Viejo 13/06/08, 12:40:51
daniel_daniel1 daniel_daniel1 is offline
Problemas De Instalacion Minisap
BUENOS DIAS, TENGO UN PROBLEMA PARA INSTALAR EL MINISAP.
EL PROBLEMA ES EL SIGUIENTE:
EN MI CASA LO PUDE INSTALAR POR PRIMERA VES AL MINISAP NETWEAVER 7.0, PERO DESPUES FORMATIE MI PC Y DE AHI EN MAS NUNCA MAS LO PUDE VOLVER A INSTALAR, ME SALEN LOS SIGUIENTES LOGS DE ERRORES:
(Jun 11, 2008 8:17:41 PM), Install, com.sap.installshield.sdcstepswrapper.StepWrapperInstallFiles, err, An error occurred and product installation failed. Look at the log file C:\SAP\NSP\log.txt for details.
(Jun 11, 2008 8:17:41 PM), Install, com.sap.installshield.sdcstepswrapper.StepWrapperInstallFiles, err, ProductException: (error code = 200; message="Java error"; exception = [java.lang.Exception])
STACK_TRACE: 15
at com.sap.installshield.sdcstepswrapper.StepWrapperInstallFiles.execute(StepWrapperInstallFiles.java:254)
at com.sap.installshield.sdcstepswrapper.StepWrapperInstallFiles.executeAllSteps(StepWrapperInstallFiles.java:224)
at com.sap.installshield.sdcstepswrapper.StepWrapperInstallFiles.executeAllInstallationSteps(StepWrapperInstallFiles.java:177)
at com.sap.installshield.sdcstepswrapper.StepWrapperInstallFiles.install(StepWrapperInstallFiles.java:268)
at com.installshield.product.service.product.PureJavaProductServiceImpl.installProductAction(Unknown Source)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.getResultForProductAction(Unknown Source)
at com.installshield.product.service.product.InstallableObjectVisitor.visitComponent(Unknown Source)
at com.installshield.product.service.product.InstallableObjectVisitor.visitInstallableComponents(Unknown Source)
at com.installshield.product.service.product.InstallableObjectVisitor.visitProductBeans(Unknown Source)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.install(Unknown Source)
at com.installshield.product.service.product.PureJavaProductServiceImpl$Installer.execute(Unknown Source)
at com.installshield.wizard.service.AsynchronousOperation.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
(Jun 11, 2008 8:22:42 PM), Install, com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct, err, An error occurred and product uninstallation failed. Look at the log file C:\SAP\NSP\log.txt for details.
(Jun 11, 2008 8:22:42 PM), Install, com.sap.installshield.sdcstepswrapper.StepWrapperInstallFiles, err, ProductException: (error code = 200; message="Java error"; exception = [java.lang.Exception])
STACK_TRACE: 15
at com.sap.installshield.sdcstepswrapper.StepWrapperInstallFiles.executeAllUninstallationSteps(StepWrapperInstallFiles.java:192)
at com.sap.installshield.sdcstepswrapper.StepWrapperInstallFiles.uninstall(StepWrapperInstallFiles.java:313)
at com.installshield.product.service.product.PureJavaProductServiceImpl.uninstallProductAction(Unknown Source)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.processActionsFailed(Unknown Source)
SI ALGUIEN SABE POR QUE ES SE LOS AGRADECERIA MUCHISIMO, YA QUE ESTOY NECESITANTO INSTALARLO DE FORMA URGENTE; ANTE TODO MUCHAS GRACIAS POR SU TIEMPO.
Viejo 13/06/08, 14:24:45
h_rossi h_rossi is offline
Exclamation
Mira, por lo que veo ese error surge de la version de java que tenes instalada. En mi caso, me me instale un ECC 6.0 con ORACLE en una PC de mi casa y el JAVA que utilize es el 1.4.2_10 de IBM (Esto es en Linux), en Windows use el 1.4.2_12 de SUN.
Que version de Java tenes?, si tenes la 1.5.algo, esa no esta soportada.
Viejo 13/06/08, 14:50:59
problema de instalacion minisap
que tal, probe con la vercion 1.5 y con la 1.4 y con las 2 me dio los mismos errores de instalacion.
ahora estoy descargando la vercion que vos me decis, voy hacer la prueba y esperemos que sirva.
muchas gracias por tu ayuda.
cualquier otro aporte me va a ser de mucha utilidad.
Viejo 13/06/08, 14:56:11
Exclamation
Fijate sea _09 en adelante, osea, 1.4.2_09 ó _10 ó _12, etc.
Otro punto es, declara las variables de java
JAVA_HOME=c:\j2sdk_xxxxxx. Donde tengas los binarios de java, javac, javaw, javadoc, javah, etc
Viejo 13/06/08, 15:06:46
problemas instalacion minisap
que tal, eso si no te entendi, podrias esplicarme mejor? en donde encuentro la entrada de java que decis y que es lo que debo de ponerle.
muchas gracias por tu tiempo.
Viejo 13/06/08, 17:57:01
Exclamation
La instalación la estas haciendo sobre Windows supongo. Entonces en las variables de entorno debes agregar la variable JAVA_HOME y adicionar la ruta en donde se encuentra la instalacion de JAVA
Viejo 17/06/08, 12:50:26
muchas gracias pòr tu info h_rosi, ya pude instalar el minisap en una pc, lo unico que no tenia nada que ver lo que vos me dijistes, es mas lo instale en una pc que tiene el java vercion 1.6 y quedo joya!!!! El error de java en realidad no tiene nada que ver con java en si, sino que como el instalador esta basado en java y eso es lo que pincha, creo que por eso dice "java error". desde ya muchas gracias por haberte molestado en contestarme!!!!
Husos Horarios son GMT. La hora en este momento es 17:29:10.
