Import
Hola dentro de ese error CJS-30022 Program 'Migration Monitor
checa estos logs te daran mas informacion para atacar el error. import_monitor.java.log, import_monitor.log Seguro hay algo q no existe... Suerte! SLDS |
java version "1.4.2_13" Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_13-b06) Java HotSpot(TM) Client VM (build 1.4.2_13-b06, mixed mode) Import Monitor jobs: running 1, waiting 71, completed 0, failed 0, total 72. Import Monitor jobs: running 2, waiting 70, completed 0, failed 0, total 72. Import Monitor jobs: running 3, waiting 69, completed 0, failed 0, total 72. Loading of 'PCL2' import package: ERROR Import Monitor jobs: running 2, waiting 69, completed 0, failed 1, total 72. Import Monitor jobs: running 3, waiting 68, completed 0, failed 1, total 72. Loading of 'SAPSSEXC_9' import package: ERROR Import Monitor jobs: running 2, waiting 68, completed 0, failed 2, total 72. Import Monitor jobs: running 3, waiting 67, completed 0, failed 2, total 72. Loading of 'SAPCLUST' import package: ERROR Import Monitor jobs: running 2, waiting 67, completed 0, failed 3, total 72. Import Monitor jobs: running 3, waiting 66, completed 0, failed 3, total 72. Loading of 'SAPAPPL1_8' import package: OK Import Monitor jobs: running 2, waiting 66, completed 1, failed 3, total 72. Import Monitor jobs: running 3, waiting 65, completed 1, failed 3, total 72. Loading of 'SAPAPPL1_10' import package: OK Import Monitor jobs: running 2, waiting 65, completed 2, failed 3, total 72. Import Monitor jobs: running 3, waiting 64, completed 2, failed 3, total 72. import_monitor.log INFO: 2018-05-20 21:10:36 Import Monitor is started. CONFIG: 2018-05-20 21:10:36 Application options: dbCodepage=4103 dbType=ORA extFiles=yes importDirs=I:\sapCD2\03ides ecc6Export1\EXP1;I:\sapCD2\03ides ecc6Export2\EXP2;I:\sapCD2\03ides ecc6Export3\EXP3;I:\sapCD2\03ides ecc6Export4\EXP4;I:\sapCD2\03ides ecc6Export5\EXP5;I:\sapCD2\03ides ecc6Export5\EXP6;I:\sapCD2\03ides ecc6Export5\EXP7;I:\sapCD2\03ides ecc6Export5\EXP8;I:\sapCD2\03ides ecc6Export5\EXP9;I:\sapCD2\03ides ecc6Export5\EXP10;I:\sapCD2\03ides ecc6Export5\EXP11 installDir=C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS jobNum=3 loadArgs= -stop_on_error monitorTimeout=30 orderBy= r3loadExe=D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe sapinst= trace=all tskFiles=yes CONFIG: 2018-05-20 21:10:36 List of packages with table structure: 'SAP0000'. CONFIG: 2018-05-20 21:10:36 List of packages with views: 'SAPVIEW'. TRACE: 2018-05-20 21:10:36 com.sap.inst.migmon.imp.ImportStandardTask preCreate Parse of 'C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL' template file is started. INFO: 2018-05-20 21:10:36 com.sap.inst.migmon.imp.ImportStandardTask preCreate Parse of 'C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL' template file is successfully completed. Primary key creation: after load. Index creation: after load. INFO: 2018-05-20 21:10:37 Data codepage 4103 is determined using TOC file 'I:\sapCD2\03ides ecc6Export1\EXP1\DATA\AGR_HIERT.TOC' for package 'AGR_HIERT'. TRACE: 2018-05-20 21:10:37 com.sap.inst.migmon.LoadTask run Loading of 'SAPSSEXC_9' import package is started. TRACE: 2018-05-20 21:10:37 com.sap.inst.migmon.LoadTask run Loading of 'DOKCLU' import package is started. TRACE: 2018-05-20 21:10:37 com.sap.inst.migmon.LoadTask run Loading of 'PCL2' import package is started. TRACE: 2018-05-20 21:10:37 com.sap.inst.migmon.LoadTask processPackage Task file generation for 'DOKCLU' import package: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -ctf