gs_print
TABLES
t_outtab_header = gt_doc_head
t_outtab_item = gt_doc_item
EXCEPTIONS
program_error = 1
OTHERS = 2.
IF sy-subrc <> 0.
ENDIF.
ENDFORM.
(Necesito colocar las posiciones en la misma linea de la cabecera
Viejo 14/07/08, 23:32:40
ic_man_777 ic_man_777 is offline
Localización: Mexico
Busque y no encontre como hacer eso... si lo encuentras me avisas =)
Yo lo unico que pude hacer fue, a mi tabla interna de items agregarle un campo blank de tamaño de un caracter.
E ir metiendo ese campo al fieldcat cuando era necesario, para alinearlo aproximadamente a la columna del header.
Puedes meter varias veces el mismo campo en la tabla de items, así que, si metes un campo en blanco este lo espaciará... en el titulo de este campo tambien lo dejé vacío...
Husos Horarios son GMT. La hora en este momento es 16:11:17.
