  #11
Viejo 29/07/10, 23:02:21
juafigue juafigue is offline
al ver este error; *** ERROR => Invalid profile parameter dbms/type (or environment variable dbms_type) = <undef>, cannot load DB library
[dbcon.c 4537]
tuve que agregar la variable DBMS_TYPE=SAP, pero ahora me figura otro error el la trace.
trc file: "dev_disp", trc level: 1, release: "701"
Thu Jul 29 18:45:27 2010
*** ERROR => DlLoadLib: LoadLibrary(dbsapslib.dll) Error 126 [dlnt.c 241]
Error 126 = "No se puede encontrar el módulo especificado."
sysno 00
sid NSP
systemid 560 (PC with Windows NT)
relno 7010
patchlevel 0
patchno 29
intno 20020600
make: multithreaded, Unicode, optimized
pid 3004
kernel runs with dp version 241000(ext=110000) (@(#) DPLIB-INT-VERSION-241000-UC)
length of sys_adm_ext is 576 bytes
*** SWITCH TRC-HIDE on ***
***LOG Q00=> DpSapEnvInit, DPStart (00 3004) [dpxxdisp.c 1261]
shared lib "dw_xml.dll" version 29 successfully loaded
shared lib "dw_xtc.dll" version 29 successfully loaded
shared lib "dw_stl.dll" version 29 successfully loaded
shared lib "dw_gui.dll" version 29 successfully loaded
shared lib "dw_mdm.dll" version 29 successfully loaded
rdisp/softcancel_sequence : -> 0,5,-1
use internal message server connection to port 3900
Thu Jul 29 18:45:32 2010
*** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 4 seconds
***LOG GZZ=> 1 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 5529]
MtxInit: 30000 0 0
DpSysAdmExtInit: ABAP is active
DpSysAdmExtInit: VMC (JAVA VM in WP) is not active
DpIPCInit2: start server >JuanFMovil_NSP_00 <
DpShMCreate: sizeof(wp_adm) 13632 (1704)
DpShMCreate: sizeof(tm_adm) 4415616 (21968)
DpShMCreate: sizeof(wp_ca_adm) 1664 (80)
DpShMCreate: sizeof(appc_ca_adm) 1600 (80)
DpCommTableSize: max/headSize/ftSize/tableSize=500/8/528056/528064
DpShMCreate: sizeof(comm_adm) 528064 (1048)
DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
DpShMCreate: sizeof(slock_adm) 0 (96)
DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
DpShMCreate: sizeof(file_adm) 0 (72)
DpShMCreate: sizeof(vmc_adm) 0 (1544)
DpShMCreate: sizeof(wall_adm) (38456/34360/64/184)
DpShMCreate: sizeof(gw_adm) 48
DpShMCreate: SHM_DP_ADM_KEY (addr: 08FA0040, size: 5042120)
DpShMCreate: allocated sys_adm at 08FA0040
DpShMCreate: allocated wp_adm at 08FA2170
DpShMCreate: allocated tm_adm_list at 08FA56B0
DpShMCreate: allocated tm_adm at 08FA56E0
DpShMCreate: allocated wp_ca_adm at 093DB760
DpShMCreate: allocated appc_ca_adm at 093DBDE0
DpShMCreate: allocated comm_adm at 093DC420
DpShMCreate: system runs without slock table
DpShMCreate: system runs without file table
DpShMCreate: allocated vmc_adm_list at 0945D2E0
DpShMCreate: allocated gw_adm at 0945D320
DpShMCreate: system runs without vmc_adm
DpShMCreate: allocated ca_info at 0945D350
DpShMCreate: allocated wall_adm at 0945D358
MBUF state OFF
DpCommInitTable: init table for 500 entries
rdisp/queue_size_check_value : -> off
ThTaskStatus: rdisp/reset_online_during_debug 0
EmInit: MmSetImplementation( 2 ).
MM global diagnostic options set: 0
<ES> client 0 initializing ....
<ES> InitFreeList
<ES> block size is 1024 kByte.
Using implementation view
<EsNT> Using memory model view.
<EsNT> Memory Reset disabled as NT default
<ES> 1023 blocks reserved for free list.
ES initialized.
rdisp/http_min_wait_dia_wp : 1 -> 1
***LOG CPS=> DpLoopInit, ICU ( 3.0 3.0 4.0.1) [dpxxdisp.c 1656]
***LOG Q0K=> DpMsAttach, mscon ( JuanFMovil) [dpxxdisp.c 12362]
DpStartStopMsg: send start message (myname is >JuanFMovil_NSP_00 <)
DpStartStopMsg: start msg sent
CCMS: alert/MONI_SEGM_SIZE = 0 monitoring and alerting switched off.
DpMsgAdmin: Set release to 7010, patchlevel 0
MBUF state PREPARED
MBUF component UP
DpMBufHwIdSet: set Hardware-ID
***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c 1048]
DpMsgAdmin: Set patchno for this platform to 29
Release check o.K.
Thu Jul 29 18:46:12 2010
my types changed after wp death/restart 0xbf --> 0xbe
my types changed after wp death/restart 0xbe --> 0xbc
my types changed after wp death/restart 0xbc --> 0xb8
my types changed after wp death/restart 0xb8 --> 0xb0
my types changed after wp death/restart 0xb0 --> 0xa0
my types changed after wp death/restart 0xa0 --> 0x80
*** DP_FATAL_ERROR => DpWPCheck: no more work processes
*** DISPATCHER EMERGENCY SHUTDOWN ***
increase tracelevel of WPs
NiWait: sleep (10000ms) ...
