Viejo 12/09/07, 15:13:14
Avatar de YOKKER
YOKKER YOKKER is offline
report?? estructuras??? PPOME??
Una pregunta... alguien conoce un report o algo para pasar de un mandante a otro,.... o de una maquina a otra,... de desarrollo aproductivo la estructura de la ppome??????????
Muchas gracias
Viejo 13/09/07, 11:04:14
aurelio.redondo aurelio.redondo is offline
Thumbs up jajajajajajaj
SE38 PROGRAMA: (report RHMOVE30) EJecutar
Editor AVAP
Requisitos previos: Variante de plan activa en 100 y 200 debe ser la misma (01 activa o la que se traslade)
Confirmar en spro, variante de plan activa.
transportar sin test ni bloqueo, con opción de enlace A003 "pertence", para que "es titular" no vaya y no lleve personas.
COPIAR UNA PPOME ya creada DESDE 100 AL 200
EJEMPLO DE UNIDAD ORGANIZATIVA QUE SE PASA DEL 200 AL 100
12.09.2007 Salida dinámica de lista 1
Var.plan 10 Vía eval. A003
| Transport|Löschen|TO| ID obj.|Sigla |Inicio |Fin |Status|
| X | |S |50000012|Pos.nueva|12.09.2007|31.12.9999|activo|
| X | |O |50000011|SPAD |12.09.2007|31.12.9999|activo|
| X | |S |50000015|Pos.nueva|12.09.2007|31.12.9999|activo|
| X | |O |50000013|UNIDAD 1 |12.09.2007|31.12.9999|activo|
| X | |S |50000016|Pos.nueva|12.09.2007|31.12.9999|activo|
| X | |O |50000014|UNIDAD 2.|12.09.2007|31.12.9999|activo|
Additional key words
Activity groups, Workflow, Tasks, Activation, Organizational management, Client copy
Cause and prerequisites
PD objects are written to the so-called transport plan version during the transport. Only after you have executed the transport can they be transferred to the "active plan version" (activation). This procedure is required due to the complex time logic of the PD objects.
Basically, PD objects that are not entered via the automatic transport connection should be transported via a manual transport connection (report RHMOVE30).
After a regular transport, the activation is started automatically.
In Transaction SCC1 there is an error from Release 3.0D up to and including 3.1H due to which automatic activation is sometimes not started (see Note 87787).
If you copy transport requests with SCC1, you must be aware that links to objects which are not PD objects (for example R/3 users) can only be successfully transported if these objects already exist in the target client.
If after carrying out transports you experience problems in the source client (with transports in a system), refer to Note 89608.
Solution
Read Note 87787. If the methods are still not called correctly, proceed as follows: after the transport, start report RHWFACTI in the target client. This has the correction number for the transport carried out as an optional parameter and also optional (as of Release 3.1H) is the object type.
If 'Test mode' is marked, the objects to be activated are only displayed, otherwise, they are activated.
With regard to report RHWFACTI also read the Related Note 84199 (Release 3.0D to 3.1H).
Source code corrections
Header Data
Release Status: Released for Customer
Released on: 04.12.1997 23:00:00
Priority: Recommendations/additional info
Category: Consulting
Primary Component: BC-BMT-OM Organizational Management
Secondary Components: BC-CTS-CCO Client Copy
BC-CTS Change and Transport System
Viejo 13/09/07, 11:09:38
Avatar de YOKKER
gracias
Muchisimass gracias, justo lo que andaba buscando!!!,
Viejo 31/03/11, 13:07:07
Anuschi Anuschi is offline
Transportar de DEV a PRD Posiciones de la PPOME
Hola a todos,
Quisiera saber si hay alguna transaccion o programa para transportar desde desarrollo a productivo la PPOME con Unidades Organizativas y Posiciones?
Muchas Gracias,.
Anus
Viejo 31/03/11, 14:15:18
vicosap vicosap is offline
Lo que necesitas es lo que viene arriba en este mismo post el programa RHMOVE30.
Husos Horarios son GMT. La hora en este momento es 03:34:42.
