Ejemplo de BAPI_MATERIAL_SAVEDATA
Hola, agradeceria quien me pudiera enviar un ejemplo de uso de la Bapi BAPI_MATERIAL_SAVEDATA, de antemano agradecido
Sergio |
Bapi
Buenas, anexo codigo :
REPORT ZBAPIMM01 LINE-SIZE 255 NO STANDARD PAGE HEADING LINE-COUNT 065(001). TABLES: T001L, "Storage Locations MARA, "General Material Data MAKT, "Material Descriptions MBEW, "Material Valuation MARC. "Plant Data for Material DATA: BAPI_HEAD LIKE BAPIMATHEAD, BAPI_MAKT LIKE BAPI_MAKT, "Material Description BAPI_MARA1 LIKE BAPI_MARA, "Client Data BAPI_MARAX LIKE BAPI_MARAX, BAPI_MARC1 LIKE BAPI_MARC, "Plant View BAPI_MARCX LIKE BAPI_MARCX, BAPI_MBEW1 LIKE BAPI_MBEW, "Accounting View BAPI_MBEWX LIKE BAPI_MBEWX, BAPI_RETURN LIKE BAPIRET2. DATA: BEGIN OF INT_MAKT OCCURS 100. INCLUDE STRUCTURE BAPI_MAKT. DATA: END OF INT_MAKT. DATA: BEGIN OF INT_MAT OCCURS 100, WERKS(4), "Plant MTART(4), "Material type MATNR(18), "Material number MATKL(9) , "Material group MBRSH(1), "Industry sector MEINS(3), "Base unit of measure GEWEI(3), "Weight Unit SPART(2), "Division EKGRP(3), "Purchasing group VPRSV(1), "Price control indicator STPRS(12), "Standard price PEINH(3), "Price unit SPRAS(2), "Language key MAKTX(40), "Material description END OF INT_MAT. SELECT-OPTIONS: PLANT FOR MARC-WERKS OBLIGATORY MEMORY ID PLT, MATERIAL FOR MARA-MATNR MEMORY ID MAT, MATLTYPE FOR MARA-MTART MEMORY ID MTY, DIVISION FOR MARA-SPART MEMORY ID DIV. PARAMETERS: F_FILE LIKE RLGRAP-FILENAME DEFAULT 'C:\DATA\ZMATERIAL.XLS' MEMORY ID F_FILE, GETDATA AS CHECKBOX, "Tick to download materials data to local harddisk UPDDATA AS CHECKBOX. "Tick to update date to Materials Master IF GETDATA = 'X'. PERFORM DOWNLOAD_DATA. PERFORM DOWNLOAD_FILE. ENDIF. IF UPDDATA = 'X'. PERFORM UPLOAD_FILE. PERFORM UPDATE_MM. ENDIF. FORM DOWNLOAD_DATA. SELECT * FROM MARC WHERE LVORM EQ ' ' AND WERKS IN PLANT AND MATNR IN MATERIAL. CLEAR MARA. SELECT SINGLE * FROM MARA WHERE MATNR = MARC-MATNR. CHECK MATLTYPE. CHECK DIVISION. CLEAR MBEW. SELECT SINGLE * FROM MBEW WHERE MATNR = MARC-MATNR AND BWKEY = MARC-WERKS. CLEAR MAKT. SELECT SINGLE * FROM MAKT WHERE SPRAS = 'EN' AND MATNR = MARC-MATNR. WRITE:/ MARC-WERKS, "Plant MARA-MTART, "Material type MARA-MATNR, "Material number MARA-MATKL, "Material group MARA-MBRSH, "Industry sector MARA-MEINS, "Base unit of measure MARA-GEWEI, "Weight Unit MARA-SPART, "Division MARC-EKGRP, "Purchasing group MBEW-VPRSV, "Price control indicator MBEW-STPRS, "Standard price MBEW-PEINH, "Price unit MAKT-SPRAS, "Language key MAKT-MAKTX. "Material description INT_MAT-WERKS = MARC-WERKS. "Plant INT_MAT-MTART = MARA-MTART. "Material type INT_MAT-MATNR = MARA-MATNR. "Material number INT_MAT-MATKL = MARA-MATKL. "Material group INT_MAT-MBRSH = MARA-MBRSH. "Industry sector INT_MAT-MEINS = MARA-MEINS. "Base unit of measure INT_MAT-GEWEI = MARA-GEWEI. "Weight Unit INT_MAT-SPART = MARA-SPART. "Division INT_MAT-EKGRP = MARC-EKGRP. "Purchasing group INT_MAT-VPRSV = MBEW-VPRSV. "Price control indicator INT_MAT-STPRS = MBEW-STPRS. "Standard price INT_MAT-PEINH = MBEW-PEINH. "Price unit INT_MAT-SPRAS = MAKT-SPRAS. "Language key