Regresar   MUNDOSAP > DESARROLLO > Trucos, Consejos y Advertencias
Viejo 22/01/07, 14:25:45
alfredodegano alfredodegano is offline
Exclamation Exceptions
Hay Me Podria Pasar Algunas Clases De Errores Para Poder Utilidarlas En La Sentencia Catch.
Viejo 23/01/07, 08:17:42
Txelian Txelian is offline
Localización: Madrid
Thumbs up Listado
Aqui tienes el listado, espero que te sirva...
ADDF_INT_OVERFLOW
Overflow at addition, type I ( ADD ... UNTIL / ADD ... FROM ... TO)
Exception class: CX_SY_ARITHMETIC_OVERFLOW
ASSIGN_CASTING_ILLEGAL_CAST
The components of the source field type and the target type which are strings, tables, or references do not have exactly the same offset and type.
Exception class: CX_SY_ASSIGN_CAST_ILLEGAL_CAST
ASSIGN_CASTING_UNKNOWN_TYPE
The type specified at runtime is unknown.
Exception class: CX_SY_ASSIGN_CAST_UNKNOWN_TYPE
ASSIGN_FIELD_NOT_IN_RANGE
The field is not within the RANGE specified.
Exception class: CX_SY_ASSIGN_OUT_OF_RANGE
BCD_FIELD_OVERFLOW
Overflow at conversion / arithmetic operation (type P, with specified length)
Exception class: CX_SY_CONVERSION_OVERFLOW
BCD_OVERFLOW
Overflow at conversion / arithmetic operation (type P)
BCD_ZERODIVIDE
Division by 0 (type P)
Exception class: CX_SY_ZERODIVIDE
COMPUTE_ACOS_DOMAIN
Invalid call of the mathematical function ACOS
Exception class: CX_SY_ARG_OUT_OF_DOMAIN
COMPUTE_ASIN_DOMAIN
Invalid call of the mathematical function ASIN
COMPUTE_ATAN_DOMAIN
Invalid call of the mathematical function ATAN
COMPUTE_BCD_OVERFLOW
Overflow at arithmetic operation (all operands of type P)
COMPUTE_COSH_DOMAIN
Invalid call of the mathematical function COSH
COMPUTE_COSH_OVERFLOW
Overflow at mathematical function COSH
COMPUTE_COS_DOMAIN
COMPUTE_COS_LOSS
Inaccurate result of function COS
Exception class: CX_SY_PRECISION_LOSS
COMPUTE_EXP_DOMAIN
Invalid call of the mathematical function EXP
COMPUTE_EXP_RANGE
Overflow or underflow at mathematical function EXP
COMPUTE_FLOAT_DIV_OVERFLOW
Overflow at division (type F)
COMPUTE_FLOAT_MINUS_OVERFLOW
Overflow at subtraction (type F)
COMPUTE_FLOAT_PLUS_OVERFLOW
Overflow at addition (type F)
COMPUTE_FLOAT_TIMES_OVERFLOW
Overflow at multiplication (type F)
COMPUTE_FLOAT_ZERODIVIDE
Division by 0 (type F)
COMPUTE_INT_ABS_OVERFLOW
Integer overflow while calculating the absolute value
COMPUTE_INT_DIV_OVERFLOW
Integer overflow at division
COMPUTE_INT_MINUS_OVERFLOW
Integer overflow at subtraction
COMPUTE_INT_PLUS_OVERFLOW
Integer overflow at addition
COMPUTE_INT_TIMES_OVERFLOW
Integer overflow at multiplication
COMPUTE_INT_ZERODIVIDE
Division by 0 (type I)
COMPUTE_LOG10_ERROR
Invalid call of the mathematical function LOG10
Exception classes: CX_SY_ARITHMETIC_OVERFLOW, CX_SY_ARG_OUT_OF_DOMAIN
COMPUTE_LOG_ERROR
COMPUTE_MATH_DOMAIN
Invalid call of a mathematical function
COMPUTE_MATH_ERROR
Error performing a mathematical function
Exception class: None since this runtime error can no longer be caught
COMPUTE_MATH_LOSS
Inaccurate result of a mathematical function
COMPUTE_MATH_OVERFLOW
Overflow at a mathematical function
COMPUTE_MATH_UNDERFLOW
Underflow at a mathematical function
Exception class: None since exception no longer occurs
COMPUTE_POW_DOMAIN
Invalid argument when using powers
COMPUTE_POW_RANGE
Overflow or underflow when using powers
COMPUTE_SINH_DOMAIN
Invalid call of the mathematical function SINH
COMPUTE_SINH_OVERFLOW
Overflow at mathematical function SINH
COMPUTE_SIN_DOMAIN
COMPUTE_SIN_LOSS
Inaccurate result of the function SIN
COMPUTE_SQRT_DOMAIN
Invalid call of the mathematical function SQRT
COMPUTE_TANH_DOMAIN
Invalid call of the mathematical function TANH
COMPUTE_TAN_DOMAIN
COMPUTE_TAN_LOSS
Inaccurate result of the function TAN
CONNE_IMPORT_WRONG_COMP_DECS
Import error; a component of a structured type in the dataset has wrong decimal places
Exception class: CX_SY_IMPORT_MISMATCH_ERROR