NiISelect: timeout 10000ms
NiISelect: maximum fd=789
NiISelect: read-mask is NULL
NiISelect: write-mask is NULL
Thu Jul 29 18:46:22 2010
NiISelect: TIMEOUT occured (10000ms)
dump system status
Workprocess Table (long) Thu Jul 29 22:46:22 2010
No Ty. Pid Status Cause Start Err Sem CPU Time Program Cl User Action Table
0 DIA 2052 Ended no 1 0 0
1 DIA 3112 Ended no 1 0 0
2 DIA 1500 Ended no 1 0 0
3 UPD 296 Ended no 1 0 0
4 ENQ 3472 Ended no 1 0 0
5 BTC 1000 Ended no 1 0 0
6 SPO 3012 Ended no 1 0 0
7 UP2 192 Ended no 1 0 0
Dispatcher Queue Statistics Thu Jul 29 22:46:22 2010
| Typ | now | high | max | writes | reads |
| NOWP | 0 | 2 | 2000 | 5 | 5 |
| DIA | 4 | 4 | 2000 | 4 | 0 |
| UPD | 0 | 0 | 2000 | 0 | 0 |
| ENQ | 0 | 0 | 2000 | 0 | 0 |
| BTC | 0 | 0 | 2000 | 0 | 0 |
| SPO | 0 | 0 | 2000 | 0 | 0 |
| UP2 | 0 | 0 | 2000 | 0 | 0 |
y del dev_w0
trc file: "dev_w0", trc level: 1, release: "701"
* ACTIVE TRACE LEVEL 1
* ACTIVE TRACE COMPONENTS all, MJ
B
B Thu Jul 29 18:45:33 2010
B create_con (con_name=R/3)
B Loading DB library 'D:\usr\sap\NSP\DVEBMGS00\exe\dbsapslib.dll' ...
M *** ERROR => DlLoadLib: LoadLibrary(D:\usr\sap\NSP\DVEBMGS00\exe\dbsapslib.dll) Error 126 [dlnt.c 241]
M Error 126 = "No se puede encontrar el módulo especificado."
B *** ERROR => Couldn't load library 'D:\usr\sap\NSP\DVEBMGS00\exe\dbsapslib.dll'
[dbcon.c 4731]
M sysno 00
M sid NSP
M systemid 560 (PC with Windows NT)
M relno 7010
M patchlevel 0
M patchno 29
M intno 20020600
M make: multithreaded, Unicode, optimized
M pid 2052
M
M kernel runs with dp version 241000(ext=110000) (@(#) DPLIB-INT-VERSION-241000-UC)
M length of sys_adm_ext is 576 bytes
M ***LOG Q0Q=> tskh_init, WPStart (Workproc 0 2052) [dpxxdisp.c 1323]
I MtxInit: 30000 0 0
M DpSysAdmExtCreate: ABAP is active
M DpSysAdmExtCreate: VMC (JAVA VM in WP) is not active
M DpShMCreate: sizeof(wp_adm) 13632 (1704)
M DpShMCreate: sizeof(tm_adm) 4415616 (21968)
M DpShMCreate: sizeof(wp_ca_adm) 1664 (80)
M DpShMCreate: sizeof(appc_ca_adm) 1600 (80)
M DpCommTableSize: max/headSize/ftSize/tableSize=500/8/528056/528064
M DpShMCreate: sizeof(comm_adm) 528064 (1048)
M DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
M DpShMCreate: sizeof(slock_adm) 0 (96)
M DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
M DpShMCreate: sizeof(file_adm) 0 (72)
M DpShMCreate: sizeof(vmc_adm) 0 (1544)
M DpShMCreate: sizeof(wall_adm) (38456/34360/64/184)
M DpShMCreate: sizeof(gw_adm) 48
M DpShMCreate: SHM_DP_ADM_KEY (addr: 09820040, size: 5042120)
M DpShMCreate: allocated sys_adm at 09820040
M DpShMCreate: allocated wp_adm at 09822170
M DpShMCreate: allocated tm_adm_list at 098256B0
M DpShMCreate: allocated tm_adm at 098256E0
M DpShMCreate: allocated wp_ca_adm at 09C5B760
M DpShMCreate: allocated appc_ca_adm at 09C5BDE0
M DpShMCreate: allocated comm_adm at 09C5C420
M DpShMCreate: system runs without slock table
M DpShMCreate: system runs without file table
M DpShMCreate: allocated vmc_adm_list at 09CDD2E0
M DpShMCreate: allocated gw_adm at 09CDD320
M DpShMCreate: system runs without vmc_adm
M DpShMCreate: allocated ca_info at 09CDD350
M DpShMCreate: allocated wall_adm at 09CDD358
M rdisp/queue_size_check_value : -> off
M ThTaskStatus: rdisp/reset_online_during_debug 0
X EmInit: MmSetImplementation( 2 ).
X MM global diagnostic options set: 0
X <ES> client 0 initializing ....
X Using implementation view
X <EsNT> Using memory model view.
M <EsNT> Memory Reset disabled as NT default
X ES initialized.
M ThInit: running on host JuanFMovil
M calling db_connect ...
