REUSE_ALV_FIELDCATALOG_MERGE Modificar disposicion
Que debo agregar para que me aparezcan los iconos de modificar, gestionar disposiciones.
No se si te entiendo bien.
Me suena a querés modificar el Status GUI del reporte final. Para eso no tenés que modificar el catálogo sino el display. Copiate un estatus estandar por la trx: SE41 a tu programa y este aplicalo al alv. Ej: Programa: SAPLKKBL Status: STANDARD_FULLSCREEN Este tiene los botones: &OL0 &OAD &AVE Que creo son los que solucionan el problema que planteás. SAludos. |
CALL FUNCTION 'REUSE_ALV_LIST_DISPLAY'
EXPORTING i_callback_program = g_repid i_callback_pf_status_set = 'SET_STATUS' i_callback_user_command = 'USER_COMMAND' i_structure_name = 'TI_ZTPICK_VER' is_layout = gs_layout it_fieldcat = gt_fieldcat[] i_save = g_save --------> esto te habilita los botones para poder grabar y mod disp |
Estimados : De nuevo la explicaciòn con algo de còdigo.
FORM get_layout . clear gs_layout. * gs_layout-zebra = 'X'. gs_layout-sel_mode = 'D'. ENDFORM. " get_layout FORM get_fieldcat . data: ls_fcat type lvc_s_fcat. data: w_pos(2) TYPE n. DATA: w_repid LIKE sy-repid. data: IT_FIELDCAT TYPE SLIS_T_FIELDCAT_ALV WITH HEADER LINE. w_repid = sy-repid. CALL FUNCTION 'REUSE_ALV_FIELDCATALOG_MERGE' EXPORTING i_program_name = w_repid i_internal_tabname = 'GT_DATA' i_inclname = w_repid CHANGING ct_fieldcat = IT_FIELDCAT[] EXCEPTIONS inconsistent_interface = 1 program_error = 2 OTHERS = 3. LOOP AT IT_FIELDCAT. CLEAR ls_fcat. MOVE-CORRESPONDING IT_FIELDCAT to ls_fcat. ls_fcat-ref_table = IT_FIELDCAT-ref_tabname. ls_fcat-ref_field = IT_FIELDCAT-ref_fieldname. ls_fcat-outputlen = IT_FIELDCAT-ddic_outputlen. ls_fcat-key = space. ls_fcat-fix_column = space. ls_fcat-auto_value = space. ls_fcat-edit = space. CASE ls_fcat-fieldname. WHEN 'BELNR'. ls_fcat-key = 'X'. ls_fcat-fix_column = 'X'. WHEN 'GJAHR'. ls_fcat-key = 'X'. ls_fcat-fix_column = 'X'. WHEN 'PROCESS'. ls_fcat-scrtext_l = 'Procesado'. ls_fcat-scrtext_m = 'Procesado'. ls_fcat-scrtext_s = 'Procesado'. WHEN 'SGTXT'. ls_fcat-edit = 'X'. WHEN OTHERS. ENDCASE. APPEND ls_fcat to gt_fieldcat. ENDLOOP. Luego viene: MODULE STATUS_0100 OUTPUT. SET PF-STATUS 'ST_001'. SET TITLEBAR 'TIT01'. if GRID1 is INITIAL. CREATE OBJECT g_custom_container EXPORTING container_name = G_CONTAINER. CREATE OBJECT GRID1 EXPORTING I_PARENT = g_custom_container. CREATE OBJECT gr_events. SET HANDLER gr_events->handle_data_changed FOR GRID1. * Validar al dar enter CALL METHOD GRID1->register_edit_event EXPORTING i_event_id = cl_gui_alv_grid=>mc_evt_enter. * Validar al modificar el campo CALL METHOD grid1->register_edit_event EXPORTING i_event_id = cl_gui_alv_grid=>mc_evt_modified. CALL METHOD GRID1->SET_TABLE_FOR_FIRST_DISPLAY EXPORTING is_layout = gs_layout i_save = 'A' CHANGING IT_OUTTAB = gt_data[] IT_FIELDCATALOG = GT_FIELDCAT. ELSE. call METHOD GRID1->refresh_table_display. ENDIF. ENDMODULE. " STATUS_0100 OUTPUT |
