Viejo 25/11/09, 12:54:26
cocke cocke is offline
ERROR Database Instance SAP IDES4.71
Hola!
Tengo un problema en la instalación con SAP IDES 4.71 y la verdad no sé que puede ser.
Lo re-instalé 10 veces y aún no consigo pasar la última parte, ya que me arroja el siguiente error luego de seleccionar los paquetes EXPORT.
Adjunto log:
INFO 2009-11-25 00:15:37
Processing of host operation t_HostInfo_SHARED succeeded.
INFO 2009-11-25 00:15:45
The 'saploc' share exists at directory 'C:\usr\sap'. Choosing drive C: as SAP System drive.
INFO[E] 2009-11-25 00:16:18
Account group="p3lao\SAP_LDAP" does not exist. <#1>
INFO[E] 2009-11-25 00:16:36
Account group="p3lao\dbc11ctl" does not exist. <#1>
INFO 2009-11-25 00:19:23
Copying file C:/Varios/disk1/EXPORT1/DB/ORA/DBSIZE.XML to: DBSIZE.XML.
Creating file C:\SAPinst ORACLE SAPINST\DBSIZE.XML.
Copying file system node C:\Varios\disk1\EXPORT1/DB/ORA/DBSIZE.XML with type NODE to DBSIZE.XML succeeded.
Processing of all file system node operations of table tORA_filecopy succeeded.
INFO 2009-11-25 00:19:24
Copying file C:/Varios/disk1/EXPORT1/DB/DDLORA.TPL to: DDLORA.TPL.
Creating file C:\SAPinst ORACLE SAPINST\DDLORA.TPL.
Copying file system node C:\Varios\disk1\EXPORT1/DB/DDLORA.TPL with type NODE to DDLORA.TPL succeeded.
INFO 2009-11-25 00:19:28
Moving file C:/SAPinst ORACLE SAPINST/DDLORA.TPL to: orig_ddl_ora_tmp.tpl.
Moving file C:/SAPinst ORACLE SAPINST/changed_ddl_ora_tmp.tpl to: DDLORA.TPL.
Removing file C:/SAPinst ORACLE SAPINST/orig_ddl_ora_tmp.tpl.
ERROR 2009-11-25 00:20:50
MSC-01002 Couldn't create package table, no packages found in: C:\Varios\disk1\EXPORT1 C:\Varios\disk2\EXPORT2 C:\Varios\disk3\EXPORT3 C:\Varios\disk3\EXPORT4 C:\Varios\disk3\EXPORT5 C:\Varios\disk3\EXPORT6 C:\Varios\disk3\EXPORT7
FJS-00012 Error when executing script.
FCO-00011 The step fillR3loadPackageTable with step key SAPSYSTEM|ind|ind|ind|ind|ind|0|SAPComponent|ind|ind|ind|ind|ind|0|DatabaseLoad|ind|ind|ind|ind|ind|0|fillR3loadPackageTable executed with status ERROR.
Para la instalación he seguido el manual en PDF disponible en esta Web ->
Si alguien me puede ayudar sería excelente ya que he gogleado bastante pero no he encontrado exactamente el mismo error.
Cocke
Husos Horarios son GMT. La hora en este momento es 02:10:45.
