Pasarlo a PDF y mandarlo por Email
Tengo un smartforms y lo tengo que pasar a PDF el resultado y mandarlo por E-mail. ¿Me podéis echar una mano? Es que no tengo ni idea y lo tengo que hacer yo solito...
Smartform a pdf y envio mail
hola rodisa espero te sirva a mi me sirve!!1 w_ctrlop-getotf = 'X'. w_ctrlop-no_dialog = 'X'. *lst_control_parameters-device = 'PRINTER'. w_ctrlop-preview = space. w_compop-tdnewid = 'X'. w_compop-tdimmed = 'X'. w_compop-tddelete = 'X'. *lst_output_options-TDDEST = 'LOCL'. w_compop-tddest = 'LOC'. "Dispositivo de salida - Nombre corto w_compop-tdnoprev = 'X'. w_compop-tdcopies = 1. call function sf_function_module_name exporting control_parameters = w_ctrlop output_options = w_compop user_settings = space tab_estadoc = itab_estadoc tab_total = itab_total bukrs = pbukrs fechac = pfechac importing job_output_info = w_return. if sy-subrc <> 0. message id sy-msgid type sy-msgty number sy-msgno with sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4. endif. read table itab_estadoc index 1 into wa_estadoc. select single adrnr from kna1 into vadrnr where kunnr = wa_estadoc-kunnr. if sy-subrc = 0. select single smtp_addr from adr6 into vmail where addrnumber = vadrnr. if sy-subrc = 0. i_otf[] = w_return-otfdata[]. call function 'CONVERT_OTF_2_PDF' importing bin_filesize = ld_filesize tables otf = i_otf[] doctab_archive = lt_docs lines = lt_lines exceptions err_conv_not_possible = 1 err_otf_mc_noendmarker = 2 others = 3. if sy-subrc <> 0. message id sy-msgid type sy-msgty number sy-msgno with sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4. endif. perform correo_user using sy-uname changing ld_correo_user. perform send_mail using vmail "ld_correo_user 'Estado Cuenta Clientes' 'Estado Cuenta Clientes' lt_lines[]. endif. endif. endif. clear itab_estadoc. clear wa_estadoc. clear itab_total. clear wa_total. endat. endloop. form correo_user using i_user changing o_email. data: ld_username like bapibname-bapibname. data: lt_return like bapiret2 occurs 0 with header line. data: lt_addsmtp like bapiadsmtp occurs 0 with header line. clear o_email. * Rescato el correo segun el usuario . call function 'BAPI_USER_GET_DETAIL' exporting username = i_user tables return = lt_return addsmtp = lt_addsmtp. read table lt_addsmtp with key std_no = 'X'. if sy-subrc eq 0. move lt_addsmtp-e_mail to o_email. endif. if not o_email is initial. translate o_email to lower case. endif. endform. "correo_user *&---------------------------------------------------------------------* *& Form send_mail *&---------------------------------------------------------------------* * text *----------------------------------------------------------------------* * -->VMAIL text * -->I_SUBJECT text * -->I_OBJ_NAME text * -->I_LT_LINES text *----------------------------------------------------------------------* form send_mail using vmail i_subject i_obj_name i_lt_lines type table. * Variables para PDF y enviar por e-mail data: ld_bin_filesize type i, lt_otf type table of itcoo, lt_docs type table of docs, lt_lines type table of tline, lt_pdf255 type so_text255 occurs 0, ls_doc_chng like sodocchgi1, ld_tab_lines like sy-tabix, lt_objtxt like solisti1 occurs 0 with header line, lt_objpack like sopcklsti1 occurs 6 with header line, ls_body type solisti1, lt_body type table of solisti1, lt_recipients type table of somlreci1, ls_recipients type somlreci1. data ld_subject(50) type c. data ld_body(100) type c. data ld_field_name(50) type c. data: begin of lt_objbin occurs 0. include structure solisti1. data: end of lt_objbin. call function 'SX_TABLE_LINE_WIDTH_CHANGE' exporting * line_width_src = * line_width_dst = transfer_bin = 'X' tables content_in = i_lt_lines content_out = lt_pdf255 exceptions err_line_width_src_too_long = 1 err_line_width_dst_too_long = 2 err_conv_failed = 3 others = 4. *----------------------------------------------------------------------* * Control Data *----------------------------------------------------------------------* ls_doc_chng-obj_name = 'URGENT'. ls_doc_chng-sensitivty = 'P'. ls_doc_chng-no_change = 'X'. ls_doc_chng-priority = '1'. ls_doc_chng-obj_prio = '1'. ls_doc_chng-obj_langu = sy-langu. ls_doc_chng-no_change = 'X'. * Email Subject ls_doc_chng-obj_descr = i_subject. * Email Body ld_body = 'Anexo Estado Cuenta de Cliente'. ls_body-line = ld_body. append ls_body to lt_body. clear ls_body. append ls_body to lt_body. ld_body = 'Atte.'. ls_body-line = ld_body. append ls_body to lt_body. ld_body = sy-uname. ls_body-line = ld_body. append ls_body to lt_body. lt_objtxt[] = lt_body[]. clear lt_objtxt. describe table lt_objtxt lines ld_tab_lines. if ld_tab_lines gt 0. read table lt_objtxt index ld_tab_lines. ls_doc_chng-doc_size = ( ld_tab_lines - 1 ) * 255 + strlen( lt_objtxt ). clear lt_objpack-transf_bin. lt_objpack-body_start = 1. lt_objpack-body_num = ld_tab_lines. lt_objpack-doc_type = 'RAW'. append lt_objpack. endif. * Attachment * Move the binary attachment to other internal table. lt_objbin[] = lt_pdf255[]. lt_objpack-transf_bin = 'X'. lt_objpack-body_start = 1. ld_field_name = i_obj_name. *Get the number of lines in the Attachment (PDF FILE) describe table lt_objbin lines ld_tab_lines. lt_objpack-body_num = ld_tab_lines. lt_objpack-doc_type = 'PDF'. lt_objpack-obj_name = ld_field_name. concatenate ld_field_name '.pdf' into lt_objpack-obj_descr. lt_objpack-doc_size = ld_tab_lines * 255. append lt_objpack. *RECIPIENTS ls_recipients-rec_type = 'U'. ls_recipients-express = 'X'. ls_recipients-receiver = vmail. ls_recipients-copy = ' '. append ls_recipients to lt_recipients. if not vmail is initial. * Call the function to send the PDF file by email call function 'SO_NEW_DOCUMENT_ATT_SEND_API1' exporting document_data = ls_doc_chng put_in_outbox = 'X' tables packing_list = lt_objpack contents_bin = lt_objbin contents_txt = lt_objtxt receivers = lt_recipients exceptions too_many_receivers = 1 document_not_sent = 2 document_type_not_exist = 3 operation_no_authorization = 4 parameter_error = 5 x_error = 6 enqueue_error = 7 others = 8. commit work. if sy-subrc = 0. message i000(0k) with i_subject 'enviado con exito'. else. message i000(0k) with i_subject 'error en envío'. endif. endif. endform. "send_mail |
Samrtforms a PDF
Puedes mirar este programa RSTXPDF4 Primero debes indicarle al smartfomrs que te retorne la tabla OTF y posteriormente debes convertir dicha tabla a PDF, Mira parte de este codigo. Por Ultimo en la tabla st_job_output_info-otfdata[] tienes el pdf. Espera haberte ayudado.. Saludos:D |
Husos Horarios son GMT. La hora en este momento es 01:53:17. |
