  #11
Viejo 17/07/08, 12:53:56
Este seria la parte de un ejemplo de un alv en bloques, espero que te pueda llegar a servir.
PERFORM f_init_block.
PERFORM f_cargar_layout.
PERFORM f_cargar_fieldcat TABLES i_fieldcat.
PERFORM f_cargar_fieldcat2 TABLES i_fieldcat2.
PERFORM f_cargar_fieldcat3 TABLES i_fieldcat3.
PERFORM f_cargar_eventos.
PERFORM f_append_alv1.
PERFORM f_append_alv3.
PERFORM f_append_alv2.
PERFORM f_listar_block.
FORM f_cargar_fieldcat TABLES pt_fieldcat TYPE slis_t_fieldcat_alv.
DATA: l_posicion TYPE i.
CLEAR pt_fieldcat.
REFRESH pt_fieldcat.
pt_fieldcat-col_pos = l_posicion.
pt_fieldcat-fieldname = 'CUIT'.
pt_fieldcat-seltext_l = 'CUIT'.
pt_fieldcat-tabname = 'I_SALIDA'.
APPEND pt_fieldcat.
CLEAR pt_fieldcat.
pt_fieldcat-fieldname = 'LIFNR'.
pt_fieldcat-seltext_l = 'Acreedor'.
APPEND pt_fieldcat.
CLEAR pt_fieldcat.
pt_fieldcat-fieldname = 'BUKRS'.
pt_fieldcat-seltext_l = 'Sociedad'.
APPEND pt_fieldcat.
CLEAR pt_fieldcat.
pt_fieldcat-fieldname = 'NAME1'.
pt_fieldcat-seltext_l = 'Razon Social'.
APPEND pt_fieldcat.
CLEAR pt_fieldcat.
pt_fieldcat-fieldname = 'MENSAJE'.
pt_fieldcat-seltext_l = 'Log'.
APPEND pt_fieldcat.
CLEAR pt_fieldcat.
ENDFORM. " f_cargar_fieldcat_1
Y otros dos forms mas iguales a este...
FORM f_init_block.
CALL FUNCTION 'REUSE_ALV_BLOCK_LIST_INIT'
EXPORTING
i_callback_program = g_repid
i_callback_pf_status_set = 'SET-PF-STATUS'.
ENDFORM. "f_init_block
FORM f_append_alv1.
DATA l_tabname TYPE slis_tabname VALUE 'I_SALIDA'.
CALL FUNCTION 'REUSE_ALV_BLOCK_LIST_APPEND'
EXPORTING
is_layout = i_layout
it_fieldcat = i_fieldcat[]
i_tabname = l_tabname
it_events = i_eventos
TABLES
t_outtab = i_salida.
IF sy-subrc <> 0.
MESSAGE ID sy-msgid TYPE sy-msgty NUMBER sy-msgno
WITH sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4.
ENDIF.
ENDFORM. "f_append_alv1
FORM f_append_alv2.
DATA l_tabname TYPE slis_tabname VALUE 'I_JD'.
EXPORTING
it_fieldcat = i_fieldcat2[]
it_events = i_eventos_2
TABLES
t_outtab = i_jd.
IF sy-subrc <> 0.
ENDIF.
ENDFORM. "f_append_alv2
CALL FUNCTION 'REUSE_ALV_BLOCK_LIST_DISPLAY'
EXCEPTIONS
program_error = 1
OTHERS = 2.
IF sy-subrc <> 0.
ENDIF.
ENDFORM. "f_listar_block
FORM f_cargar_eventos .
DATA: l_eventos TYPE slis_alv_event.
CALL FUNCTION 'REUSE_ALV_EVENTS_GET'
EXPORTING
i_list_type = 0
IMPORTING
et_events = i_eventos.
CLEAR l_eventos.
READ TABLE i_eventos WITH KEY name = 'TOP_OF_PAGE'
INTO l_eventos.
IF sy-subrc = 0.
* Asignar subrutina al evento TOP-OF-PAGE
MOVE 'TOP-OF-PAGE' TO l_eventos-form.
APPEND l_eventos TO i_eventos.
ENDIF.
CLEAR l_eventos.
INTO l_eventos.
IF sy-subrc = 0.
* Asignar subrutina al evento TOP-OF-PAGE BLOQUE 2
MOVE 'TOP-OF-PAGE-2' TO l_eventos-form.
APPEND l_eventos TO i_eventos_2.
ENDIF.
CLEAR l_eventos.
INTO l_eventos.
IF sy-subrc = 0.
* Asignar subrutina al evento TOP-OF-PAGE BLOQUE 3
MOVE 'TOP-OF-PAGE-3' TO l_eventos-form.
APPEND l_eventos TO i_eventos_3.
ENDIF.
ENDFORM. " f_cargar_eventos
(Para este form debes hacer antes 3 top of page)
FORM f_append_alv3 .
DATA l_tabname TYPE slis_tabname VALUE 'I_SALIDA2'.
EXPORTING
it_fieldcat = i_fieldcat3[]
it_events = i_eventos_3
TABLES
t_outtab = i_salida2.
IF sy-subrc <> 0.
ENDIF.
espero que te sirva saludos...
Sebas
Desarrollador ABAP.
  #12
Viejo 29/07/08, 12:16:22
Avatar de mcarrasco
mcarrasco mcarrasco is offline
Localización: Venezuela. Pto Ordaz
Amigo...
Te recomiendo que crees una estructura con los campos que requieres de las 2 tablas y crees luego una tabla interna de esta estructura.
creas el catalogo según la estructura y le mandas esta tabla a la funcion que muestra el alv.
Atte. Marcos Carrasco...
Husos Horarios son GMT. La hora en este momento es 08:42:02.