I "I:\sapCD2\03ides ecc6Export2\EXP2\DATA\DOKCLU.STR" "C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL" DOKCLU.TSK ORA -l DOKCLU.log TRACE: 2018-05-20 21:10:37 com.sap.inst.migmon.LoadTask processPackage Task file generation for 'SAPSSEXC_9' import package: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -ctf I "I:\sapCD2\03ides ecc6Export4\EXP4\DATA\SAPSSEXC_9.STR" "C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL" SAPSSEXC_9.TSK ORA -l SAPSSEXC_9.log TRACE: 2018-05-20 21:10:37 com.sap.inst.migmon.LoadTask processPackage Task file generation for 'PCL2' import package: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -ctf I "I:\sapCD2\03ides ecc6Export2\EXP2\DATA\PCL2.STR" "C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL" PCL2.TSK ORA -l PCL2.log TRACE: 2018-05-20 21:10:37 com.sap.inst.migmon.LoadTask processPackage Loading of 'PCL2' import package into database: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i PCL2.cmd -dbcodepage 4103 -l PCL2.log -stop_on_error TRACE: 2018-05-20 21:10:37 com.sap.inst.migmon.LoadTask processPackage Loading of 'DOKCLU' import package into database: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i DOKCLU.cmd -dbcodepage 4103 -l DOKCLU.log -stop_on_error TRACE: 2018-05-20 21:10:37 com.sap.inst.migmon.LoadTask processPackage Loading of 'SAPSSEXC_9' import package into database: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i SAPSSEXC_9.cmd -dbcodepage 4103 -l SAPSSEXC_9.log -stop_on_error ERROR: 2018-05-20 21:27:40 com.sap.inst.migmon.LoadTask run Loading of 'PCL2' import package is interrupted with R3load error. Process 'D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i PCL2.cmd -dbcodepage 4103 -l PCL2.log -stop_on_error' exited with return code 2. For mode details see 'PCL2.log' file. Standard error output: sapparam: sapargv( argc, argv) has not been called. sapparam(1c): No Profile used. sapparam: SAPSYSTEMNAME neither in Profile nor in Commandline TRACE: 2018-05-20 21:28:06 com.sap.inst.migmon.LoadTask run Loading of 'SAPAPPL1_8' import package is started. TRACE: 2018-05-20 21:28:07 com.sap.inst.migmon.LoadTask processPackage Task file generation for 'SAPAPPL1_8' import package: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -ctf I "I:\sapCD2\03ides ecc6Export3\EXP3\DATA\SAPAPPL1_8.STR" "C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL" SAPAPPL1_8.TSK ORA -l SAPAPPL1_8.log TRACE: 2018-05-20 21:28:09 com.sap.inst.migmon.LoadTask processPackage Loading of 'SAPAPPL1_8' import package into database: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i SAPAPPL1_8.cmd -dbcodepage 4103 -l SAPAPPL1_8.log -stop_on_error ERROR: 2018-05-20 21:32:07 com.sap.inst.migmon.LoadTask run Loading of 'SAPSSEXC_9' import package is interrupted with R3load error. Process 'D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i SAPSSEXC_9.cmd -dbcodepage 4103 -l SAPSSEXC_9.log -stop_on_error' exited with return code 2. For mode details see 'SAPSSEXC_9.log' file. Standard error output: sapparam: sapargv( argc, argv) has not been called. sapparam(1c): No Profile used. sapparam: SAPSYSTEMNAME neither in Profile nor in Commandline TRACE: 2018-05-20 21:32:36 com.sap.inst.migmon.LoadTask run Loading of 'SAPCLUST' import package is started. TRACE: 2018-05-20 21:32:37 com.sap.inst.migmon.LoadTask processPackage Task file generation for 'SAPCLUST' import package: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -ctf I "I:\sapCD2\03ides ecc6Export5\EXP5\DATA\SAPCLUST.STR" "C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL" SAPCLUST.TSK