INT_MAT-MAKTX = MAKT-MAKTX. "Material description APPEND INT_MAT. CLEAR INT_MAT. ENDSELECT. ENDFORM. FORM DOWNLOAD_FILE. call function 'WS_DOWNLOAD' EXPORTING FILENAME = F_FILE FILETYPE = 'DAT' * FILETYPE = 'WK1' tables data_tab = INT_MAT EXCEPTIONS FILE_OPEN_ERROR = 1 FILE_WRITE_ERROR = 2 INVALID_FILESIZE = 3 INVALID_TYPE = 4 NO_BATCH = 5 UNKNOWN_ERROR = 6 INVALID_TABLE_WIDTH = 7 GUI_REFUSE_FILETRANSFER = 8 CUSTOMER_ERROR = 9 OTHERS = 10. IF SY-SUBRC = 0. FORMAT COLOR COL_GROUP. WRITE:/ 'Data Download Successfully to your local harddisk'. SKIP. ENDIF. ENDFORM. FORM UPLOAD_FILE. call function 'WS_UPLOAD' EXPORTING FILENAME = F_FILE FILETYPE = 'DAT' * FILETYPE = 'WK1' tables data_tab = INT_MAT EXCEPTIONS FILE_OPEN_ERROR = 1 FILE_WRITE_ERROR = 2 INVALID_FILESIZE = 3 INVALID_TYPE = 4 NO_BATCH = 5 UNKNOWN_ERROR = 6 INVALID_TABLE_WIDTH = 7 GUI_REFUSE_FILETRANSFER = 8 CUSTOMER_ERROR = 9 OTHERS = 10. IF SY-SUBRC = 0. FORMAT COLOR COL_GROUP. WRITE:/ 'Data Upload Successfully from your local harddisk'. SKIP. ENDIF. ENDFORM. FORM UPDATE_MM. LOOP AT INT_MAT. * Header BAPI_HEAD-MATERIAL = INT_MAT-MATNR. BAPI_HEAD-IND_SECTOR = INT_MAT-MBRSH. BAPI_HEAD-MATL_TYPE = INT_MAT-MTART. BAPI_HEAD-BASIC_VIEW = 'X'. BAPI_HEAD-PURCHASE_VIEW = 'X'. BAPI_HEAD-ACCOUNT_VIEW = 'X'. * Material Description REFRESH INT_MAKT. INT_MAKT-LANGU = INT_MAT-SPRAS. INT_MAKT-MATL_DESC = INT_MAT-MAKTX. APPEND INT_MAKT. * Client Data - Basic BAPI_MARA1-MATL_GROUP = INT_MAT-MATKL. BAPI_MARA1-BASE_UOM = INT_MAT-MEINS. BAPI_MARA1-UNIT_OF_WT = INT_MAT-GEWEI. BAPI_MARA1-DIVISION = INT_MAT-SPART. BAPI_MARAX-MATL_GROUP = 'X'. BAPI_MARAX-BASE_UOM = 'X'. BAPI_MARAX-UNIT_OF_WT = 'X'. BAPI_MARAX-DIVISION = 'X'. * Plant - Purchasing BAPI_MARC1-PLANT = INT_MAT-WERKS. BAPI_MARC1-PUR_GROUP = INT_MAT-EKGRP. BAPI_MARCX-PLANT = INT_MAT-WERKS. BAPI_MARCX-PUR_GROUP = 'X'. * Accounting BAPI_MBEW1-VAL_AREA = INT_MAT-WERKS. BAPI_MBEW1-PRICE_CTRL = INT_MAT-VPRSV. BAPI_MBEW1-STD_PRICE = INT_MAT-STPRS. BAPI_MBEW1-PRICE_UNIT = INT_MAT-PEINH. BAPI_MBEWX-VAL_AREA = INT_MAT-WERKS. BAPI_MBEWX-PRICE_CTRL = 'X'. BAPI_MBEWX-STD_PRICE = 'X'. BAPI_MBEWX-PRICE_UNIT = 'X'. WRITE:/ BAPI_HEAD, BAPI_MARC1. call function 'BAPI_MATERIAL_SAVEDATA' exporting HEADDATA = BAPI_HEAD CLIENTDATA = BAPI_MARA1 CLIENTDATAX = BAPI_MARAX PLANTDATA = BAPI_MARC1 PLANTDATAX = BAPI_MARCX * FORECASTPARAMETERS = * FORECASTPARAMETERSX = * PLANNINGDATA = * PLANNINGDATAX = * STORAGELOCATIONDATA = * STORAGELOCATIONDATAX = VALUATIONDATA = BAPI_MBEW1 VALUATIONDATAX = BAPI_MBEWX * WAREHOUSENUMBERDATA = * WAREHOUSENUMBERDATAX = * SALESDATA = BAPI_MVKE1 * SALESDATAX = BAPI_MVKEX * STORAGETYPEDATA = * STORAGETYPEDATAX = IMPORTING RETURN = BAPI_RETURN TABLES MATERIALDESCRIPTION = INT_MAKT * UNITSOFMEASURE = * UNITSOFMEASUREX = * INTERNATIONALARTNOS = * MATERIALLONGTEXT = * TAXCLASSIFICATIONS = * RETURNMESSAGES = * PRTDATA = * PRTDATAX = * EXTENSIONIN = * EXTENSIONINX = . IF BAPI_RETURN-TYPE = 'E'. WRITE:/ 'Error Message ', BAPI_RETURN. ENDIF. ENDLOOP. ENDFORM. espero te ayude, saludos |
Gracia Temaljose.
Husos Horarios son GMT. La hora en este momento es 06:47:59. |
