Viejo 13/02/08, 13:17:24
Pato Pato is offline
DIR_LIBRARY y dbms_type are invalid. DLENOACCESS dboraslib.sl
Tengo un error al hacer un tp connect:
tp connect DES pf=/usr/sap/trans/bin/TPPARAM
This is tp version 270.00.35 (release 45B) for ORACLE database
ERROR: No connect due to DbSl Load Lib Failure
ERROR: The values set for DIR_LIBRARY ('/usr/sap/DES/SYS/exe/run') or dbms_type ('ora') are invalid.
ERROR: Connect to DES failed (20080212162613).
TRACE-INFO: 1: [developertrace,0] Tue Feb 12 16:26:13 2008 1195 0.001195
TRACE-INFO: 2: [developertrace,0] DlLoadLib: shl_load /usr/sap/DES/SYS/exe/run/dboraslib.sl -> DLENOACCESS
TRACE-INFO: 3: 10 0.001205
TRACE-INFO: 4: [dbcon.c ,3127] *** ERROR => Couldn't load library '/usr/sap/DES/SYS/exe/run/dboraslib.sl'
TRACE-INFO: 5: 17 0.001222
TRACE-INFO: 6: [tpfsacc.c,508] tplock: check consistency of semaphore...
TRACE-INFO: 7: 83 0.001305
TRACE-INFO: 8: [tpfsacc.c,509] /usr/sap/trans/tmp/SLOG0807.DES.LOC 6 0.001311
TRACE-INFO: 9: [tpfsacc.c,508] tplock: check consistency of semaphore...
TRACE-INFO: 10: 8929 0.010240
TRACE-INFO: 11: [tpfsacc.c,509] /usr/sap/trans/tmp/SLOG0807.DES.LOC 7 0.010247
TRACE-INFO: 12: [tpfsacc.c,508] tplock: check consistency of semaphore...
TRACE-INFO: 13: 499 0.010746
TRACE-INFO: 14: [tpfsacc.c,509] /usr/sap/trans/tmp/SLOG0807.DES.LOC 6 0.010752
tp returncode summary:
TOOLS: Highest return code of single steps was: 0
ERRORS: Highest tp internal error was: 0249
tp finished with return code: 249
meaning:
connect failed due to DbSL load lib failure
Esa libreria dboraslib.sl existe en el directorio DIR_LIBRARY pero no sé pq me da ese error.
Alguno de vos sabe pq pasarme esto? Ayuda por favor
Graciee
Viejo 13/02/08, 13:38:50
sama sama is offline
bajate el ultimo kernel disponible para tu versión de SAP. Este fichero que comentas es del kernel, concretamente de la parte de Oracle. Instalando un nuevo kernel debería ir.
Viejo 18/02/08, 08:31:07
gracias.
Se soluciono bajando una nueva version del TP y R3TRANS y añadiendo al TPPARAM las lineas DBLIBPATH y TEST IMPORT = 0. Pero añadiendolas desde la STMS, no editando el fichero TPPARAM.
Husos Horarios son GMT. La hora en este momento es 11:14:20.