ORA -l SAPCLUST.log TRACE: 2018-05-20 21:32:37 com.sap.inst.migmon.LoadTask processPackage Loading of 'SAPCLUST' import package into database: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i SAPCLUST.cmd -dbcodepage 4103 -l SAPCLUST.log -stop_on_error ERROR: 2018-05-20 21:39:14 com.sap.inst.migmon.LoadTask run Loading of 'SAPCLUST' import package is interrupted with R3load error. Process 'D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i SAPCLUST.cmd -dbcodepage 4103 -l SAPCLUST.log -stop_on_error' exited with return code 2. For mode details see 'SAPCLUST.log' file. Standard error output: sapparam: sapargv( argc, argv) has not been called. sapparam(1c): No Profile used. sapparam: SAPSYSTEMNAME neither in Profile nor in Commandline TRACE: 2018-05-20 21:39:36 com.sap.inst.migmon.LoadTask run Loading of 'SAPAPPL1_10' import package is started. TRACE: 2018-05-20 21:39:36 com.sap.inst.migmon.LoadTask processPackage Task file generation for 'SAPAPPL1_10' import package: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -ctf I "I:\sapCD2\03ides ecc6Export3\EXP3\DATA\SAPAPPL1_10.STR" "C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL" SAPAPPL1_10.TSK ORA -l SAPAPPL1_10.log TRACE: 2018-05-20 21:39:37 com.sap.inst.migmon.LoadTask processPackage Loading of 'SAPAPPL1_10' import package into database: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i SAPAPPL1_10.cmd -dbcodepage 4103 -l SAPAPPL1_10.log -stop_on_error INFO: 2018-05-20 21:44:02 com.sap.inst.migmon.LoadTask run Loading of 'SAPAPPL1_8' import package is successfully completed. TRACE: 2018-05-20 21:44:06 com.sap.inst.migmon.LoadTask run Loading of 'SAPSSEXC_7' import package is started. TRACE: 2018-05-20 21:44:06 com.sap.inst.migmon.LoadTask processPackage Task file generation for 'SAPSSEXC_7' import package: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -ctf I "I:\sapCD2\03ides ecc6Export5\EXP5\DATA\SAPSSEXC_7.STR" "C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL" SAPSSEXC_7.TSK ORA -l SAPSSEXC_7.log TRACE: 2018-05-20 21:44:07 com.sap.inst.migmon.LoadTask processPackage Loading of 'SAPSSEXC_7' import package into database: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i SAPSSEXC_7.cmd -dbcodepage 4103 -l SAPSSEXC_7.log -stop_on_error INFO: 2018-05-20 21:50:08 com.sap.inst.migmon.LoadTask run Loading of 'SAPAPPL1_10' import package is successfully completed. TRACE: 2018-05-20 21:50:36 com.sap.inst.migmon.LoadTask run Loading of 'SAPSDIC_2' import package is started. TRACE: 2018-05-20 21:50:36 com.sap.inst.migmon.LoadTask processPackage Task file generation for 'SAPSDIC_2' import package: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -ctf I "I:\sapCD2\03ides ecc6Export5\EXP5\DATA\SAPSDIC_2.STR" "C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL" SAPSDIC_2.TSK ORA -l SAPSDIC_2.log TRACE: 2018-05-20 21:50:37 com.sap.inst.migmon.LoadTask processPackage Loading of 'SAPSDIC_2' import package into database: D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i SAPSDIC_2.cmd -dbcodepage 4103 -l SAPSDIC_2.log -stop_on_error lo que entiendo es que no puede cargar estos archivos: 'PCL2' , 'SAPSSEXC_9' , 'SAPCLUST' pero eso es raro por que los mismos instaladores utilice en otra pc y termine la instalacion sin errores pero voya reemplazar esos archivos pero que mas puedo hacer, por favor ayuda. Úlima edición por israel_erick fecha: 18/05/09 a las 21:19:58. |
adjunta los logs generados como 'PCL2.log', SAPSDIC_2.log, el dev_0, wp_0 y similares.
