Viejo 19/10/10, 08:02:54
famores famores is offline
Error instalando SAP IDES 47
Hola, tengo un error al instalar SAP IDES 47 en mi maquina.
Adjunto el Log SAPAPPL0.log
Gracias!!
(DB) INFO: AGR_FLAGSB created
(IMP) INFO: import of AGR_FLAGSB completed (891 rows)
(DB) INFO: AGR_FLAGSB~0 created
(DB) INFO: AGR_HIERT created
(IMP) INFO: import of AGR_HIERT completed (8184339 rows)
DbSl Trace: ORA-1652 occured when executing SQL statement (parse error offset = 37)
DbSl Trace: sc_p=01D7F904,no=209,idc_p=00000000,con=0,act=0,sl en=210,smax=768,#vars=0,stmt=02CD30E0,table=
DbSl Trace: CREATE UNIQUE INDEX "AGR_HIERT~0" ON "AGR_HIERT" ( "MANDT", "AGR_NAME", "SPRAS", "OBJECT_ID" ) TABLE\
DbSl Trace: SPACE PSAPR10 STORAGE (INITIAL 0 NEXT 0000002560K MINEXTENTS 0000000001 MAXEXTENTS 2147483645 PCTINC\
DbSl Trace: REASE 0 ) ;
(DB) ERROR: DDL statement failed
(CREATE UNIQUE INDEX "AGR_HIERT~0" ON "AGR_HIERT" ( "MANDT", "AGR_NAME", "SPRAS", "OBJECT_ID" ) TABLESPACE PSAPR10 STORAGE (INITIAL 0 NEXT 0000002560K MINEXTENTS 0000000001 MAXEXTENTS 2147483645 PCTINCREASE 0 ) )
DbSlExecute: rc = 99
(SQL error 1652)
error message returned by DbSl:
ORA-01652: unable to extend temp segment by 2560 in tablespace PSAPTEMP
DbSl Trace: Disconnecting from connection 0 ...
DbSl Trace: Closing user session (con_hdl=0,svchp=01DC5F2C,usrhp=01DD0914)
DbSl Trace: Detaching from DB Server (con_hdl=0,svchp=01DC5F2C,srvhp=01DC8164)
DbSl Trace: Now I'm disconnected from ORACLE
(DB) INFO: disconnected from DB
E:\usr\sap\R10\SYS\exe\run/R3load.exe: job finished with 1 error(s)
E:\usr\sap\R10\SYS\exe\run/R3load.exe: END OF LOG: 20101018213349
Viejo 19/10/10, 10:56:44
jgsanz jgsanz is offline
mirate el errror ORA-1652, parece que el tablespace temp no puede ampliarse y no tiene suficiente espacio.
Viejo 19/10/10, 14:46:16
autoextend on
He aumentado el tamaño del disco y en la instalación he configurado para que en ese tablespace se haga autoextend... a ver que tal.
Viejo 21/10/10, 07:37:20
Instalacion completa
Completo!! configurando el extend desde el instalador... sin problemas :-)
Husos Horarios son GMT. La hora en este momento es 12:41:52.
