Infotype 0009 - Bank Details
Dear colleagues,
I am a SAP consultant from Germany and I work for a company with many subsidiaries in different countries. So, we would like to rollout the Mexican subsidiary into SAP HR and I already did some basic configuration. I have some issues with the bank details in infotype 0009. I understand the CLAVE (or CLABE) system is used and contains the bank, branch, account and check number in one field. Does it mean that the bank key is not needed in IT9, because all information is contained in the CLABE number? I tried to deactivate the field for the bank key - but no way. Also tried to check the module pool and some customizing in transaction OY17 and V_500_B etc. without luck. No matter what I do the system still asks for the bank key. So how you did the setup for this Infotype? Or does your business put in bank key and bank account? Help is much appreciated. Thanks a lot! Armin |
Hi Armin
The bank code is used to determine the bank to be canceled from the employee, it is configured from FI and is used by us in the DTAKT character, now I understand that it is a mandatory field. Did you try to place it as not required in the configuration of the infotype dynpro? then you should validate if standard transactions like CDTA0 and FFOT do not use them. Now you do not indicate why you do not want to use it on the IT0009, if you have any additional information, you can write to me at . Regards, |
Husos Horarios son GMT. La hora en este momento es 22:57:31. |
