Viejo 03/06/11, 15:58:08
jsp.sergio jsp.sergio is offline
Error en Instalacion del Trial
Buenas gente, sigo intentando instalar el trial, pero llega a la parte de "Start Instance" y arroja el siguiente error:
An error occurred while processing option SAP NetWeaver 7.0 SR1 including Enhancement Package 1 > SAP Application Server ABAP > MaxDB > Central System > Central System
El log dice;
TRACE 2011-06-03 12:37:22.122 [iaxxejsbas.hpp:483]
EJS_Base::dispatchFunctionCall()
JS Callback has thrown unknown exception. Rethrowing.
ERROR 2011-06-03 12:37:22.203 [sixxcstepexecute.cpp:950]
FCO-00011 The step start with step key |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Onehost_System|ind|ind|ind|ind|2|0|NW_CI_Instance|ind|ind|ind|ind|10|0|NW_CI_Instance_Start|ind|ind|ind|ind|2|0|start was executed with status ERROR .
TRACE 2011-06-03 12:37:22.303 [iaxxgenimp.cpp:752]
CGuiEngineImp::showMessageBox
<html> <head> </head> <body> <p> An error occurred while processing option SAP NetWeaver 7.0 SR1 including Enhancement Package 1 > SAP Application Server ABAP > MaxDB > Central System > Central System. You can now: </p> <ul> <li> Choose <i>Retry</i> to repeat the current step. </li> <li> Choose <i>View Log</i> to get more information about the error. </li> <li> Stop the option and continue with it later. </li> </ul> <p> Log files are written to C:\Archivos de programa/sapinst_instdir/NW701/AS-ABAP/ADA/CENTRAL/. </p> </body></html>
TRACE 2011-06-03 12:37:22.313 [iaxxgenimp.cpp:1255]
CGuiEngineImp::acceptAnswerForBlockingRequest
Waiting for an answer from GUI
Es algun problema con los requisitos del sistema?
Muchas gracias, saludos
Husos Horarios son GMT. La hora en este momento es 23:14:09.
