Como modificar una lista de Material
Hola a todos:
Estoy tratando de modificar una lista de material especificamente los componentes y encabezado usando la BAPI BAPI_MATERIAL_BOM_GROUP_CREATE, ya logre crear una lista de material usando la bapi use el siguiente codigo : Data : Variante LIKE it_bomgroup-object_id Value 'ZNUEVA'. * Fill the data * Material BoM Group Header Data CLEAR it_bomgroup. it_bomgroup-bom_group_identification = ''. it_bomgroup-object_type = 'BGR'. it_bomgroup-object_id = VARIANTE. it_bomgroup-technical_type = ''. it_bomgroup-bom_usage = MATERIALES_ENC-STLAN. it_bomgroup-created_in_plant = MATERIALES_ENC-WERKS. it_bomgroup-ltxt_lang = SY-LANGU. it_bomgroup-bom_text = ''. APPEND it_bomgroup. ** Header Details of the different variants CLEAR it_variants. it_variants-bom_group_identification = ''. it_variants-object_type = 'BOM'. it_variants-object_id = VARIANTE. it_variants-alternative_bom = MATERIALES_ENC-STLAL. it_variants-bom_status = MATERIALES_ENC-STLAN. it_variants-base_qty = MATERIALES_ENC-BASE_QTY. it_variants-base_unit = MATERIALES_ENC-base_unit. it_variants-valid_from_date = SY-DATUM. it_variants-function = 'NEW'. APPEND it_variants. Loop at MATERIALES_DET. ** Details of the items of the variants CLEAR it_items. it_items-bom_group_identification = ''. it_items-object_type = 'ITM'. it_items-object_id = VARIANTE. it_items-item_no = MATERIALES_DET-POSNR. it_items-item_cat = MATERIALES_DET-POSTP. it_items-component = MATERIALES_DET-IDNRK. it_items-comp_qty = MATERIALES_DET-COMP_QTY. it_items-comp_unit = MATERIALES_DET-COMP_UNIT. it_items-valid_from_date = SY-DATUM. APPEND it_items. EndLOOP. ** Details of the materials of the different variants CLEAR it_matrel. it_matrel-bom_group_identification = ''. it_matrel-material = MATERIALES_ENC-MATNR. it_matrel-plant = MATERIALES_ENC-WERKS. it_matrel-bom_usage = MATERIALES_ENC-STLAN. it_matrel-alternative_bom = MATERIALES_ENC-STLAL. APPEND it_matrel. ** Linking items to the corresponding variants CLEAR it_itemas. it_itemas-bom_group_identification = ''. it_itemas-sub_object_type = 'ITM'. it_itemas-sub_object_id = VARIANTE. it_itemas-super_object_type = 'BOM'. it_itemas-super_object_id = VARIANTE. it_itemas-valid_from_date = SY-DATUM. it_itemas-function = 'NEW'. APPEND it_itemas. * Create variants CALL FUNCTION 'BAPI_MATERIAL_BOM_GROUP_CREATE' EXPORTING all_error = 'X' TABLES bomgroup = it_bomgroup variants = it_variants items = it_items materialrelations = it_matrel itemassignments = it_itemas return = RETORNO_MEN. CALL FUNCTION 'BAPI_TRANSACTION_COMMIT'. Ahora quiero modificar la lista pero usando la misma bapi cambiando la function a 'CHG', alguien lo ha hecho?. Ojo la lista de materiales que cree no tiene bom_group_identification porque por lo que vi mi empresa no lo usa. Pero tengo la duda si igual le asigna un grupo por defecto. De ante mano muchas gracias al que pueda responder, YCastro |