¿La versión Java es correcta? si no prueba con una para como j2sdk1.4.2_14. si es esto mira la nota 716604 ya que existen problemas con la 1.4.2_13: There was a problem detected with the SAP startup framework of the WebAS Java in combination with SUN J2SE 1.4.2_13 on Linux x86 (32 Bit) and Linux Itanium (64 Bit). Please pay attention to note 1009962 (even if you use a higher version than 1.4.2_13). Last recommended versions 1.4.2_20 b04 1.4.2_19 b07 1.4.2_17 Aquí tenemos la 1.4.2_14 en todos los sistemas sin problema
SAP Basis Consultant Úlima edición por koletas fecha: 19/05/09 a las 08:37:50. |
Error
Sobre la version de java veo que tienes una standar una b06, bueno la nota q te pasaron si dice que bajes esas versiones que son las correctas segun la nota en varias instalaciones la verdad a mi me paso, claro dentro de un windows que no me funcionan tengo q usar una full 1.4.2_14 como lo dice nuestro amigo. Checa las variables de entorno. Y bueno como lo dice el adjunta los log que te marca los log q enviaste. Hay q ver los log de cada cosa para ver que sucede. Suerte! SLDS |
PCL2.log
D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: START OF LOG: 20180520211037 D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: sccsid @(#) $Id: //bas/700_REL/src/R3ld/R3load/R3ldmain.c#6 $ SAP D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: version R7.00/V1.4 [UNICODE] Compiled Apr 2 2006 23:26:45 D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -ctf I I:\sapCD2\03ides ecc6Export2\EXP2\DATA\PCL2.STR C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL PCL2.TSK ORA -l PCL2.log D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: job completed D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: END OF LOG: 20180520211037 D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: START OF LOG: 20180520211037 D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: sccsid @(#) $Id: //bas/700_REL/src/R3ld/R3load/R3ldmain.c#6 $ SAP D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: version R7.00/V1.4 [UNICODE] Compiled Apr 2 2006 23:26:45 D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i PCL2.cmd -dbcodepage 4103 -l PCL2.log -stop_on_error DbSl Trace: ORA-1403 when accessing table SAPUSER (DB) INFO: connected to DB (DB) INFO: DbSlControl(DBSL_CMD_NLS_CHARACTERSET_GET): UTF8 (DB) INFO: PCL2 created #20180520211037 (IMP) INFO: import of PCL2 completed (744532 rows) #20180520212514 DbSl Trace: ORA-1578 occurred when executing SQL statement (parse error offset=32) (DB) ERROR: DDL statement failed (CREATE UNIQUE INDEX "PCL2~0" ON "PCL2" ( "CLIENT", "RELID", "SRTFD", "SRTF2" ) TABLESPACE PSAPSR3 STORAGE (INITIAL 80298937 NEXT 0000000640K MINEXTENTS 0000000001 MAXEXTENTS 2147483645 PCTINCREASE 0 ) ) DbSlExecute: rc = 99 (SQL error 1578) error message returned by DbSl: ORA-01578: ORACLE data block corrupted (file # 46, block # 136) ORA-01110: data file 46: 'D:\ORACLE\DM1\SAPDATA1\SR3_43\SR3.DATA43' (DB) INFO: disconnected from DB D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: job finished with 1 error(s) D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: