Error instalando SAP IDES 47
Hola, tengo un error al instalar SAP IDES 47 en mi maquina.
Adjunto el Log SAPAPPL0.log Gracias!! (DB) INFO: AGR_FLAGSB created (IMP) INFO: import of AGR_FLAGSB completed (891 rows) (DB) INFO: AGR_FLAGSB~0 created (DB) INFO: AGR_HIERT created (IMP) INFO: import of AGR_HIERT completed (8184339 rows) DbSl Trace: ORA-1652 occured when executing SQL statement (parse error offset = 37) DbSl Trace: sc_p=01D7F904,no=209,idc_p=00000000,con=0,act=0,sl en=210,smax=768,#vars=0,stmt=02CD30E0,table= DbSl Trace: CREATE UNIQUE INDEX "AGR_HIERT~0" ON "AGR_HIERT" ( "MANDT", "AGR_NAME", "SPRAS", "OBJECT_ID" ) TABLE\ DbSl Trace: SPACE PSAPR10 STORAGE (INITIAL 0 NEXT 0000002560K MINEXTENTS 0000000001 MAXEXTENTS 2147483645 PCTINC\ DbSl Trace: REASE 0 ) ; (DB) ERROR: DDL statement failed (CREATE UNIQUE INDEX "AGR_HIERT~0" ON "AGR_HIERT" ( "MANDT", "AGR_NAME", "SPRAS", "OBJECT_ID" ) TABLESPACE PSAPR10 STORAGE (INITIAL 0 NEXT 0000002560K MINEXTENTS 0000000001 MAXEXTENTS 2147483645 PCTINCREASE 0 ) ) DbSlExecute: rc = 99 (SQL error 1652) error message returned by DbSl: ORA-01652: unable to extend temp segment by 2560 in tablespace PSAPTEMP DbSl Trace: Disconnecting from connection 0 ... DbSl Trace: Closing user session (con_hdl=0,svchp=01DC5F2C,usrhp=01DD0914) DbSl Trace: Detaching from DB Server (con_hdl=0,svchp=01DC5F2C,srvhp=01DC8164) DbSl Trace: Now I'm disconnected from ORACLE (DB) INFO: disconnected from DB E:\usr\sap\R10\SYS\exe\run/R3load.exe: job finished with 1 error(s) E:\usr\sap\R10\SYS\exe\run/R3load.exe: END OF LOG: 20101018213349 |
mirate el errror ORA-1652, parece que el tablespace temp no puede ampliarse y no tiene suficiente espacio.
autoextend on
He aumentado el tamaño del disco y en la instalación he configurado para que en ese tablespace se haga autoextend... a ver que tal.
Gracias |
Instalacion completa
Completo!! configurando el extend desde el instalador... sin problemas :-)
Gracias |
Husos Horarios son GMT. La hora en este momento es 16:11:40. |
