  #11
Viejo 07/01/09, 10:20:13
gfr gfr is offline
Adjunto la info que tengo que esta sacada de de la web de SAP.
Resumen: Los manuales son ADM940 (2006), ADM950(2003), ADM955 (xx) y ADM960 (2005), en sus ultimas versiones pero de estos a mi me falta el ADM955, si alguien lo tiene se agradece si me lo pueden pasar.
Gustavo
Certification Role
SAP Certified Technology Professional - Security with SAP NetWeaver 7.0
Level Professional
Focus Area Technology
Product Group Platform
Solution SAP NetWeaver
Description
This certification path will validate your capability as a well-trained technologist prepared to help your client or employer manage and execute key business processes. Armed with an understanding SAP system administration for SAP NetWeaver, you can implement this knowledge for your projects as a system administration specialist.
Certification Tests
P_ADM_SEC_70 - SAP Certified Technology Professional - Security with SAP NetWeaver 7.0
Predecessor Certification Roles
SAP Certified Technology Associate - System Administration (MAX DB) with SAP NetWeaver 7.0
SAP Certified Tech. Associate - System Admin (Oracle DB) with SAP NW 7.0
SAP Certified Technology Associate - System Administration (MS SQL DB) with SAP NetWeaver 7.0
SAP Certified Technology Associate - System Administration (DB2) with SAP NetWeaver 7.0
Follow-on Certification Roles
Education
View Related Curriculum Map
Want to learn more? Contact SAP for more information.
Certification Test
Booking Code
P_ADM_SEC_70
The certification test for "SAP Certified Technology Professional - Security with SAP NetWeaver 7.0" verifies the profound knowledge in the area of NetWeaver Secuity. This certificate proves that the candidate has an advanced understanding within this profile and is able to apply these skills practically and provide guidance in project implementation.
Software
Software components: SAP NetWeaver 7.0
Number of Questions
90
Duration
180 minutes
Notes
Professional Certifications are targeting profiles with minimum 4 - 7 years of experience. Besides the recommended education courses also practical job experience is required and tested.
Please note this certification may have a different passing score from previous or different certification exams. For multiple response items there is no partial credit given.
Please note that you are not allowed to use any reference materials during the certification test (no access to online documentation or to any SAP system). You will require Photo ID to be allowed to take the test.
Competency Areas
The following list helps you to identify the competency areas covered in this test. The percentage indicates the portion of the test dedicated to a particular competency area.
Way(s) to attain
Competency Importance Topic Primary Alternative Other
Conceptualize complex processes into customer prominent solutions. Based on professional application and advanced analysis qualification, customer business requirements can be recognized and transferred into concepts and blueprints of prominent customer solutions in
40% SSO-Concepts (Certificates, SAP Logon Tickets) ADM960
Business Continuity Planning
Security Management Practice
Security Infrastructure Architecture
Compliance
Enterprise SOA Security in SAP Systems ADM960
Build solutions by independently researching valid implementation options. Based on profound understanding and deep application skills, project requirements can be transferred into solid customer solutions in
40% Authorization groups f. tables, custom ABAP dev. auth. solutions ADM9x0
Implementing and reviewing SAP Authorization Concept ADM940
Integrating ABAP User-Management with Organizational Management ADM940
Central User Storage Techniques ADM940
Build Framework: Security Audit tools & Change Documents (SCDO) ADM950
Maxware, IDM and LDAP in a company environment
Accomplish and identify solutions for defined project tasks. Based on profound knowledge and basic understanding, identified tasks can be performed during system implementation, configuration, and testing in the areas of
20% GRC Suite (Compl.Calib.5.X, Role Expert, Virsa, Fire F, Maxware) ADM955
SAP UME administration and J2EE roles ADM200
Handling PFCG (check indicators, SU24, transport & upload roles) ADM940
--------------------------------------------------------------------------Configure and implement cryptographic technologies in SAP System ADM960
  #12
Viejo 08/01/09, 18:05:25
Danielecc Danielecc is offline
Certificacion
Yo encontre todos los manuales en internet, excepto el ADM955.
Tambien agradecería si alguien lo tiene, nos lo puede facilitar.
Saludos...
  #13
Viejo 10/01/09, 22:47:41
sapbasis.cat sapbasis.cat is offline
Certificación P_ADM_SEC_70
Buenas,
Yo también estoy en busca del manual ADM955 para la certificación P_ADM_SEC_70.
Si alguien lo tiene agradecería que lo enviaran (o el enlace de descarga) a
Les dejo un enlace de SAP donde podrán descargar un ejemplo del test de certificación. En la misma página hay otros ejemplos de varias certificaciones SAP:
  #14
Viejo 15/01/09, 12:07:18
Consulta
Esta certificacion no incluye el HR940 que es de seguridad tambien...
Alguien ha encontrado el adm955?
saludos...
  #15
Viejo 16/01/09, 15:24:31
gfr gfr is offline
Danielecc, como estas.
Por lo que esta en el post que realice y es oficial de la academia de SAP no incluye HR.
Si HR se maneja como hasta hace por lo menos 4 años, tienen todo un modelo especial de seguridad propia que se monta sobre la seguridad de SAP. y las certificaciones de HR incluyen en algun lado esta seguridad que te menciono.
Gustavo
  #16
Viejo 19/01/09, 15:07:11
jcmontejo jcmontejo is offline
Localización: Bogota - Colombia
saludo - inquietud Seguridad SAP
Saludo,
estoy interesado en realizar una academia en SAP, pero en la parte de seguridad y auditorias me podrian aconsejar cual se inclina mas a lo solicitado.
  #17
Viejo 17/02/09, 02:20:18
Thumbs up Alguien tiene una simulation examen de security
Saludo a todos,
Me podrian indicar si ya consiguieron el adm955 y si alguien tiene una simulation del examen paras la certificacion.
Gracias]
  #18
Viejo 23/07/09, 23:06:12
Maveriks Maveriks is offline
Como estas man?
Te dejo mi dire, agradecería muchisimo me pases los manuales, dado que estoy interesado en tirarme a la certificación.
Cualquier cosa, no dudes en contactarme.
Abrazo!
  #19
Viejo 29/10/09, 20:29:41
gfr gfr is offline
Hola, gracias a una colega encontre al manual ADM955 que muchos buscamos.
Gustavo
Gustavo.
Seguridad SAP R/3 y BI
  #20
Viejo 16/11/10, 05:08:42
272004 272004 is offline
Ayuda Compañeros
Hola!!
Me podrias colaborar con los siguientes manuales de seguridad sap
ADM940 ADM950 ADM960 ADM200 TZNWIM
Saludos a Todos.
Husos Horarios son GMT. La hora en este momento es 01:59:29.
