Viejo 04/03/10, 20:45:12
yosoydekaslimon yosoydekaslimon is offline
disp+work.exe stopped
Buenas tardes
Soy nuevo en el mundo sap, pero estoy encontrando bastantes inconvenientes para instalar SAPNWABAP701SR1_TRIAL
Llevo ya cerca de 2 meses intentando instalar la aplicación y he observado peor nio ha sido posibl, he observado que al levantar la instancia, queda parada disp+work.exe
Ruego vuestra ayuda, estoy bastante desesperado.
La traza es la siguiente
trc file: "dev_disp", trc level: 1, release: "701"
sysno 02
sid NSP
systemid 560 (PC with Windows NT)
relno 7010
patchlevel 0
patchno 29
intno 20020600
make: multithreaded, Unicode, optimized
pid 936
Thu Mar 04 22:38:37 2010
kernel runs with dp version 241000(ext=110000) (@(#) DPLIB-INT-VERSION-241000-UC)
length of sys_adm_ext is 576 bytes
*** SWITCH TRC-HIDE on ***
***LOG Q00=> DpSapEnvInit, DPStart (02 936) [dpxxdisp.c 1261]
shared lib "dw_xml.dll" version 29 successfully loaded
shared lib "dw_xtc.dll" version 29 successfully loaded
shared lib "dw_stl.dll" version 29 successfully loaded
shared lib "dw_gui.dll" version 29 successfully loaded
shared lib "dw_mdm.dll" version 29 successfully loaded
rdisp/softcancel_sequence : -> 0,5,-1
use internal message server connection to port 3902
Thu Mar 04 22:38:41 2010
*** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 4 seconds
***LOG GZZ=> 1 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 5529]
MtxInit: 30000 0 0
DpSysAdmExtInit: ABAP is active
DpSysAdmExtInit: VMC (JAVA VM in WP) is not active
DpIPCInit2: start server >localhost_NSP_02 <
DpShMCreate: sizeof(wp_adm) 13632 (1704)
DpShMCreate: sizeof(tm_adm) 4415616 (21968)
DpShMCreate: sizeof(wp_ca_adm) 1664 (80)
DpShMCreate: sizeof(appc_ca_adm) 1600 (80)
DpCommTableSize: max/headSize/ftSize/tableSize=500/8/528056/528064
DpShMCreate: sizeof(comm_adm) 528064 (1048)
DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
DpShMCreate: sizeof(slock_adm) 0 (96)
DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
DpShMCreate: sizeof(file_adm) 0 (72)
DpShMCreate: sizeof(vmc_adm) 0 (1544)
DpShMCreate: sizeof(wall_adm) (38456/34360/64/184)
DpShMCreate: sizeof(gw_adm) 48
DpShMCreate: SHM_DP_ADM_KEY (addr: 060D0040, size: 5042120)
DpShMCreate: allocated sys_adm at 060D0040
DpShMCreate: allocated wp_adm at 060D2170
DpShMCreate: allocated tm_adm_list at 060D56B0
DpShMCreate: allocated tm_adm at 060D56E0
DpShMCreate: allocated wp_ca_adm at 0650B760
DpShMCreate: allocated appc_ca_adm at 0650BDE0
DpShMCreate: allocated comm_adm at 0650C420
DpShMCreate: system runs without slock table
DpShMCreate: system runs without file table
DpShMCreate: allocated vmc_adm_list at 0658D2E0
DpShMCreate: allocated gw_adm at 0658D320
DpShMCreate: system runs without vmc_adm
DpShMCreate: allocated ca_info at 0658D350
DpShMCreate: allocated wall_adm at 0658D358
MBUF state OFF
DpCommInitTable: init table for 500 entries
rdisp/queue_size_check_value : -> off
ThTaskStatus: rdisp/reset_online_during_debug 0
*** ERROR => ztta/cua_area is 180000. [sapinit.c 975]
*** ERROR => ztta/cua_area adjusted to 500000. [sapinit.c 979]
EmInit: MmSetImplementation( 2 ).
MM global diagnostic options set: 0
<ES> client 0 initializing ....
<ES> InitFreeList
<ES> block size is 1024 kByte.
Using implementation view
<EsNT> Using memory model view.
<EsNT> Memory Reset disabled as NT default
<ES> 1023 blocks reserved for free list.
ES initialized.
Thu Mar 04 22:38:42 2010
rdisp/http_min_wait_dia_wp : 1 -> 1
***LOG CPS=> DpLoopInit, ICU ( 3.0 3.0 4.0.1) [dpxxdisp.c 1656]
***LOG Q0K=> DpMsAttach, mscon ( localhost) [dpxxdisp.c 12362]
*** DP_FATAL_ERROR => DpMsAttach: local hostname 'localhost' is resolved to loopback address (cf. SAP note 1054467 for details)
*** DISPATCHER EMERGENCY SHUTDOWN ***
increase tracelevel of WPs
[DpWpDied] W0 lives (PID:3600 HANDLE:1576)
killing W0-3600 (SIGUSR2)
*** ERROR => DpWpKill(3600, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W1 lives (PID:3496 HANDLE:1568)
killing W1-3496 (SIGUSR2)
*** ERROR => DpWpKill(3496, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W2 lives (PID:672 HANDLE:1564)
killing W2-672 (SIGUSR2)
*** ERROR => DpWpKill(672, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W3 lives (PID:2012 HANDLE:1560)
killing W3-2012 (SIGUSR2)
*** ERROR => DpWpKill(2012, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W4 lives (PID:1716 HANDLE:1556)
killing W4-1716 (SIGUSR2)
*** ERROR => DpWpKill(1716, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W5 lives (PID:1800 HANDLE:1552)
killing W5-1800 (SIGUSR2)
*** ERROR => DpWpKill(1800, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W6 lives (PID:3868 HANDLE:1548)
killing W6-3868 (SIGUSR2)
*** ERROR => DpWpKill(3868, SIGUSR2) failed [dpxxtool.c 2549]
[DpWpDied] W7 lives (PID:3824 HANDLE:1544)
killing W7-3824 (SIGUSR2)
*** ERROR => DpWpKill(3824, SIGUSR2) failed [dpxxtool.c 2549]
NiWait: sleep (10000ms) ...
NiISelect: timeout 10000ms
NiISelect: maximum fd=1617
NiISelect: read-mask is NULL
NiISelect: write-mask is NULL
Viejo 05/03/10, 02:30:40
Avatar de Tonijua
Tonijua Tonijua is offline
Localización: Chile
Mmm yo no se mucho de esto, pero lo he instalado dos veces, dejame un correo y te mando un manual que tengo en dnd explica como se instala.
Tonijua.
Moderador FICO
Viejo 05/03/10, 12:22:20
Avatar de BREZHNEV
BREZHNEV BREZHNEV is offline
hola, de casualidad has leido los pre requisitos para instalar ese producto?, cuando lo descargas te descarga tambien ese documento, y ahi se indica que cosas tienes que configurar en tu PC, para que no tengas problemas, pero me parece que no lo has hecho, ya que el error:
me hace pensar que no tienes sificiente memoria (fisica o de paginacion), adicionalmente el error:
me hace pensar que no has configurado la red que te sugiere SAP de la manera correcta (creo que es 10.10.0.10), ni tampoco el atchivo ETC.
por favor indicame si configuraste todos los pre requisitos correctamente, asi como cuanto de memoria tienes en tu PC (fisica y de paginacion).
salu2
==»BREZHNEV«==
Husos Horarios son GMT. La hora en este momento es 22:28:56.