[dbcon.c 4731]
M ***LOG R19=> ThInit, db_connect ( DB-Connect 008192) [thxxhead.c 1449]
M in_ThErrHandle: 1
M *** ERROR => ThInit: db_connect (step 1, th_errno 13, action 3, level 1) [thxxhead.c 10563]
M
M Info for wp 0
M
M pid = 2052
M severity = 0
M status = 0
M stat = WP_RUN
M waiting_for = NO_WAITING
M reqtype = DP_RQ_DIAWP
M act_reqtype = NO_REQTYPE
M rq_info = 0
M tid = -1
M mode = 255
M len = -1
M rq_id = 65535
M rq_source =
M last_tid = 0
M last_mode = 0
M semaphore = 0
M act_cs_count = 0
M csTrack = 0
M csTrackRwExcl = 0
M csTrackRwShrd = 0
M mode_cleaned_counter = 0
M control_flag = 0
M int_checked_resource(RFC) = 0
M ext_checked_resource(RFC) = 0
M int_checked_resource(HTTP) = 0
M ext_checked_resource(HTTP) = 0
M report = > <
M action = 0
M tab_name = > <
M attachedVm = no VM
M
M *****************************************************************************
M *
M * LOCATION SAP-Server JuanFMovil_NSP_00 on host JuanFMovil (wp 0)
M * ERROR ThInit: db_connect
M *
M * TIME Thu Jul 29 18:45:33 2010
M * RELEASE 701
M * COMPONENT Taskhandler
M * VERSION 1
M * RC 13
M * MODULE thxxhead.c
M * LINE 10783
M * COUNTER 1
M *
M
M PfStatDisconnect: disconnect statistics
M Entering TH_CALLHOOKS
M ThCallHooks: call hook >BtcCallLgCl< for event BEFORE_DUMP
M ThCallHooks: call hook >ThrSaveSPAFields< for event BEFORE_DUMP
M *** ERROR => ThrSaveSPAFields: no valid thr_wpadm [thxxrun1.c 723]
M *** ERROR => ThCallHooks: event handler ThrSaveSPAFields for event BEFORE_DUMP failed [thxxtool3.c 261]
M Entering ThSetStatError
M ThIErrHandle: do not call ThrCoreInfo (no_core_info=0, in_dynp_env=0)
M Entering ThReadDetachMode
M call ThrShutDown (1)...
M ***LOG Q02=> wp_halt, WPStop (Workproc 0 2052) [dpnttool.c 334]
  #12
Viejo 30/07/10, 06:54:02
Avatar de elalien
elalien elalien is offline
Localización: Madrid
Yo nunca trabajé con MaxDB como base de datos, que parece que es la que estás usando tú, pero ¿estás seguro que la variable de entorno DBMS_TYPE tienes que ponerla a SAP?
Está claro que tu problema es de conexion a la BBDD, no está encontrando la libreria de conexion (dbslib)
revisa en el manual de instalacion de tu version el valor que tiene que tener dbms_type ( ¿es posible que sea ADA?)
Si quieres una vez que tengas levantada la BBDD y antes de intentar levantar SAP puedes probar a hacer un r3trans -d que chequee la conexion a la BBDD y te debe devolver un 0 si es correcto
Un saludo
  #13
Viejo 30/07/10, 09:11:58
Muy agradecido por tu ayuda, me habian dicho que pusiera Sap, y lo cambié por ADA, como me dijiste y por fin!!! Pude entrar con el sap logon(la MaxDB, viene por defecto con este version trial).
donde pruebo el r3trans -d??
Ahora uno de los errores que me dice, es que hay inconsistencia de base de datos, y que la version del Win7 no es compatible:
SAP System Check.
"OS release Windows NT 6.1 7600 2x Intel 80686 (Mod 15 step 13) is not supported with this kernel (701)".
Severe problems were detected during initial check.
Please, do not use that system before fixing these problems.
Runtime Errors START_CALL_SICK
Short text
Database inconsistency: Start Transaction SICK.
What happened?
The current program had to be terminated because of an error when installing the R/3 System.
The error occurred when initializing the R/3 System.
What can you do?
Please call the transaction sick. The list generated here contains an installation error.
Note which actions and input led to the error.
For further help in handling the problem, contact your SAp administrator.
You can use the ABAP dump analysis transaction ST22 to view and manage termination messages, in particular
for long term reference.
Error analysis
The error probably ocurred when installing the R/3 System.
Error text of the first reported error:
"OS release Windows NT 6.1 7600 2x Intel 80686 (Mod 15 step 13) is not supported with this kernel (701)."
Nuevamente te agradezco por tu ayuda y tu tiempo elalien.
  #14
Viejo 30/07/10, 10:56:02
Avatar de elalien
el r3trans -d lo puedes ejecutar desde el SO con el usuario nspadm
el otro error que te da, dudo que tenga solucion puesto que w2007 no está soportado como SO para SAP, en cualquier caso si es un sistema sólo de prueba puede que te funcione igualmente, pero lo suyo es que lo instalaras sobre un w2003 o w2008
  #15
Viejo 02/08/10, 09:00:10
Nunca pude entrar con el usuario nspadm, me mostraba un error: "error en el servicio Servicio de perfil de usuario no se puede iniciar sesion. No se puede cargar el perfil de usuario"
Como conclusión, se supone que no funciona del todo bien en Windows 7. Pero al menos me deja hacer unos prácticos que pillé por ahí.
Gracias a todos por su ayuda.
  #16
Viejo 23/05/11, 17:53:48
palomino3108 palomino3108 is offline
Yo tengo el mismo problema...con el proceso disp+work que no levanta
Ya hice todo lo indicado aqui y continuo sin poder levantar los servicios.... les envio el log del dev_w0 ... cualquier ayuda la agradesco de antemano ... saludos...
B
B Tue May 24 12:30:26 2011
B Loading DB library 'C:\usr\sap\NSP\DVEBMGS00\exe\dbsdbslib.dll' ...