END OF LOG: 20180520212740 SAPSDIC_2.log D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: START OF LOG: 20180520215036 D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: sccsid @(#) $Id: //bas/700_REL/src/R3ld/R3load/R3ldmain.c#6 $ SAP D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: version R7.00/V1.4 [UNICODE] Compiled Apr 2 2006 23:26:45 D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -ctf I I:\sapCD2\03ides ecc6Export5\EXP5\DATA\SAPSDIC_2.STR C:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS\DDLORA.TPL SAPSDIC_2.TSK ORA -l SAPSDIC_2.log D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: job completed D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: END OF LOG: 20180520215037 D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: START OF LOG: 20180520215037 D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: sccsid @(#) $Id: //bas/700_REL/src/R3ld/R3load/R3ldmain.c#6 $ SAP D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe: version R7.00/V1.4 [UNICODE] Compiled Apr 2 2006 23:26:45 D:\usr\sap\DM1\SYS\exe\uc\NTI386\R3load.exe -i SAPSDIC_2.cmd -dbcodepage 4103 -l SAPSDIC_2.log -stop_on_error DbSl Trace: ORA-1403 when accessing table SAPUSER (DB) INFO: connected to DB (DB) INFO: DbSlControl(DBSL_CMD_NLS_CHARACTERSET_GET): UTF8 (DB) INFO: TODIR created #20180520215039 (IMP) INFO: import of TODIR completed (3730223 rows) #20180520215337 (DB) INFO: TODIR~0 created #20180520215657 (DB) INFO: TODIR~1 created #20180520220043 (DB) INFO: TPDB2 created #20180520220044 (IMP) INFO: import of TPDB2 completed (2 rows) #20180520220044 (DB) INFO: TPDB2~0 created #20180520220045 (DB) INFO: TRESE created #20180520220045 (IMP) INFO: import of TRESE completed (457 rows) #20180520220045 (DB) INFO: TRESE~0 created #20180520220046 (DB) INFO: TRESN created #20180520220046 (IMP) INFO: import of TRESN completed (3438 rows) #20180520220047 (DB) INFO: TRESN~0 created #20180520220047 (DB) INFO: TRGTS_COMP created #20180520220048 (IMP) INFO: import of TRGTS_COMP completed (31 rows) #20180520220048 (DB) INFO: TRGTS_COMP~0 created #20180520220048 (DB) INFO: TRGTS_COMPGRP created #20180520220049 (IMP) INFO: import of TRGTS_COMPGRP completed (11 rows) #20180520220049 (DB) INFO: TRGTS_COMPGRP~0 created #20180520220049 (DB) INFO: TRGTS_COMPGRPASN created #20180520220049 (IMP) INFO: import of TRGTS_COMPGRPASN completed (84 rows) #20180520220050 (DB) INFO: TRGTS_COMPGRPASN~0 created #20180520220050 (DB) INFO: TRGTS_COMPGRP_T created #20180520220050 (IMP) INFO: import of TRGTS_COMPGRP_T completed (252 rows) #20180520220051 (DB) INFO: TRGTS_COMPGRP_T~0 created #20180520220051 (DB) INFO: TRGTS_COMP_T created #20180520220052 (IMP) INFO: import of TRGTS_COMP_T completed (709 rows) #20180520220052 (DB) INFO: TRGTS_COMP_T~0 created #20180520220053 (DB) INFO: TRJOB created #20180520220054 (IMP) INFO: import of TRJOB completed (0 rows) #20180520220054 (DB) INFO: TRJOB~0 created #20180520220054 (DB) INFO: TRSYSCOMP created #20180520220054 (IMP) INFO: import of TRSYSCOMP completed (0 rows) #20180520220054 (DB) INFO: TRSYSCOMP~0 created #20180520220055 (DB) INFO: TSPDD2 created #20180520220055 (IMP) INFO: import of TSPDD2 completed (0 rows) #20180520220055 (DB) INFO: TSPDD2~0 created #20180520220055 (DB) INFO: TSPDDCH created #20180520220056 (IMP) INFO: import of TSPDDCH completed (0 rows) #20180520220056 (DB) INFO: TSPDDCH~0 created #20180520220056 (DB) INFO: TSYS1 created #20180520220056 (IMP) INFO: import of TSYS1 completed (0 rows) #20180520220056 (DB) INFO: TSYS1~0 created #20180520220056 (DB) INFO: TSYS2 created #20180520220057 (IMP) INFO: import of TSYS2 completed (0 rows) #20180520220057 (DB) INFO: TSYS2~0 created #20180520220057 (DB) INFO: TTREEBRAEX created #20180520220059 (IMP) INFO: import of TTREEBRAEX completed (0 rows) #20180520220059 (DB) INFO: TTREEBRAEX~0 created #20180520220059 (DB) INFO: TTREEBRAEX~001 created #20180520220059 (DB) INFO: TTREEBRAIN created #20180520220059 (IMP) INFO: import of TTREEBRAIN completed (656 rows) #20180520220100 (DB) INFO: TTREEBRAIN~0 created #20180520220100 (DB) INFO: TTREEBRAIN~001 created #20180520220101 (DB) INFO: TTREECOUEX created #20180520220101 (IMP) INFO: import of TTREECOUEX completed (0 rows) #20180520220101 (DB) INFO: TTREECOUEX~0 created #20180520220101 (DB) INFO: TTREECOUEX~001 created #20180520220102 (DB) INFO: TTREECOUIN created #20180520220102 (IMP) INFO: import of TTREECOUIN completed (755 rows) #20180520220102 (DB) INFO: TTREECOUIN~0 created #20180520220103 (DB) INFO: TTREECOUIN~001 created #20180520220104 (DB) INFO: TTREEFLAEX created #20180520220104 (IMP) INFO: import of TTREEFLAEX completed (0 rows) #20180520220104 (DB) INFO: TTREEFLAEX~0 created #20180520220104 (DB) INFO: TTREEFLAEX~001 created #20180520220105 (DB) INFO: TTREEFLAIN created #20180520220105 (IMP) INFO: import of TTREEFLAIN completed (0 rows) #20180520220105 (DB) INFO: TTREEFLAIN~0 created #20180520220105 (DB) INFO: TTREEFLAIN~001 created #20180520220106 (DB) INFO: TTREERELEX created #20180520220106 (IMP) INFO: import of TTREERELEX completed (0 rows) #20180520220106 (DB) INFO: TTREERELEX~0 created #20180520220106 (DB) INFO: TTREERELEX~001 created #20180520220107 (DB) INFO: TTREERELIN created #20180520220108 (IMP) INFO: import of TTREERELIN completed (0 rows) #20180520220108 (DB) INFO: TTREERELIN~0 created #20180520220108 (DB) INFO: TTREERELIN~001 created #20180520220108 (DB) INFO: TTREEROAEX created #20180520220109 (IMP) INFO: import of TTREEROAEX completed (0 rows) #20180520220109 (DB) INFO: TTREEROAEX~0 created #20180520220110 (DB) INFO: TTREEROAEX~001 created #20180520220110 (DB) INFO: TTREEROAIN created #20180520220110 (IMP) INFO: import of TTREEROAIN completed (12037 rows) #20180520220111 (DB) INFO: TTREEROAIN~0 created #20180520220111 (DB) INFO: TTREEROAIN~001 created #20180520220112 (DB) INFO: TTREEROLEX created #20180520220112 (IMP) INFO: import of TTREEROLEX completed (0 rows) #20180520220112 (DB) INFO: TTREEROLEX~0 created #20180520220113 (DB) INFO: TTREEROLEX~001 created #20180520220113 (DB) INFO: TTREEROLIN created #20180520220113 (IMP) INFO: import of TTREEROLIN completed (21235 rows) #20180520220114 (DB) INFO: TTREEROLIN~0 created #20180520220115 (DB) INFO: TTREEROLIN~001 created #20180520220115 (DB) INFO: TTREESUBEX created #20180520220116 (IMP) INFO: import of TTREESUBEX completed (0 rows) #20180520220116 (DB) INFO: TTREESUBEX~0 created #20180520220116 (DB) INFO: TTREESUBEX~001 created #20180520220116 (DB) INFO: TTREESUBIN created #20180520220117 (IMP) INFO: import of TTREESUBIN completed (9678 rows) #20180520220117 (DB) INFO: TTREESUBIN~0 created #20180520220117 (DB) INFO: TTREESUBIN~001 created #20180520220118 (DB) INFO: TTREVBRAEX created #20180520220119 (IMP) INFO: import of TTREVBRAEX completed (0 rows) #20180520220119 (DB) INFO: TTREVBRAEX~0 created #20180520220119 (DB) INFO: TTREVBRAEX~001 created #20180520220119 (DB) INFO: TTREVBRAIN created #20180520220120 (IMP) INFO: import of TTREVBRAIN completed (0 rows) #20180520220120 (DB) INFO: TTREVBRAIN~0 created #20180520220120 (DB) INFO: TTREVBRAIN~001 created #20180520220120 (DB) INFO: TTREVCOUEX created #20180520220121 (IMP) INFO: import of TTREVCOUEX completed (0 rows) #20180520220121 (DB) INFO: TTREVCOUEX~0 created #20180520220121 (DB) INFO: TTREVCOUEX~001 created #20180520220121 (DB) INFO: TTREVCOUIN created #20180520220122 (IMP) INFO: import of TTREVCOUIN completed (0 rows) #20180520220122 (DB) INFO: TTREVCOUIN~0 created #20180520220122 (DB) INFO: TTREVCOUIN~001 created #20180520220122 (DB) INFO: TTREVROAEX created #20180520220123 (IMP) INFO: import of TTREVROAEX completed (0 rows) #20180520220123 (DB) INFO: TTREVROAEX~0 created #20180520220123 (DB) INFO: TTREVROAEX~001 created #20180520220123 (DB) INFO: TTREVROAIN created #20180520220123 (IMP) INFO: import of TTREVROAIN completed (0 rows) #20180520220123 (DB) INFO: TTREVROAIN~0 created #20180520220124 (DB) INFO: TTREVROAIN~001 created #20180520220124 (DB) INFO: TTREVROLEX created #20180520220125 (IMP) INFO: import of TTREVROLEX completed (0 rows) #20180520220125 (DB) INFO: TTREVROLEX~0 created #20180520220125 (DB) INFO: TTREVROLEX~001 created #20180520220125 (DB) INFO: TTREVROLIN created #20180520220126 (IMP) INFO: import of TTREVROLIN completed (0 rows) #20180520220126 (DB) INFO: TTREVROLIN~0 created #20180520220126 (DB) INFO: TTREVROLIN~001 created #20180520220126 (DB) INFO: TTREVSUBEX created #20180520220127 (IMP) INFO: import of TTREVSUBEX completed (0 rows) #20180520220127 (DB) INFO: TTREVSUBEX~0 created #20180520220128 (DB) INFO: TTREVSUBEX~001 created #20180520220128 (DB) INFO: TTREVSUBIN created #20180520220128 (IMP) INFO: import of TTREVSUBIN completed (0 rows) #20180520220128 (DB) INFO: TTREVSUBIN~0 created #20180520220128 (DB) INFO: TTREVSUBIN~001 created #20180520220129 (DB) INFO: TTXCP created #20180520220129 (IMP) INFO: import of TTXCP completed (33 rows) #20180520220129 (DB) INFO: TTXCP~0 created #20180520220130 (DB) INFO: TTYPS created #20180520220130 (IMP) INFO: import of TTYPS completed (23 rows) #20180520220130 (DB) INFO: TTYPS~0 created #20180520220131 (DB) INFO: TTYPT created #20180520220131 (IMP) INFO: import of TTYPT completed (2561 rows) #20180520220131 (DB) INFO: TTYPT~0 created #20180520220132 (DB) INFO: TZDVA created #20180520220132 (IMP) INFO: import of TZDVA completed (1512 