Leer datos de una BBDD ACCESS
Despues de pelearme mucho, he conseguido leer datos de una BBDD ACCESS. Dejo aquí el código para quien le pueda interesar Un saludo REPORT z_prueba_access. * Selection Screen INCLUDE ole2incl. *data: TEST like TEST. *TYPES: ole2_object LIKE obj_record. DATA: h_cn TYPE ole2_object. DATA: h_rs TYPE ole2_object. DATA: h_fi TYPE ole2_object. DATA: h_it TYPE ole2_object. DATA: h_es TYPE ole2_object. DATA: h_er TYPE ole2_object. DATA: c1(250) VALUE 'Driver={Driver do Microsoft Access (*.mdb)};' & 'DBQ=\\lhinf\C\bd1.mdb;'. DATA: c2(250) VALUE 'select * from datosclientes'. DATA: rs_eof TYPE i. DATA: c3(250). DATA: cfname(15). DATA: cfvalue(50). DATA: cerr(100). DATA: i1 TYPE i. DATA: i2 TYPE i. DATA: i3 TYPE i. DATA: i4 TYPE i. DATA: f1 TYPE f. DATA: p1 TYPE p. DATA: x1 TYPE x. START-OF-SELECTION. IF h_cn-header = space OR h_cn-handle = -1. * Crea la conexón a la base de datos WRITE: AT / 'Cadena Conexión :', c1. CREATE OBJECT h_cn 'ADODB.CONNECTION'. IF sy-subrc NE 0. WRITE sy-msgli. ENDIF. SET PROPERTY OF h_cn 'ConnectionTimeout' = 25. SET PROPERTY OF h_cn 'CommandTimeout' = 600. CALL METHOD OF h_cn 'open' EXPORTING #1 = c1. * Crea el objeto recordset CREATE OBJECT h_rs 'ADODB.Recordset'. IF sy-subrc NE 0. WRITE sy-msgli. ENDIF. SET PROPERTY OF h_rs 'ActiveConnection' = h_cn. SET PROPERTY OF h_rs 'CursorType' = 1. SET PROPERTY OF h_rs 'LockType' = 1. * Abrimos la consulta a BBDD CALL METHOD OF h_rs 'open' EXPORTING #2 = c2. IF sy-subrc NE 0. WRITE sy-msgli. ENDIF. GET PROPERTY OF h_rs 'RecordCount' = i1. IF sy-subrc NE 0. WRITE sy-msgli. ENDIF. GET PROPERTY OF h_rs 'EOF' = rs_eof. WHILE rs_eof <> 1. IF i1 > 0 . i4 = i4 + 1. ULINE. WRITE: AT / 'REGISTRO:', i4. * Inicia Impresión de Columnas i3 = 0. CALL METHOD OF h_rs 'Fields' = h_fi EXPORTING #1 = 0. GET PROPERTY OF h_fi 'Value' = cfvalue. WRITE: AT /(25) 'F1:', cfvalue. i3 = i3 + 1. CALL METHOD OF h_rs 'Fields' = h_fi EXPORTING #1 = i3. GET PROPERTY OF h_fi 'VALUE' = cfvalue. WRITE: AT /(25) 'F2:', cfvalue. i3 = i3 + 1. CALL METHOD OF h_rs 'Fields' = h_fi EXPORTING #1 = i3. GET PROPERTY OF h_fi 'VALUE' = cfvalue. WRITE: AT /(25) 'F3:', cfvalue. i3 = i3 + 1. * Siguiente Registro CALL METHOD OF h_rs 'movenext'. IF sy-subrc NE 0. WRITE sy-msgli. ENDIF. GET PROPERTY OF h_rs 'EOF' = rs_eof. ENDIF. ENDWHILE. * Cierra la conexión CALL METHOD OF h_rs 'close'. FREE OBJECT h_rs. h_rs-handle = -1. CALL METHOD OF h_cn 'close'. FREE OBJECT h_cn. h_cn-handle = -1. FREE OBJECT h_fi. FREE OBJECT h_it. FREE OBJECT h_es. FREE OBJECT h_er. |
Desplegado | |