B Library 'C:\usr\sap\NSP\DVEBMGS00\exe\dbsdbslib.dll' loaded
B Version of 'C:\usr\sap\NSP\DVEBMGS00\exe\dbsdbslib.dll' is "700.08", patchlevel (0.24)
B New connection 0 created
M sysno 00
M sid NSP
M relno 7010
M patchlevel 0
M patchno 29
M intno 20020600
M pid 2560
M
M ***LOG Q0Q=> tskh_init, WPStart (Workproc 0 2560) [dpxxdisp.c 1323]
M DpShMCreate: SHM_DP_ADM_KEY (addr: 092B0040, size: 5042120)
M DpShMCreate: allocated sys_adm at 092B0040
M DpShMCreate: allocated wp_adm at 092B2170
M DpShMCreate: allocated tm_adm_list at 092B56B0
M DpShMCreate: allocated tm_adm at 092B56E0
M DpShMCreate: allocated wp_ca_adm at 096EB760
M DpShMCreate: allocated appc_ca_adm at 096EBDE0
M DpShMCreate: allocated comm_adm at 096EC420
M DpShMCreate: allocated vmc_adm_list at 0976D2E0
M DpShMCreate: allocated gw_adm at 0976D320
M DpShMCreate: allocated ca_info at 0976D350
M DpShMCreate: allocated wall_adm at 0976D358
X ES initialized.
M ThInit: running on host Palomino3108
C
C DBSDBSLIB : version 700.08, patch 0.024 (Make PL 0.29)
C MAXDB shared library (dbsdbslib) patchlevels (last 10)
C (0.024) Default value for max. input variables is 2000 (note 655018)
C (0.024) Profile parameter to define max. input variables (note 655018)
C (0.024) Switch SQLMODE after CREATE INDEX SERIAL (note 1267841)
C (0.024) Input parameters for SQL statements increased (note 655018)
C (0.018) Create index serial for MaxDB 7.6 (note 1267841)
C (0.018) More trace in case of packed to string conversion error (note 1262799)
C (0.016) R3trans export aborts with signal 6 (note 1262245)
C (0.009) IA64 alignment errors (note 1245982)
C (0.007) Support DB-Type 'SAP DB' by UPDSTAT (note 1225668)
C
C
C Loading SQLDBC client runtime ...
C SQLDBC SDK Version : SQLDBC.H 7.6.0 BUILD 002-121-083-965
C SQLDBC Library Version : libSQLDBC 7.6.5 BUILD 011-123-196-300
C SQLDBC client runtime is MaxDB 7.6.5.011 CL 196300
C SQLDBC supports new DECIMAL interface : 0
C SQLDBC supports VARIABLE INPUT data : 1
C SQLDBC supports keepAlive indicator : 0
C INFO : SQLOPT= -I 0 -t 0 -S SAPR3
C Try to connect (DEFAULT) on connection 0 ...
C
C Tue May 24 12:30:27 2011
C *** ERROR => Connect to database failed, rc = -10709 (Connection failed (RTE:[5] database not running))
[dbsdbsql.cpp 137]
B ***LOG BV3=> severe db error -10709 ; work process is stopped [dbsh#2 @ 1203] [dbsh 1203 ]
B ***LOG BY2=> sql error -10709 performing CON [dblink#2 @ 431] [dblink 0431 ]
B ***LOG BY0=> Connection failed (RTE:[5] database not running) [dblink#2 @ 431] [dblink 0431 ]
M ***LOG R19=> ThInit, db_connect ( DB-Connect 000256) [thxxhead.c 1449]
M in_ThErrHandle: 1
M
M Info for wp 0
M
M pid = 2560
M severity = 0
M status = 0
M stat = WP_RUN
M rq_info = 0
M tid = -1
M mode = 255
M len = -1
M rq_id = 65535
M rq_source =
M last_tid = 0
M last_mode = 0
M semaphore = 0
M act_cs_count = 0
M csTrack = 0
M csTrackRwExcl = 0
M csTrackRwShrd = 0
M control_flag = 0
M report = > <
M action = 0
M tab_name = > <
M
M *
M * LOCATION SAP-Server Palomino3108_NSP_00 on host Palomino3108 (wp 0)
M *
M * TIME Tue May 24 12:30:27 2011
M * RELEASE 701
M * VERSION 1
M * RC 13
M * LINE 10783
M * COUNTER 1
M *
M
M ***LOG Q02=> wp_halt, WPStop (Workproc 0 2560) [dpnttool.c 334]
  #17
Viejo 23/05/11, 23:00:31
Avatar de johangonz
La instancia la debes subir con <SID>adm, seguro lo estas haciendo con administrator u otro usuario, ya que el instalador crea las variables de entorno para ese usuario. Para entrar debes poner el password que le pusiste a ese user en la instalacion del master password, al menos que hayas definido una puntual en el procedimiento. Desconozco si corre en 7, esos OS hace mucho tiempo que dejaron de gustarme jajaja... son un dolor!!!
Johan González
CEO
NW Consulting Services
Siguenos en Facebook:
Moderador
  #18
Viejo 11/10/11, 02:19:53
coppel coppel is offline
saludos tengo un servidor windows server win 2008 baje el kernel 64 bits unicode los dos archivos del kernel el lib ws rtran tp y mi servidor levanta en amarillo alguna sugerencia?
  #19
Viejo 18/10/11, 15:11:38
caita caita is offline
Post
Hola amigo, me gustaria saber que tipo de configuracion de SO tienes solo especificas que tienes W7 de X64.\
Hay que tener en cuenta que W7 tiene el mismo kernel que Windows server 2008 R2 y no esta soportado para SAP release 7.01 con kernel de nivel menor al 69.
