Viejo 12/01/12, 19:26:51
frank_jruiz frank_jruiz is offline
Unhappy Bapi_incominginvoice_create
hola, estoy realizando la implementacion de la BAPI BAPI_INCOMINGINVOICE_CREATE el cual tengo el siguiente codigo.
*Cabecera
L_HEADERDATA-INVOICE_IND = 'X'.
L_HEADERDATA-DOC_TYPE = 'RE'.
L_HEADERDATA-DOC_DATE = '20111130'.
L_HEADERDATA-PSTNG_DATE = '20111130'.
L_HEADERDATA-REF_DOC_NO = 'PRUEBA A'.
L_HEADERDATA-COMP_CODE = '1000'.
L_HEADERDATA-CURRENCY = 'COP'.
L_HEADERDATA-GROSS_AMOUNT = '6000000'.
L_HEADERDATA-CALC_TAX_IND = 'X'.
*pedido POS
LT_ITEMDATA-INVOICE_DOC_ITEM = '000006'.
LT_ITEMDATA-PO_NUMBER = '5000021945'.
LT_ITEMDATA-PO_ITEM = '00020'.
LT_ITEMDATA-REF_DOC = '5000142047'.
LT_ITEMDATA-REF_DOC_YEAR = '2011'."AÑO Fecha factura EKBE
LT_ITEMDATA-REF_DOC_IT = '0001'.
LT_ITEMDATA-TAX_CODE = 'V0'.
LT_ITEMDATA-ITEM_AMOUNT = '6000000'."WRBTR
LT_ITEMDATA-QUANTITY = '30.000'."MENGE-EKBE
LT_ITEMDATA-PO_UNIT = '10'.
APPEND LT_ITEMDATA.
*RETENCIONES ***************
LT_WITHTAXDATA-SPLIT_KEY = '000001' .
LT_WITHTAXDATA-WI_TAX_TYPE = '+P' .
LT_WITHTAXDATA-WI_TAX_CODE = '+P' .
LT_WITHTAXDATA-WI_TAX_BASE = '6000000' .
LT_WITHTAXDATA-WI_TAX_AMT = '0.00' .
LT_WITHTAXDATA-WI_TAX_WITHHELD_AMT = '0.00' .
APPEND LT_WITHTAXDATA.
LT_WITHTAXDATA-WI_TAX_TYPE = '+Q' .
LT_WITHTAXDATA-WI_TAX_CODE = '+Q' .
LT_WITHTAXDATA-WI_TAX_BASE = '700000' .
LT_WITHTAXDATA-WI_TAX_TYPE = '/A' .
LT_WITHTAXDATA-WI_TAX_CODE = '/A' .
LT_WITHTAXDATA-WI_TAX_BASE = '730000' .
LT_WITHTAXDATA-WI_TAX_TYPE = '/C' .
LT_WITHTAXDATA-WI_TAX_CODE = '/C' .
LT_WITHTAXDATA-WI_TAX_BASE = '4570000' .
LT_WITHTAXDATA-WI_TAX_AMT = '475377' .
LT_WITHTAXDATA-WI_TAX_TYPE = '/D' .
LT_WITHTAXDATA-WI_TAX_CODE = '/D' .
LT_WITHTAXDATA-WI_TAX_BASE = '1818400' .
LT_WITHTAXDATA-WI_TAX_TYPE = '/E' .
LT_WITHTAXDATA-WI_TAX_CODE = '/E' .
LT_WITHTAXDATA-WI_TAX_BASE = '200000' .
LT_WITHTAXDATA-WI_TAX_TYPE = 'CE' .
LT_WITHTAXDATA-WI_TAX_CODE = 'CE' .
LT_WITHTAXDATA-WI_TAX_BASE = '50000' .
CLEAR: LT_WITHTAXDATA,
LT_ITEMDATA.
CALL FUNCTION 'BAPI_INCOMINGINVOICE_CREATE'
EXPORTING
HEADERDATA = L_HEADERDATA
* ADDRESSDATA = ADDRESSDATA
* IMPORTING
* INVOICEDOCNUMBER = INVOICEDOCNUMBER
* FISCALYEAR = FISCALYEAR
TABLES
ITEMDATA = LT_ITEMDATA
* ACCOUNTINGDATA = LT_ACCTDATA
* GLACCOUNTDATA = GLACCOUNTDATA
* MATERIALDATA = MATERIALDATA
* TAXDATA = TAXDATA
WITHTAXDATA = LT_WITHTAXDATA
* VENDORITEMSPLITDATA = VENDORITEMSPLITDATA
RETURN = RETURN .
pero al realizar la prueba me genera el mensaje siguiente:
1 E M8 412 Indicador de retención impuestos requiere entrada de importe base 000000 WITHTAXDATA 000001 0 SOLSEP400
ya he probado enviando el importe de diferentes manera pero no me contabiliza.
Úlima edición por frank_jruiz fecha: 12/01/12 a las 20:41:07.
Viejo 12/01/12, 20:09:05
Smile Bapi_incominginvoice_create
Hola el problema es que todos los indicadores deben tener la base en este caso el primero no la tiene
gracias.
Viejo 12/01/12, 20:39:50
Exclamation Bapi_incominginvoice_create
ya la Bapi esta funcionando pero no genera RETURN para hacer la conta bilizacion que puede ser ??
Viejo 24/08/19, 04:25:42
Attilio Travascio Attilio Travascio is offline
Solo dejo esta respuesta, por si alguien busca la información, si la tabla RETURN, llega vacía, es porque no se encontró ningún error.
Debes revisar los parámetros de Export, que indican el Numero del documento creado y el año fiscal.
ATTILIO TRAVASCIO
Viejo 26/08/19, 17:42:37
Avatar de ximena251
ximena251 ximena251 is offline
En estos te devuelve los datos
invoicedocnumber = lv_doc
fiscalyear = lv_year
ya solo si lv_doc no viene vacío, le aplicas un commit
CALL FUNCTION 'BAPI_TRANSACTION_COMMIT'
EXPORTING
wait = 'X'.
Los escritores somos seres heridos por ello creamos otra realidad
Husos Horarios son GMT. La hora en este momento es 19:51:28.
