Viejo 13/02/11, 02:02:20
Avatar de yakuzaruso
yakuzaruso yakuzaruso is offline
Question Error al instalar SAP IDES
Hola gente, les queria consultar a ver si a alguien le paso eso.
Antes habia instalado SAP IDES varias veces y no tuve ningun problema hasta hace un par de dias cuando intento instalar, hasta instalar Oracle y instalar kernel de sap , todo bien, al momento de crear instancia de base de datos de sao y importar archivos de export, me da ese error y no entiendo porque ya que antes nunca me paso.
Le paso mensaje de error.
Lo probe tanto en Win Xp como en Win 2003 Server y pasa lo mismos.
Agradecere algunos opiniones y consejos.
Gracias.
INFO 2011-02-12 23:46:31
Processing of host operation t_HostInfo_SHARED succeeded.
INFO 2011-02-12 23:46:38
The 'saploc' share exists at directory 'C:\usr\sap'. Choosing drive C: as SAP System drive.
INFO[E] 2011-02-12 23:47:09
Account group="sap\SAP_LDAP" does not exist. <#1>
INFO[E] 2011-02-12 23:47:27
Account group="sap\dbar1ctl" does not exist. <#1>
INFO 2011-02-12 23:49:02
Copying file C:/SAP INSTALACION/SAP/EXPORT_DB/disk1/EXPORT1/DB/ORA/DBSIZE.XML to: DBSIZE.XML.
Creating file C:\SAPinst ORACLE SAPINST\DBSIZE.XML.
Copying file system node C:\SAP INSTALACION\SAP\EXPORT_DB\disk1\EXPORT1/DB/ORA/DBSIZE.XML with type NODE to DBSIZE.XML succeeded.
Processing of all file system node operations of table tORA_filecopy succeeded.
Copying file C:/SAP INSTALACION/SAP/EXPORT_DB/disk1/EXPORT1/DB/DDLORA.TPL to: DDLORA.TPL.
Creating file C:\SAPinst ORACLE SAPINST\DDLORA.TPL.
Copying file system node C:\SAP INSTALACION\SAP\EXPORT_DB\disk1\EXPORT1/DB/DDLORA.TPL with type NODE to DDLORA.TPL succeeded.
INFO 2011-02-12 23:49:07
Moving file C:/SAPinst ORACLE SAPINST/DDLORA.TPL to: orig_ddl_ora_tmp.tpl.
Moving file C:/SAPinst ORACLE SAPINST/changed_ddl_ora_tmp.tpl to: DDLORA.TPL.
Removing file C:/SAPinst ORACLE SAPINST/orig_ddl_ora_tmp.tpl.
ERROR 2011-02-12 23:51:01
MSC-01003 ESyException: ESAPinstException: error text undefined
FJS-00012 Error when executing script.
FCO-00011 The step fillR3loadPackageTable with step key SAPSYSTEM|ind|ind|ind|ind|ind|0|SAPComponent|ind|ind|ind|ind|ind|0|DatabaseLoad|ind|ind|ind|ind|ind|0|fillR3loadPackageTable executed with status ERROR.
FSL-02015 Node C:\SAP\DATA does not exist.
Este es el error que me da.
Husos Horarios son GMT. La hora en este momento es 20:34:19.