Al actualizar el kernel 7.01 a niveles mas arriba del 69 verifica que los archivos en las carpetas
* windows/system32
* usr/.../DVEBMGSXX
* usr/.../SYS/exe
asi con esto el SAPMMC si funciona.
te recomiendo usar una versión por lo menos que sea release 7.20 que ya esta soportada en SAP para Ws 2008 R2
Te recomiendo lo siguiente, si tienes una makina con minimo 4BG en ram debieras poner minimo unas 80GB en PAGINACIÓN a nivel de Sistema operativo.
lo mas facil que puedes hacer es leer la guia de isntalacion de SAP erp 6.0
* baja tu sistema operativo a windows server 2008
* instala JAVA j2sdk1.4.2_20-x64 o alguna version posterior en JAVA for BUSINESS
* define las variables de entorno JAVA_HOME y en path el java/bin
* coloca un archivo de paginacion minimo de 80GB
y pasa el pre-requisites checker del instalador de sap
cualquier inquietud no dudes de enviar MP
CAITA
  #20
Viejo 11/07/17, 21:43:06
javotool javotool is offline
disp+work.exe shutdown
Buenas Tardes.
Tengo un problema con mi instancia no puedo iniciar me marca el siguiente error disp+work.exe shutdown ya hice el trace y esto es lo que me despliega.
trc file: "dev_disp", trc level: 1, release: "740"
sysno 02
sid PRH
systemid 562 (PC with Windows NT)
relno 7400
patchlevel 0
patchno 80
intno 20020600
make multithreaded, Unicode, 64 bit, optimized
profile \\ServerPRO\sapmnt\PRH\SYS\profile\PRH_DVEBMGS02_ServerPRO
pid 1300
Tue Jul 11 16:25:28 2017
kernel runs with dp version 196000(ext=116000) (@(#) DPLIB-INT-VERSION-196000-UC)
length of sys_adm_ext is 500 bytes
***LOG Q00=> DpSapEnvInit, DPStart (02 1300) [dpInit.c 571]
shared lib "dw_xml.dll" version 80 successfully loaded
shared lib "dw_xtc.dll" version 80 successfully loaded
shared lib "dw_stl.dll" version 80 successfully loaded
shared lib "dw_gui.dll" version 80 successfully loaded
shared lib "dw_rndrt.dll" version 80 successfully loaded
shared lib "dw_abp.dll" version 80 successfully loaded
DpCheckMulticast: check of IP v4 multicast address o.k.
rdisp/softcancel_sequence : -> 0,5,-5
use internal message server connection to port 3903
rdisp/shutdown/disable_login : 0
rdisp/snapshot(CREATE): DP_CS_RESOURCES_EXHAUSTED
rdisp/snapshot(PERIOD):300 sec
rdisp/snapshot(LINES):10000 lines
DpCommonParamInit: rdisp/core_file_size = default --> no change
***LOG Q42=> DpSapEnvInit, DPStart () [dpInit.c 662]
MtxInit: 30000 0 0
DpIPCInit2: write dp-profile-values into sys_adm_ext
DpIPCInit2: start server >ServerPRO_PRH_02 <
DpShMCreate: alloate/attach shared memory (mode=CREATE)
DpShMCreate: sizeof(wp_adm) 28704 (1104)
DpShMCreate: sizeof(tm_adm) 51041136 (253936)
DpShMCreate: sizeof(ca_adm) 432000 (72)
DpCommTableSize: max/headSize/ftSize/tableSize=500/16/7464064/7583152
DpShMCreate: sizeof(comm_adm) 7583152 (14904)
DpShMCreate: sizeof(slock_adm) 0 (296)
DpShMCreate: sizeof(file_adm) 0 (80)
DpSockTableSize: max/headSize/ftSize/tableSize=500/16/520064/520080
DpShMCreate: sizeof(sock_adm) 520080 (1016)
DpShMCreate: sizeof(vmc_adm) 0 (3208)
DpShMCreate: sizeof(wall_adm) (ft=41664/fi=67472/hd=64/rec=192)
DpShMCreate: sizeof(amc_rec_adm) (ft=86464/fi=67472/hd=64/rec=408)
DpShMCreate: sizeof(websocket_adm) (ft=38464/hd=64/rec=176)
DpShMCreate: sizeof(j2ee_adm) 3936
DpShMCreate: SHM_DP_ADM_KEY (addr: 000000000AF50050, size: 60016880
DpShMCreate: allocated sys_adm at 000000000AF50250
DpShMCreate: allocated wp_adm_list at 000000000AF62080
DpShMCreate: allocated wp_adm at 000000000AF623A0
DpShMCreate: allocated tm_adm_list at 000000000AF695C0
DpShMCreate: allocated tm_adm at 000000000AF69800
DpShMCreate: allocated ca_adm at 000000000E016D70
DpShMCreate: allocated comm_adm at 000000000E0806F0
DpShMCreate: allocated sock_adm at 000000000E7BBEA0
DpShMCreate: allocated vmc_adm_list at 000000000E83B030
DpShMCreate: system runs without VMC
DpShMCreate: allocated gw_adm at 000000000E83B2D0
DpShMCreate: allocated j2ee_adm at 000000000E83B500
DpShMCreate: allocated ca_info at 000000000E83C660
DpShMCreate: allocated wall_adm (ft) at 000000000E83C8A0
DpShMCreate: allocated wall_adm (fi) at 000000000E846D60
DpShMCreate: allocated wall_adm (head) at 000000000E8576F0