rows) #20180520220132 (DB) INFO: TZDVA~0 created #20180520220133 (DB) INFO: UMODHDR created #20180520220133 (IMP) INFO: import of UMODHDR completed (2 rows) #20180520220133 (DB) INFO: UMODHDR~0 created #20180520220134 (DB) INFO: UMODOBJ created #20180520220134 (IMP) INFO: import of UMODOBJ completed (50804 rows) #20180520220137 (DB) INFO: UMODOBJ~0 created #20180520220139 (DB) INFO: UMODREL created #20180520220139 (IMP) INFO: import of UMODREL completed (1 rows) #20180520220140 (DB) INFO: UMODREL~0 created #20180520220141 (DB) INFO: UPGPARAM created #20180520220141 (IMP) INFO: import of UPGPARAM completed (3 rows) #20180520220141 (DB) INFO: UPGPARAM~0 created #20180520220142 (DB) INFO: UPGTBATG created #20180520220142 (IMP) INFO: import of UPGTBATG completed (669 rows) #20180520220142 (DB) INFO: UPGTBATG~0 created #20180520220143 (DB) INFO: UPG_DD12L created #20180520220143 (IMP) INFO: import of UPG_DD12L completed (0 rows) #20180520220143 (DB) INFO: UPG_DD12L~0 created #20180520220144 (DB) INFO: UPG_DD17S created #20180520220144 (IMP) INFO: import of UPG_DD17S completed (0 rows) #20180520220144 (DB) INFO: UPG_DD17S~0 created #20180520220144 (DB) INFO: USRFLD created #20180520220144 (IMP) INFO: import of USRFLD completed (69 rows) #20180520220145 (DB) INFO: USRFLD~0 created #20180520220146 (DB) INFO: USRFLDGRP created #20180520220146 (IMP) INFO: import of USRFLDGRP completed (67 rows) #20180520220146 (DB) INFO: USRFLDGRP~0 created #20180520220147 (DB) INFO: USRFLDT created #20180520220147 (IMP) INFO: import of USRFLDT completed (885 rows) #20180520220147 (DB) INFO: USRFLDT~0 created #20180520220148 (DB) INFO: USRFLDVAL created #20180520220148 (IMP) INFO: import of USRFLDVAL completed (14 rows) #20180520220148 (DB) INFO: USRFLDVAL~0 created #20180520220149 (DB) INFO: UTCMP created #20180520220149 (IMP) INFO: import of UTCMP completed (373 rows) #20180520220149 (DB) INFO: UTCMP~0 created #20180520220149 (DB) INFO: UVERS created #20180520220150 (IMP) INFO: import of UVERS completed (5 rows) #20180520220150 (DB) INFO: UVERS~0 created #20180520220150 (DB) INFO: UVERS_HIST created #20180520220151 (IMP) INFO: import of UVERS_HIST completed (37 rows) #20180520220151 (DB) INFO: UVERS_HIST~0 created #20180520220151 (DB) INFO: VERI_BT_VB created #20180520220152 (IMP) INFO: import of VERI_BT_VB completed (0 rows) #20180520220152 (DB) INFO: VERI_BT_VB~0 created #20180520220152 (DB) INFO: VERI_INDX created #20180520220152 (IMP) INFO: import of VERI_INDX completed (0 rows) #20180520220152 (DB) INFO: VERI_INDX~0 created #20180520220153 (DB) INFO: VRSMODISRC created #20180520220153 |
Errores:Oracle
ORA-1403
ORA-01578 Este error de oracle se suele producir cuando no se encuentran registros al ejecutar una consulta. Tambien se puede dar por el espacio en tu hdd. Generalmete un import reduce mucho la db a su termino pero mientras hace mucha expancion por todo el tipo de indexes que genera. Pero es tema de indixes tienes que regenerarlos directamente en la base.Ingresas a sqlplus con el usuario sys y regeneralos. No es tan complicado hacerlo. Con eso solucionas el problema. Suerte! SLDS |
