Error al instalar DB2 7.2 EE en HP UX 11i v23
HOla amigos
Tengo un problema, estoy empezando a instalar el SOL MAN version 4.0 y me dice la guía que instale el motor de la base de datos , entonces al momento de instalar tengo este error: 02/21/08 12:58:38 MST BEGIN install AGENT SESSION (pid=13871) (jobid=epi-sap--0037) * Agent session started for user "root@epi-sap-". (pid=13871) * Beginning Analysis Phase. * Source: epi-sap-:/var/SWINC/db27/UNIX/HP11_64/DBSW_EE/db2/ * Target: epi-sap-:/ * Target logfile: epi-sap-:/var/adm/sw/swagent.log * Reading source for product information. NOTE: The filesystems in the filesystem table will not be checked against those currently mounted because the "mount_all_filesystems" option is set to "false". WARNING: The product "DB2V7CAE,r=7.1.1.40" is not compatible with this system's architecture or operating system. If the OS has been updated since this product was installed, a newer version should be installed if available. * This product will still be included in the task because the "allow_incompatible" option is set to "true". * Reading source for file information. The prerequisite "OS-Core.CMDS-AUX,r>=B.11.00,a=HP-UX_?.11.??_32/64,v=HP" for fileset "DB2V7CAE.client,r=7.1.1.40" cannot be successfully resolved. The prerequisite "OS-Core.CMDS-MIN,r>=B.11.00,a=HP-UX_?.11.??_32/64,v=HP" for fileset "DB2V7CAE.client,r=7.1.1.40" cannot be successfully resolved. The prerequisite "SOE.SOE,r>=B.11.00,a=HP-UX_?.11.??_32/64,v=HP" for fileset "DB2V7CAE.client,r=7.1.1.40" cannot be successfully resolved. ERROR: The dependencies for fileset "DB2V7CAE.client,r=7.1.1.40" cannot be resolved (see previous lines). You must resolve the above dependencies before operating on this fileset or change the "enforce_dependencies" option to "false". * Executing preDSA command. * Summary of Analysis Phase: ERROR: Exclude DB2V7CAE.client,r=7.1.1.40 ERROR: 1 of 1 filesets had Errors. ERROR: The Analysis Phase had errors and warnings. See the above output for details. ======= 02/21/08 12:58:38 MST END install AGENT SESSION (Cancelled) (pid=13871) (jobid=epi-sap--0037) El instalador es de los cds que SAP nos proporcionó no se cual es el error o como puedo solucionarlo, o si es la versión si alguien me puede ayudar indicando cual es la correcta Muchas gracias por las ayuda que me puedan dar SAludos DANny |
Desplegado | |