CONNE_IMPORT_WRONG_COMP_LENG
Import error; a component of a structured type in the dataset has the wrong length
CONNE_IMPORT_WRONG_COMP_TYPE
Import error; a component of a structured type in the dataset has the wrong type
CONNE_IMPORT_WRONG_FIELD_DECS
Import error; a field in the dataset has wrong decimal places
CONNE_IMPORT_WRONG_FIELD_LENG
Import error; a field in the dataset has the wrong length
CONNE_IMPORT_WRONG_FIELD_TYPE
Import error; a field in the dataset has the wrong type
CONNE_IMPORT_WRONG_OBJECT_TYPE
Import error; type conflict between simple and structured data types
CONNE_IMPORT_WRONG_STRUCTURE
Import error; type conflict between structured objects
CONVT_CODEPAGE
Character set conversion not possible for one or more characters
Exception class: CX_SY_CONVERSION_CODEPAGE
CONVT_CODEPAGE_INIT
Conversion of texts between code pages not supported
Exception class: CX_SY_CODEPAGE_CONVERTER_INIT
CONVT_NO_NUMBER
Value to be converted cannot be interpreted as a number
Exception class: CX_SY_CONVERSION_NO_NUMBER
CONVT_OVERFLOW
Overflow at conversion (all types, not type P)
CREATE_DATA_ILLEGAL_DECIMALS
Invalid value for the addition DECIMALS
Exception class: CX_SY_CREATE_DATA_ERROR
CREATE_DATA_ILLEGAL_INIT_SIZE
Invalid value for the addition INITIAL SIZE
CREATE_DATA_ILLEGAL_LENGTH
Invalid value for the addition LENGTH
CREATE_DATA_LEN_NOT_ALLOWED
The addition LENGTH was used for a type other than C, N, X, or P
CREATE_DATA_NOT_ALLOWED_TYPE
The type specified dynamically in the addition TYPE is not typed completely.
CREATE_DATA_UNKNOWN_TYPE
The type specified in the addition TYPE is unknown.
CREATE_OBJECT_CLASS_ABSTRACT
You attempted to instantiate an abstract class.
Exception class: CX_SY_CREATE_OBJECT_ERROR
CREATE_OBJECT_CLASS_NOT_FOUND
The class specified in the dynamic CREATE OBJECT was not found.
CREATE_OBJECT_CREATE_PRIVATE
You attempted to create an object of a class defined as 'CREATE PRIVATE'.
CREATE_OBJECT_CREATE_PROTECTED
You attempted to create an object of a class defined as 'CREATE PROTECTED'.
DATA_LENGTH_NEGATIVE
Invalid subfield access: Length negative
Exception class: CX_SY_RANGE_OUT_OF_BOUNDS
DATA_LENGTH_0
Invalid subfield access: Length 0
DATA_LENGTH_TOO_LARGE
Invalid subfield access: Length too large
DATA_OFFSET_NEGATIVE
Invalid subfield access: Offset negative
DATA_OFFSET_LENGTH_TOO_LARGE
Invalid subfield access: Offset + length too large
DATA_OFFSET_LENGTH_NOT_ALLOWED
Invalid subfield access: Inadequate type
Exception class: CX_SY_OFFSET_NOT_ALLOWED
DATASET_CANT_CLOSE
File could not be closed; there might be no more space in the file system.
Exception class: CX_SY_FILE_CLOSE
DATASET_CANT_OPEN
File cannot be opened
Exception class: CX_SY_FILE_OPEN
DATASET_NO_PIPE
OPEN DATASET with the addition FILTER is not supported on the current operating system.
Exception class: CX_SY_PIPES_NOT_SUPPORTED
DATASET_NO_POSITION
Access to current read/write position of file not possible
Exception class: CX_SY_FILE_POSITION
DATASET_NOT_OPEN
File not open
Exception class: CX_SY_FILE_OPEN_MODE
DATASET_OFFSET_TO_LARGE
Offset specified exceeds the system limit
DATASET_PIPE_CLOSED
Pipe for file closed
Exception class: CX_SY_PIPE_REOPEN
DATASET_READ_ERROR
Error reading a file
Exception class: CX_SY_FILE_IO
DATASET_READ_ONLY
File opened in read-only mode
DATASET_SEEK_ERROR
Error positioning in a file
DATASET_TOO_MANY_FILES
Maximum number of open files exceeded
Exception class: CX_SY_TOO_MANY_FILES
DATASET_WRITE_ERROR
Error writing a file
DYN_CALL_METH_CLASSCONSTRUCTOR
You attempted to call the class constructor.
Exception class: CX_SY_DYN_CALL_ILLEGAL_METHOD
DYN_CALL_METH_CLASS_ABSTRACT
You attempted to call an abstract method.
Exception class: CX_SY_DYN_CALL_ILLEGAL_CLASS
DYN_CALL_METH_CLASS_NOT_FOUND
You attempted to call a method of a class that does not exist.
