Problema con web serice en SAP, eror XML
Tengo un problema con un web services que he hecho en SAP. Cuando lo mando llamar me pide varias veces user y password y creo no lo acepta, me regresa el siguiente XML: <soap-env:Envelope xmlns:soap-env="http://schemas.xmlsoap.org/soap/envelope/"> <soap-env:Header/> <soap-env:Body> <soap-env:Fault> <faultcode>soap-env:Server</faultcode> <faultstring xml:lang="en"> SRT: Wrong Content-Type and empty HTTP-Body received: ("HTTP Code 200 : OK") </faultstring> <detail> <ns:SystemFault xmlns:ns="http://www.sap.com/webas/710/soap/runtime/abap/fault/system/"> <Host>undefined</Host> <Component>COREMSG</Component> <ChainedException> <Exception_Name>CX_SOAP_CORE</Exception_Name> <Exception_Text> SRT: Wrong Content-Type and empty HTTP-Body received: ("HTTP Code 200 : OK") </Exception_Text> </ChainedException> </ns:SystemFault> <ns:SystemFault xmlns:ns="http://www.sap.com/webas/711/soap/runtime/abap/fault/system/"> <Host>undefined</Host> <Component>COREMSG</Component> <ChainedException xmlns:asx="http://www.sap.com/abapxml" asx:root="asx:abap" version="1.0"> <asx:values> <EXCEPTION href="#o176"/> </asx:values> <asx:heap xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:abap="http://www.sap.com/abapxml/types/built-in" xmlns:cls="http://www.sap.com/abapxml/classes/global" xmlns:dic="http://www.sap.com/abapxml/types/dictionary"> <cls:CX_SOAP_CORE id="o176"> <CX_ROOT> <TEXTID>0018FE864EEE1DECA69CF9C71ACB337F</TEXTID> <PREVIOUS/> <KERNEL_ERRID/> <INTERNAL_SOURCE_POS> <PROGID>111</PROGID> <CONTID>1157</CONTID> </INTERNAL_SOURCE_POS> </CX_ROOT> <CX_NO_CHECK/> <CX_SOAP_CORE> <E_LOCATION> <CLASS>CL_SOAP_HTTP_TPBND_ROOT</CLASS> <METHOD>get_http_headers</METHOD> <ID>3</ID> </E_LOCATION> <E_TEXT> SRT: Wrong Content-Type and empty HTTP-Body received: ("HTTP Code 200 : OK") </E_TEXT> <E_ID>1032</E_ID> <E_FAULT_LOCATION>1</E_FAULT_LOCATION> <E_AREA>COREMSG</E_AREA> <E_HOST>0</E_HOST> <E_PROCESS_CONTROL/> </CX_SOAP_CORE> </cls:CX_SOAP_CORE> </asx:heap> </ChainedException> </ns:SystemFault> </detail> </soap-env:Fault> </soap-env:Body> </soap-env:Envelope> Alguien que me diga por facor de que se trata |
Re: Problema con web serice en SAP, eror XML
Hola. Encontraste la solución al problema, estoy batallando con lo mismo.
Husos Horarios son GMT. La hora en este momento es 07:34:25. |
