Viejo 15/12/11, 16:13:29
sapidesmexico sapidesmexico is offline
Error al instalar SAP IDES ECC 6.0 con Oracle 10.2
Estimados foristas les mando este error q me presenta el instalar el sap ecc 6.0 es en la parte de cuando le faltan 2 tareas para acompletar la instalación de abap el log pertenece al archivo PCL2.log
alguna sugerencia?
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111210013352
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: sccsid @(#) $Id: //bas/701_REL/src/R3ld/R3load/R3ldmain.c#5 $ SAP
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: version R7.01/V1.4 [UNICODE]
Compiled Feb 24 2009 23:41:07
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe -ctf I Z:\Descomprimidos\51037623_InstallationExport\51037623_2\DATA_UNITS\EXPORT_2\DATA\PCL2.STR C:\Program Files\sapinst_instdir\ERPEhP4\AS-ABAP\ORA\CENTRAL\DDLORA_LRG.TPL PCL2.TSK ORA -l PCL2.log
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: job completed
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111210013352
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111210013353
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe -i PCL2.cmd -dbcodepage 4103 -l PCL2.log -stop_on_error
DbSl Trace: ORA-1403 when accessing table SAPUSER
(DB) INFO: connected to DB
(DB) INFO: DbSlControl(DBSL_CMD_NLS_CHARACTERSET_GET): UTF8
(DB) INFO: PCL2 created #20111210013355
(RFF) ERROR: file PCL2.002 not found
(TFH) ERROR: Unable to close Z:\Descomprimidos\51037623_InstallationExport\51037623_2\DATA_UNITS\EXPORT_2\DATA\PCL2.001
(DB) INFO: disconnected from DB
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: job finished with 1 error(s)
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111210013924
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111210175403
(DB) INFO: PCL2 deleted/truncated #20111210175422
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111210175734
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111211084536
(DB) INFO: PCL2 deleted/truncated #20111211084557
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111211084840
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111211085910
(DB) INFO: PCL2 deleted/truncated #20111211085928
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111211090221
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111211092152
(DB) INFO: PCL2 deleted/truncated #20111211092211
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111211092503
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: START OF LOG: 20111211094526
DbSl Trace: OCI-call 'OCISessionBegin' failed with rc=1034
DbSl Trace: CONNECT failed with sql error '1034'
(DB) ERROR: db_connect rc = 256
(DB) ERROR: DbSlErrorMsg rc = 99
D:\usr\sap\WY2\SYS\exe\uc\NTAMD64\R3load.exe: END OF LOG: 20111211094526
Viejo 15/12/11, 16:19:16
Esto es lo q me dice el import_monitor_java.log
java version "1.4.2_17"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_17-b06)
Java HotSpot(TM) 64-Bit Server VM (build 1.4.2_17-b06, mixed mode)
Import Monitor jobs: running 1, waiting 1, completed 103, failed 0, total 105.
Loading of 'PCL2' import package: ERROR
Import Monitor jobs: running 0, waiting 1, completed 103, failed 1, total 105.
Viejo 15/12/11, 16:20:58
esto es lo q dice el sapinst.log
INFO 2011-12-11 10:14:49.078
Switched to user: wy2adm.
INFO 2011-12-11 10:14:49.218
Creating file C:\Program Files\sapinst_instdir\ERPEhP4\AS-ABAP\ORA\CENTRAL\import_monitor.java.log.
INFO 2011-12-11 10:14:49.250
INFO 2011-12-11 10:14:49.265
Working directory changed to C:\Program Files\sapinst_instdir\ERPEhP4\AS-ABAP\ORA\CENTRAL.
Output of C:\j2sdk1.4.2_17-x64\bin\java.exe -classpath migmon.jar -showversion -Xmx1024m com.sap.inst.migmon.imp.ImportMonitor -sapinst is written to the logfile import_monitor.java.log.
WARNING 2011-12-11 10:15:20.250
Execution of the command "C:\j2sdk1.4.2_17-x64\bin\java.exe -classpath migmon.jar -showversion -Xmx1024m com.sap.inst.migmon.imp.ImportMonitor -sapinst" finished with return code 103. Output:
WARNING[E] 2011-12-11 10:15:20.250
CJS-30022 Program 'Migration Monitor' exits with error code 103. For details see log file(s) import_monitor.java.log, import_monitor.log.
ERROR 2011-12-11 10:15:20.265
FCO-00011 The step runMigrationMonitor with step key |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Onehost_System|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|ind|ind|ind|10|0|NW_ABAP_Import_Dialog|ind|ind|ind|ind|5|0|NW_ABAP_Import|ind|ind|ind|ind|0|0|runMigrationMonitor was executed with status ERROR .
INFO 2011-12-11 10:15:32.812
An error occured and the user decided to retry the current step: "|NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Onehost_System|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|ind|ind|ind|10|0|NW_ABAP_Import_Dialog|ind|ind|ind|ind|5|0|NW_ABAP_Import|ind|ind|ind|ind|0|0|runMigrationMonitor".
INFO 2011-12-11 10:15:33.125
INFO 2011-12-11 10:15:33.265
INFO 2011-12-11 10:15:33.281
WARNING 2011-12-11 10:16:03.531
WARNING[E] 2011-12-11 10:16:03.531
ERROR 2011-12-11 10:16:03.546
INFO 2011-12-11 10:20:52.593
INFO 2011-12-11 10:20:52.906
INFO 2011-12-11 10:20:53.031
INFO 2011-12-11 10:20:53.046
WARNING 2011-12-11 10:21:23.296
WARNING[E] 2011-12-11 10:21:23.296
ERROR 2011-12-11 10:21:23.312
Viejo 19/12/11, 03:31:47
problema solucionado
incremente la paginacion
el numero de trabajos paralelos lo deje en 2
descomprimi de nuevo los archivos
ya tengo el servidor funcional de nuevo al 100 %
gracias por sus aportaciones
Husos Horarios son GMT. La hora en este momento es 20:02:37.
