Viejo 03/02/12, 08:48:24
angel428041 angel428041 is offline
Exclamation Dump Data_length_0 "cx_sy_range_out_of_bounds"
Buenas compañeros, me esta apareciendo este DUMP, alguien me podría dar una mano ?, he estado buscando notas para solucionarlo pero no he podido encontrar una, les agradezco desde ya quien me pueda dar alguna información.
Errores tiempo ejec. DATA_LENGTH_0
Excepción CX_SY_RANGE_OUT_OF_BOUNDS
Fecha y hora 03.02.2012 04:01:06
Texto breve
Invalid partial field access: Length 0
¿Qué ha sucedido?
Error in the ABAP Application Program
The current ABAP program "SAPLSO03" had to be terminated because it has come across a statement that unfortunately cannot be executed.
¿Qué puede hacer?
Note down which actions and inputs caused the error.
To process the problem further, contact you SAP system administrator.
Using Transaction ST22 for ABAP Dump Analysis, you can look at and manage termination messages, and you can also keep them for a long time.
Anál.errores
An exception occurred that is explained in detail below.
The exception, which is assigned to class 'CX_SY_RANGE_OUT_OF_BOUNDS', was not caught in procedure "CHECK_DOUBLE_BYTE_CHAR" "(FORM)", nor was it propagated by a RAISING clause.
Since the caller of the procedure could not have anticipated that the exception would occur, the current program is terminated.
The reason for the exception is:
In the executed program "SAPLSO03", the system attempted to access the field "LV_LINE" using the length 0.
However, a partial field access with the length specification 0 is not allowed.
Notas para corregir errores
Use a positive length specification if a part of the field "LV_LINE" is to be accessed.
If the error occurred in your own ABAP program or in an SAP program you modified, try to remove the error.
If the error occures in a non-modified SAP program, you may be able to find an interim solution in an SAP Note.
If you have access to SAP Notes, carry out a search with the following keywords:
"DATA_LENGTH_0" "CX_SY_RANGE_OUT_OF_BOUNDS"
"SAPLSO03" or "LSO03F03"
Entorno sistema
SAP-Release 701
SAP kernel....... 701
created (date)... "Jul 3 2011 22:11:09"
create on........ "Linux GNU SLES-9 ppc64 cc4.1.2"
Database version. "SQLDBC 7.6.6.020 CL 243176 "
Patch level. 150
Patch text.. " "
Database............. "MaxDB 7.6, MaxDB 7.7, MaxDB 7.8"
SAP database version. 701
Operating system..... "Linux 2.6"
Memory consumption
Roll.... 16192
EM...... 20949240
Heap.... 0
Page.... 172032
MM Used. 3367608
MM Free. 819640
Usuario y transacción
Transaction......... "SBWP "
Transactions ID..... "4F297872C2B6155CE1000000AC10017D"
Program............. "SAPLSO03"
Screen.............. "SAPLSO03 0300"
Screen line......... 2
Info posición de cancelación
Termination occurred in the ABAP program "SAPLSO03" – in "CHECK_DOUBLE_BYTE_CHAR".
The main program was "SAPLSO33 ".
In the source code you have the termination point in line 461 of the (Include) program "LSO03F03".
The termination is caused because exception "CX_SY_RANGE_OUT_OF_BOUNDS" occurred in procedure "CHECK_DOUBLE_BYTE_CHAR" "(FORM)", but it was neither handled locally nor declared in the RAISING clause of its signature.
The procedure is in program "SAPLSO03 "; its source code begins in line 450 of the (Include program "LSO03F03 ".
Detalle código fuente
Lín. Txt.fte.
431 write: text-122. "Page
432 pos_page_no = sy-linsz - 3.
433 position pos_page_no.
434 write: sy-pagno.
435 * ULINE. "yxu090197
436 write: / output_str. "yxu090197
437 write: / . "yxu090197
438 if sy-pagno <> 1.
439 skip.
440 endif.
441 endform.
442 *&---------------------------------------------------------------------*
443 *& Form CHECK_DOUBLE_BYTE_CHAR
444 *&---------------------------------------------------------------------*
445 * text
446 *----------------------------------------------------------------------*
447 * -->P_OBJCONT text
448 * -->P_DOUBLE_BYTE text
449 *----------------------------------------------------------------------*
450 form CHECK_DOUBLE_BYTE_CHAR tables objcont
451 changing linesz.
452
453 data lv_line type soli.
454 data lv_len type i.
455 data lv_string type string.
456 data lv_offset type i.
457 data lv_mod type i.
458
459 loop at objcont[] into lv_line.
460 lv_offset = lv_line(3).
>>>> lv_string = lv_line+5(lv_offset).
462 lv_len = cl_abap_list_utilities=>dynamic_output_length( lv_string ).
463 if lv_len > linesz.
464 lv_mod = linesz mod 2.
465 if lv_mod = 0.
466 linesz = linesz / 2.
467 else.
468 linesz = ( linesz - 1 ) / 2.
469 endif.
470 exit.
471 endif.
472 endloop.
473
474 endform. " CHECK_DOUBLE_BYTE_CHAR
Viejo 13/02/12, 18:08:28
Avatar de johangonz
Ya vi que te ayudaron en otro foro, fuera importante actualizar las respuestas para tener los datos aca:
Johan González
CEO
NW Consulting Services
Siguenos en Facebook:
Moderador
Viejo 13/02/12, 18:31:24
Smile
Para quienes tienen este mismo problema ..
Creo que para resolver este problema es necesario aplicar la nota 1621983.
Eduardo Rezende
Me funciono sin problemas.
Husos Horarios son GMT. La hora en este momento es 04:06:46.