DpShMCreate: allocated amc_rec_adm (ft) at 000000000E857930
DpShMCreate: allocated amc_rec_adm (fi) at 000000000E86CCF0
DpShMCreate: allocated amc_rec_adm (head) at 000000000E87D680
DpShMCreate: allocated websocket_adm (ft) at 000000000E87D8C0
DpShMCreate: allocated websocket_adm (head) at 000000000E887100
DpShMCreate: initialized 21 eyes
DpSysAdmIntInit: initialize sys_adm
DpSysAdmIntInit: created queue 0 (DispatcherQueue)
DpSysAdmIntInit: created queue 1 (GatewayQueue)
DpSysAdmIntInit: created queue 2 (IcmanQueue)
DpSysAdmIntInit: created queue 3 (StartServiceQueue)
DpSysAdmIntInit: created queue 4 (DpMonQueue)
Scheduler info
WP info
#dia = 10
#btc = 0
#standby = 0
#max = 26
General Scheduler info
preemptionInfo.isActive = true
preemptionInfo.timeslice = 500
preemptionInfo.checkLoad = true
Prio Class High
maxRuntime[RQ_Q_PRIO_HIGH] = 600 sec
maxRuntimeHalf[RQ_Q_PRIO_HIGH] = 300 sec
Prio Class Normal
maxRuntime[RQ_Q_PRIO_NORMAL] = 3600 sec
maxRuntimeHalf[RQ_Q_PRIO_NORMAL] = 1800 sec
maxTicketsForPrio[RQ_Q_PRIO_NORMAL] = 8
withPrioTickets[RQ_Q_PRIO_NORMAL] = true
Prio Class Low
maxRuntime[RQ_Q_PRIO_LOW] = infinite
maxRuntimeHalf[RQ_Q_PRIO_LOW] = infinite
maxTicketsForPrio[RQ_Q_PRIO_LOW] = 8
withPrioTickets[RQ_Q_PRIO_LOW] = true
Running requests[RQ_Q_PRIO_NORMAL] = 0
Running requests[RQ_Q_PRIO_LOW] = 0
DpCommAttachTable: attached comm table (header=000000000E0806F0/ft=000000000E080700/fi=000000000E79EB80)
DpSockAttachTable: attached sock table (header=000000000E7BBEA0/ft=000000000E7BBEB0)
MBUF state OFF
DpSockInitTable: init table for 500 entries
<ES> client 26 initializing ....
<ES> EsILock: use spinlock for locking
<ES> InitFreeList
<ES> block size is 4096 kByte.
<ES> Info: disclaim threshold = 0 MB
<ES> Info: disclaim coasting/alloc = 300 s
<ES> Info: disclaim coasting/free = 0 s
<ES> Info: blockdisclaimsize_KB = 0 KB
<ES> 2149 blocks reserved for free list.
ES initialized.
mm.dump: set maximum dump mem to 96 MB
rdisp/calculateLoadAverage : 1
= SSL Initialization platform tag=(ntamd64-msc16)
= (740_REL,Aug 1 2014,mt,ascii-uc,SAP_UC/size_t/void* = 16/64/64)
DIR_INSTANCE="E:\usr\sap\PRH\DVEBMGS02"
DIR_LIBRARY="E:\usr\sap\PRH\DVEBMGS02\exe"
= Initialization with _no_ default credentials
ssl/ssl_lib="E:\usr\sap\PRH\DVEBMGS02\exe\sapcrypto.dll"
profile param "ssl/ssl_lib" = "E:\usr\sap\PRH\DVEBMGS02\exe\sapcrypto.dll"
resulting Filename = "E:\usr\sap\PRH\DVEBMGS02\exe\sapcrypto.dll"
Tue Jul 11 16:25:29 2017
= found CommonCryptoLib (SAPCRYPTOLIB) Version 8.4.22 pl40 (Jul 23 2014) MT-safe
= current UserID: SERVERPRO\SAPServicePRH
= found SECUDIR environment variable
= using SECUDIR=E:\usr\sap\PRH\DVEBMGS02\sec
ssl/ciphersuites="193:HIGH:MEDIUM:+e3DES"
ssl/client_ciphersuites="192:HIGH:MEDIUM:+e3DES"
= Success -- SapCryptoLib SSL ready!
***LOG Q0K=> DpMsAttach, mscon ( ServerPRO) [dpMessageSer 1529]
MBUF state LOADING
DpStartStopMsg: send start message (myname is >ServerPRO_PRH_02 <)
DpStartStopMsg: start msg sent to message server o.k.
MPI: dynamic quotas disabled.
MPI init: pipes=4000 buffers=6395 reserved=1918 quota=10%
CreateProcess gwrd (PID:4656 HANDLE:932)
CreateProcess ICM (PID:4336 HANDLE:940)
create new work process W0 (PID:4368 HANDLE:956)
create new work process W1 (PID:2712 HANDLE:964)
create new work process W2 (PID:4824 HANDLE:968)
create new work process W3 (PID:3508 HANDLE:960)
create new work process W4 (PID:4828 HANDLE:972)
create new work process W5 (PID:4464 HANDLE:976)
create new work process W6 (PID:4480 HANDLE:980)
create new work process W7 (PID:4508 HANDLE:984)
create new work process W8 (PID:1128 HANDLE:988)
create new work process W9 (PID:3412 HANDLE:992)
create new work process W10 (PID:4816 HANDLE:996)
create new work process W11 (PID:4852 HANDLE:1000)
create new work process W12 (PID:4896 HANDLE:1004)
create new work process W13 (PID:4884 HANDLE:1008)
create new work process W14 (PID:4928 HANDLE:1012)
create new work process W15 (PID:4832 HANDLE:1016)
create new work process W16 (PID:4860 HANDLE:1020)
CCMS: Initialized monitoring segment of size 60000000.
CCMS: Initialized CCMS Headers in the shared monitoring segment.
