Viejo 25/08/14, 18:07:27
fa.luis fa.luis is offline
Problema con web serice en SAP, eror XML
Tengo un problema con un web services que he hecho en SAP. Cuando lo mando llamar me pide varias veces user y password y creo no lo acepta, me regresa el siguiente XML:
<soap-env:Envelope xmlns:soap-env="http://schemas.xmlsoap.org/soap/envelope/">
<soap-env:Header/>
<soap-env:Body>
<soap-env:Fault>
<faultcode>soap-env:Server</faultcode>
<faultstring xml:lang="en">
SRT: Wrong Content-Type and empty HTTP-Body received: ("HTTP Code 200 : OK")
</faultstring>
<detail>
<ns:SystemFault xmlns:ns="http://www.sap.com/webas/710/soap/runtime/abap/fault/system/">
<Host>undefined</Host>
<Component>COREMSG</Component>
<ChainedException>
<Exception_Name>CX_SOAP_CORE</Exception_Name>
<Exception_Text>
</Exception_Text>
</ChainedException>
</ns:SystemFault>
<ns:SystemFault xmlns:ns="http://www.sap.com/webas/711/soap/runtime/abap/fault/system/">
<ChainedException xmlns:asx="http://www.sap.com/abapxml" asx:root="asx:abap" version="1.0">
<asx:values>
<EXCEPTION href="#o176"/>
</asx:values>
<asx:heap xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:abap="http://www.sap.com/abapxml/types/built-in" xmlns:cls="http://www.sap.com/abapxml/classes/global" xmlns:dic="http://www.sap.com/abapxml/types/dictionary">
<cls:CX_SOAP_CORE id="o176">
<CX_ROOT>
<TEXTID>0018FE864EEE1DECA69CF9C71ACB337F</TEXTID>
<PREVIOUS/>
<KERNEL_ERRID/>
<INTERNAL_SOURCE_POS>
<PROGID>111</PROGID>
<CONTID>1157</CONTID>
</INTERNAL_SOURCE_POS>
</CX_ROOT>
<CX_NO_CHECK/>
<CX_SOAP_CORE>
<E_LOCATION>
<CLASS>CL_SOAP_HTTP_TPBND_ROOT</CLASS>
<METHOD>get_http_headers</METHOD>
<ID>3</ID>
</E_LOCATION>
<E_TEXT>
</E_TEXT>
<E_ID>1032</E_ID>
<E_FAULT_LOCATION>1</E_FAULT_LOCATION>
<E_AREA>COREMSG</E_AREA>
<E_HOST>0</E_HOST>
<E_PROCESS_CONTROL/>
</CX_SOAP_CORE>
</cls:CX_SOAP_CORE>
</asx:heap>
</ChainedException>
</ns:SystemFault>
</detail>
</soap-env:Fault>
</soap-env:Body>
</soap-env:Envelope>
Alguien que me diga por facor de que se trata
Viejo 29/09/21, 16:27:21
Hikari Hikari is offline
Re: Problema con web serice en SAP, eror XML
Hola. Encontraste la solución al problema, estoy batallando con lo mismo.
Husos Horarios son GMT. La hora en este momento es 12:27:23.