DYN_CALL_METH_CONSTRUCTOR
You attempted to call the instance constructor.
DYN_CALL_METH_EXCP_NOT_FOUND
You attempted to catch an unknown exception.
Exception class: CX_SY_DYN_CALL_EXCP_NOT_FOUND
DYN_CALL_METH_NOT_FOUND
You attempted to call an unknown method.
DYN_CALL_METH_NOT_IMPLEMENTED
You attempted to call a method not yet implemented.
DYN_CALL_METH_NO_CLASS_METHOD
You attempted to call an instance method through a class.
DYN_CALL_METH_PARAM_KIND
You attempted to pass a parameter with a wrong parameter type.
Exception class: CX_SY_DYN_CALL_ILLEGAL_TYPE
DYN_CALL_METH_PARAM_LITL_MOVE
You attempted to pass a constant actual parameter to a formal EXPORTING, CHANGING, or RETURNING parameter.
DYN_CALL_METH_PARAM_MISSING
A required parameter was not filled.
Exception class: CX_SY_DYN_CALL_PARAM_MISSING
DYN_CALL_METH_PARAM_NOT_FOUND
You attempted to pass an unknown parameter.
Exception class: CX_SY_DYN_CALL_PARAM_NOT_FOUND
DYN_CALL_METH_PARAM_TAB_TYPE
You attempted to pass a parameter with a wrong table type.
DYN_CALL_METH_PARAM_TYPE
You attempted to pass a parameter with a wrong type.
DYN_CALL_METH_PARREF_INITIAL
An initial data reference was passed for a required parameter.
DYN_CALL_METH_PRIVATE
You attempted to call a private method outside.
DYN_CALL_METH_PROTECTED
You attempted to call a protected method outside.
DYN_CALL_METH_REF_IS_INITIAL
You attempted to call a method to an initial reference.
Exception class: CX_SY_REF_IS_INITIAL
EXPORT_BUFFER_NO_MEMORY
The EXPORT data cluster is too large for the application buffer.
Exception class: CX_SY_EXPORT_BUFFER_NO_MEMORY
EXPORT_DATASET_CANNOT_OPEN
The IMPORT/EXPORT statement was unable to open the file.
EXPORT_DATASET_WRITE_ERROR
The Export statement could not write the file.
GENERATE_SUBPOOL_DIR_FULL
The system is unable to generate another temporary subroutine pool.
Exception class: CX_SY_GENERATE_SUBPOOL_FULL
IMPORT_ALIGNMENT_MISMATCH
Import error; identical sequence of components but with type conflict or with different integration into structured data types
IMPORT_TYPE_MISMATCH
Import error; only at IMPORT...FROM MEMORY | FROM SHARED BUFFER...
Exception class: None since this runtime error can not longer be caught
IMPORT_WRONG_END_POS
Import error; dataset has a different length.
MOVE_CAST_ERROR
Type conflict assigning between object and/or interface references (only MOVE...?TO... or operator ?=)
Exception class: CX_SY_MOVE_CAST_ERROR
OPEN_DATASET_NO_AUTHORITY
No authorization to access a file
Exception class: CX_SY_FILE_AUTHORITY
OPEN_PIPE_NO_AUTHORITY
No authorization to access a file (OPEN DATASET...FILTER...)
PERFORM_PROGRAM_NAME_TOO_LONG
Invalid program name in the PERFORM statement
Exception class: CX_SY_PROGRAM_NOT_FOUND
REFI_WRONG_SECTION
Wrong offset/length specification in the REPLACE statement
REPLACE_INFINITE_LOOP
SECTION of length 0 in the REPLACE statement
Exception class: CX_SY_REPLACE_INFINITE_LOOP
RMC_COMMUNICATION_FAILURE
Communication error during Remote Method Call
Exception class: CX_SY_RMC_COMM_FAILURE
RMC_INVALID_STATUS
State error during Remote Method Call
Exception class: CX_SY_RMC_INVALID_STATUS
RMC_SYSTEM_FAILURE
System error during Remote Method Call
Exception class: CX_SY_RMC_SYSTEM_FAILURE
STRING_LENGTH_NEGATIVE
Invalid access with negative length to a string
STRING_LENGTH_TOO_LARGE
Invalid access to a string (length too large)
STRING_OFFSET_NEGATIVE
Invalid access with negative offset to a string
STRING_OFFSET_TOO_LARGE
Invalid access to a string (offset too large)
STRING_OFFSET_LENGTH_TOO_LARGE
Invalid access to a string (offset + length too large)
Exception class: CX_SY_LOCALIZATION_ERROR
TEXTENV_CODEPAGE_NOT_ALLOWED
Character set not released in the system (SET LOCALE...)
TEXTENV_INVALID
Error setting the text environment (SET LOCALE...)
TEXTENV_KEY_INVALID
In SET LOCALE...: Value disallowed by the system in the additions LANGUAGE, COUNTRY, or MODIFIER
Código HTML está On
Husos Horarios son GMT. La hora en este momento es 21:12:30.