CCMS: Checking Downtime Configuration of Monitoring Segment.
CCMS: AlMsUpload called by wp 1024.
Tue Jul 11 16:25:30 2017
CCMS: AlMsUpload successful for E:\usr\sap\PRH\DVEBMGS02\log\ALMTTREE.DAT (1429 MTEs).
Tue Jul 11 16:25:32 2017
CCMS: start to initalize 3.X shared alert area (first segment).
DpCheckPreemptionTicker: created thread for DpPremptionTicker
***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c 1369]
MBUF state ACTIVE
DpMBufTypeMod: MBUF component UP (event=MBUF_DPEVT_UP)
DpMsgProcess: 1 server in MBUF
DpMsCheckServices()
Tue Jul 11 16:25:36 2017
*** DpRqNoWpHandle: SHUTDOWN request from W10 received (reason=DP_SHUTDOWN_UNKNOWN_REASON) ***
********** SERVER SNAPSHOT 1 (Reason: Shutdown) - begin **********
Force W0 in state WP_NEW to dump stack
Force W1 in state WP_NEW to dump stack
Force W2 in state WP_NEW to dump stack
Force W3 in state WP_NEW to dump stack
Force W4 in state WP_NEW to dump stack
Force W5 in state WP_NEW to dump stack
Force W6 in state WP_NEW to dump stack
Force W7 in state WP_NEW to dump stack
Force W8 in state WP_NEW to dump stack
Force W9 in state WP_NEW to dump stack
Force W10 in state WP_NEW to dump stack
Force W11 in state WP_NEW to dump stack
Force W12 in state WP_NEW to dump stack
Force W13 in state WP_NEW to dump stack
Force W14 in state WP_NEW to dump stack
Force W15 in state WP_NEW to dump stack
Force W16 in state WP_NEW to dump stack
Scheduler info
WP info
DpNumberOfDiaWps: dia_wps 10, standby_wps 0
#dia = 10
#btc = 4
#standby = 0
#max = 26
Prio Class High
Prio Class Normal
Prio Class Low
Actual tickets in use
actTicketsInUseForPrio[RQ_Q_PRIO_NORMAL] = 0
actTicketsInUseForPrio[RQ_Q_PRIO_LOW] = 0
Queue Statistics Tue Jul 11 21:25:36 2017
Number of lost wakeup datagrams: 0
Max. number of queue elements : 14000
NOWP: 0 (peak 5, writeCount 30, readCount 30)
DIA : 3 (peak 3, writeCount 3, readCount 0)
UPD : 0 (peak 0, writeCount 0, readCount 0)
ENQ : 0 (peak 0, writeCount 0, readCount 0)
BTC : 0 (peak 0, writeCount 0, readCount 0)
SPO : 0 (peak 0, writeCount 0, readCount 0)
UP2 : 0 (peak 0, writeCount 0, readCount 0)
DISP: 0 (peak 5, writeCount 28, readCount 28)
GW : 0 (peak 0, writeCount 0, readCount 0)
IC : 0 (peak 1, writeCount 2, readCount 2)
LWP : 0 (peak 0, writeCount 0, readCount 0)
Session queue dump (high priority, 1 elements, peak 1):
-1 <- 31 < EmbryoQueue_DIA> -> -1
Session queue dump (normal priority, 1 elements, peak 1):
-1 <- 36 < T0_U2_M0> -> -1
Session queue dump (low priority, 0 elements, peak 0):
Dump of queue <EmbryoQueue_DIA> in slot 31 (2 requests, port=0):
-1 <- 4 (rq_id 3424, DIA, REQ_HANDLER_AUTOTH) -> 5
4 <- 5 (rq_id 3443, DIA, REQ_HANDLER_MSADM) -> -1
Dump of queue <T0_U2_M0> in slot 36 (1 requests, port=0):
-1 <- 1 (rq_id 3470, DIA, REQ_HANDLER_PLUGIN) -> -1
Infos about some special queues:
Queue <StartServiceQueue> in slot 3 (port=0) has no requests
Workprocess Table (long) Tue Jul 11 21:25:36 2017
Current snapshot id: 1
Number of preemptions : 0
|No |Pid |Type|State |Cause|Err|Prio|Sess-Key |Sess-Type|Locked|Sem|Time |Program |Cli|User |Action |Action-Info |
| 0|4368 |DIA |WP_NEW | | | | | | |10 | | | | | | |
| 1|2712 |DIA |WP_NEW | | | | | | |10 | | | | | | |
| 2|4824 |DIA |WP_NEW | | | | | | |10 | | | | | | |
| 3|3508 |DIA |WP_NEW | | | | | | |10 | | | | | | |
| 4|4828 |DIA |WP_NEW | | | | | | | | | | | | | |
| 5|4464 |DIA |WP_NEW | | | | | | |10 | | | | | | |
| 6|4480 |DIA |WP_NEW | | | | | |10,39 | | | | | | | |
| 7|4508 |DIA |WP_NEW | | | | | | |10 | | | | | | |
| 8|1128 |DIA |WP_NEW | | | | | | |10 | | | | | | |
| 9|3412 |DIA |WP_NEW | | | | | | |10 | | | | | | |
| 10|4816 |UPD |WP_NEW | | | | | | | | | | | | | |
| 11|4852 |BTC |WP_NEW | | | | | | |10 | | | | | | |
| 12|4896 |BTC |WP_NEW | | | | | | |10 | | | | | | |
| 13|4884 |BTC |WP_NEW | | | | | | |10 | | | | | | |
| 14|4928 |BTC |WP_NEW | | | | | | |10 | | | | | | |
| 15|4832 |SPO |WP_NEW | | | | | | |10 | | | | | | |
| 16|4860 |UP2 |WP_NEW | | | | | | |10 | | | | | | |
Session Table Tue Jul 11 21:25:36 2017
|Logon-Type |Sess-Key |Cli|User |Terminal |Time |WP |Program |Prio|Tasks|Application-Info |Tcode |ES-Mem(KB)|
|HTTP_NORMAL |T0_U2_M0 | | |192.168.0.151 |16:25:34| | |norm|1 | | |0 |
CA Blocks
0 INVALID -1
1 ca_blk slots of 6000 in use, 1 currently unowned (in request queues)
********** SERVER SNAPSHOT 1 (Reason: Shutdown) - end **********
Tue Jul 11 16:25:46 2017
DpTriggerSapSnapshot: start E:\usr\sap\PRH\DVEBMGS02\exe\sapcontrol.EXE
DpTriggerSapSnapshot: sapcontrol runs with pid 3932
***LOG Q41=> DpDumpInternalTables, () [dpxxdisp.c 3152]
DpHalt: shutdown server >ServerPRO_PRH_02 < (normal)
Tue Jul 11 16:25:49 2017
DpModState: change server state from STARTING to SHUTDOWN
DpHalt: stop work processes
Tue Jul 11 16:25:50 2017
DpHalt: stop gateway
DpHalt: stop icman
DpHalt: terminate gui connections
DpHalt: wait for end of work processes
DpHalt: waiting for termination of work processes ...
Tue Jul 11 16:25:51 2017
Tue Jul 11 16:25:52 2017
Tue Jul 11 16:25:53 2017
Tue Jul 11 16:25:54 2017
Tue Jul 11 16:25:55 2017
Tue Jul 11 16:25:56 2017
Tue Jul 11 16:25:57 2017
Tue Jul 11 16:25:58 2017
Tue Jul 11 16:25:59 2017
Tue Jul 11 16:26:00 2017
Tue Jul 11 16:26:01 2017
Tue Jul 11 16:26:02 2017
Tue Jul 11 16:26:07 2017
Tue Jul 11 16:26:08 2017
Tue Jul 11 16:26:09 2017
Tue Jul 11 16:26:10 2017
Tue Jul 11 16:26:11 2017
Tue Jul 11 16:26:12 2017
Tue Jul 11 16:26:13 2017
Tue Jul 11 16:26:14 2017
Tue Jul 11 16:26:15 2017
Tue Jul 11 16:26:16 2017
Tue Jul 11 16:26:17 2017
Tue Jul 11 16:26:18 2017
Tue Jul 11 16:26:19 2017
Tue Jul 11 16:26:20 2017
Tue Jul 11 16:26:21 2017
Tue Jul 11 16:26:22 2017
Tue Jul 11 16:26:23 2017
Tue Jul 11 16:26:24 2017
Tue Jul 11 16:26:25 2017
Tue Jul 11 16:26:26 2017
Tue Jul 11 16:26:27 2017
Tue Jul 11 16:26:28 2017
Tue Jul 11 16:26:29 2017
Tue Jul 11 16:26:30 2017
Tue Jul 11 16:26:31 2017
Tue Jul 11 16:26:32 2017
Tue Jul 11 16:26:33 2017
Tue Jul 11 16:26:34 2017
Tue Jul 11 16:26:35 2017
Tue Jul 11 16:26:36 2017
Tue Jul 11 16:26:37 2017
Tue Jul 11 16:26:38 2017
Tue Jul 11 16:26:39 2017
Tue Jul 11 16:26:40 2017
Tue Jul 11 16:26:41 2017
Tue Jul 11 16:26:42 2017
Tue Jul 11 16:26:43 2017
Tue Jul 11 16:26:44 2017
Tue Jul 11 16:26:45 2017
Tue Jul 11 16:26:46 2017
Tue Jul 11 16:26:47 2017
Tue Jul 11 16:26:48 2017
Tue Jul 11 16:26:49 2017
Tue Jul 11 16:26:50 2017
Tue Jul 11 16:26:51 2017
Tue Jul 11 16:26:52 2017
Tue Jul 11 16:26:53 2017
*** ERROR => DpHalt: W1 (pid 2712) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W2 (pid 4824) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W3 (pid 3508) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W4 (pid 4828) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W5 (pid 4464) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W6 (pid 4480) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W7 (pid 4508) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W8 (pid 1128) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W9 (pid 3412) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W11 (pid 4852) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W12 (pid 4896) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W13 (pid 4884) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W14 (pid 4928) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W15 (pid 4832) still alive ... [dpInit.c 3194]
*** ERROR => DpHalt: W16 (pid 4860) still alive ... [dpInit.c 3194]
Tue Jul 11 16:26:54 2017
DpHalt: wait for end of gateway
[DpProcDied] Process died (PID:4656 HANDLE:932 rc:0x0)
DpHalt: wait for end of icman
[DpProcDied] Process died (PID:4336 HANDLE:940 rc:0x0)
DpStartStopMsg: send stop message (myname is >ServerPRO_PRH_02 <)
DpStartStopMsg: stop msg sent to message server o.k.
Tue Jul 11 16:26:55 2017
DpHalt: sync with message server o.k.
DpHalt: detach from message server
***LOG Q0M=> DpMsDetach, ms_detach () [dpMessageSer 1885]
MBUF state OFF
DpMBufTypeMod: MBUF component DOWN (event=MBUF_DPEVT_DOWN)
DpHalt: cleanup EM
***LOG Q05=> DpHalt, DPStop ( 1300) [dpInit.c 3487]
Husos Horarios son GMT. La hora en este momento es 00:07:37.
