No muestra cabecero en ALV
Hola !!!! Modifique el programa para que muestre un cabecero en la saldia del ALV, pero abre la caja mas no despliega la info (titulos y campos) dentro de ella, que puedo revisar.
Muchas Garcias de antemano. Saludos AMAM |
Podrias pasarnos el codigo fuente para revisarlo ?
Cabecero en ALV reporte HR
Hola es este: * FELL6BK051310 14.11.2003 performance improvement with trimmings as * side effect * FELL6BK050334 30.10.2003 new comboboxes: current period / other period * 46C FELL9CK137604 23.06.2003 new version with period comparison, * archived data, programme log, various bugfixes. * 46C FELL9CK132959 28.04.2003 improved compatibility w process manager * 4.0C new development C.Frey: wage type reporter (successor of * wage type statement/distribution RPCLGA00/09 RPCLGV00/09 report hxxcwtr0 no standard page heading. include zzh99cwtr0_scr_def. include zzh99cwtr0_data_def. initialization. rp-set-name-format. perform initialise changing field_directory. at selection-screen on value-request for p_extemp. perform get_xlt_file changing p_extemp excel_template. at selection-screen on value-request for p_lvtemp. perform get_alv_variant changing alv_template p_lvtemp. at selection-screen on value-request for p_grtemp. perform get_alv_variant changing grid_template p_grtemp. at selection-screen. *983979 - UNNI To change the object selection string of old variants perform replace_objselstrg changing p_h_strg. perform selection_screen_input using field_directory pyty_cal pyid_cal pyid_ref yoc abkr_cal pcurperc pcurperr changing ypernodt ycompper p_h_strg abkr_ref begd_cal endd_cal abrp_cal abrj_cal bond_cal begd_ref endd_ref abrp_ref abrj_ref bond_ref pyty_ref begcalsh endcalsh begrefsh endrefsh alv_template p_lvtemp grid_template p_grtemp excel_template p_extemp. at selection-screen output. perform convert_old_variants changing ypernodt begd_cal endd_cal abkr_cal abrp_cal abrj_cal. perform selection_screen_output using ypernodt hide_oc yoc begcalsh begrefsh. start-of-selection. perform start_of_selection using ypernodt p_h_strg changing field_directory ycompper driver ip_beg ip_end fp_beg fp_end ip_beg_ref ip_end_ref fp_beg_ref fp_end_ref. get pernr. perform core_proc using ip_beg ip_end fp_beg fp_end pyty_cal pyid_cal bond_cal s_pyty_c[] ycompper arc_read false yoc ypernodt for_view. if ycompper eq true. perform core_proc using ip_beg_ref ip_end_ref fp_beg_ref fp_end_ref pyty_ref pyid_ref bond_ref s_pyty_c[] ycompper arc_read true yoc ypernodt for_view. perform filter_diffs in program (driver) using s_absnum[] s_absamo[] s_relnum[] s_relamo[]. endif. * if nullrecs eq false. * perform delete_null_fields in program (driver). * endif. end-of-selection. * Print report with sap script perform print_form tables pers_table. " Donde la llena if nullrecs eq false. perform delete_null_fields in program (driver). endif. perform end_of_selection using driver excel_template alv_template grid_template excel lv grid. include zzh99cwtr0_forms. include zzh99cwtr0_screen_2000. *---------------------------------------------------------------------* * PRINT THE INFORMATION OF THE REPORT * *---------------------------------------------------------------------* * --> P_FORM FORM TO PRINT * *---------------------------------------------------------------------* form print_form tables p_pers_table structure pers_table. * p_int_sen STRUCTURE int_sen * p_int_int STRUCTURE int_int * p_sal_int STRUCTURE sal_int. * * DATA: text_element_tab TYPE pvesc_text_element_tab, * current_text_element LIKE LINE OF text_element_tab, * subrc LIKE sy-subrc. * * CHECK sy-ucomm NE c_cancel. * ** sort p_int_int and p_int_sen results tables * SORT p_int_sen BY pers_code fecha trans_code. * SORT p_int_int BY pers_code fecha_int cntr1. sort p_pers_table by pers_code. " AA * Print the report. Loop at pers_table loop at p_pers_table. alv_out-pernr = p_pers_table-pers_code. alv_out-cname = p_pers_table-cname. alv_out-nombre = p_pers_table-nombre. * READ TABLE p_sal_int WITH KEY p_pers_table-pers_code. ** ** alv_out-begda = p_sal_int-fecha_ing. ** alv_out-anos = p_sal_int-anos. ** alv_out-amt01 = p_sal_int-monto_sal. ** alv_out-amt03 = p_sal_int-monto_prt. ** Print seniority table * PERFORM print_sen TABLES p_int_sen * USING p_pers_table-pers_code. * * alv_out-amt02 = saldo_without_adv_pay. * alv_out-amt04 = alv_out-amt03 - alv_out-amt02. * * IF alv_out-amt04 < 0. * alv_out-amt04 = 0. * ENDIF. append alv_out. endloop. perform print_alv. * * endform. " PRINT_FORM *&---------------------------------------------------------------------* *& Form PRINT_ALV *&---------------------------------------------------------------------* * text *----------------------------------------------------------------------* * --> p1 text * <-- p2 text *----------------------------------------------------------------------* form print_alv . * Carga de Campos para ALV perform init_fieldcat. * Atributos de ALV perform init_layout. * Ordenar ALV perform init_sort. * Carga de Eventos perform eventtab_build_01 changing gt_events. * Cabecera de ALV perform comment_build_01 using gt_list_top_of_page. * ALV perform mostrar_alv_01. endform. " PRINT_ALV *&---------------------------------------------------------------------* *& Form COMMENT_BUILD_01 *&---------------------------------------------------------------------* * text *----------------------------------------------------------------------* * -->P_GT_LIST_TOP_OF_PAGE text *----------------------------------------------------------------------* form comment_build_01 using lt_top_of_page type slis_t_listheader. data: ls_line type slis_listheader, datum_tx(10). refresh: lt_top_of_page. * Title * LIST HEADING LINE: TYPE H clear ls_line. ls_line-typ = 'H'. ls_line-info = 'Reporte INCE'. append ls_line to lt_top_of_page. write: 'hola'. clear ls_line. ls_line-typ = 'S'. write sy-uzeit to sy-uzeit using edit mask '__:__'. write sy-datum to datum_tx using edit mask '__/__/____'. concatenate 'Ejecutado el día: ' datum_tx ' A las: ' sy-uzeit into ls_line-info separated by space. append ls_line to lt_top_of_page. clear ls_line. ls_line-typ = 'S'. concatenate 'Ejecutado por : ' sy-uname into ls_line-info separated by space. append ls_line to lt_top_of_page. clear ls_line. ls_line-typ = 'S'. append ls_line to lt_top_of_page. endform. " COMMENT_BUILD_01 *&---------------------------------------------------------------------* *& Form EVENTTAB_BUILD_01 *&---------------------------------------------------------------------* * text *----------------------------------------------------------------------* * <--P_GT_EVENTS text *----------------------------------------------------------------------* form eventtab_build_01 changing pgt_events type slis_t_event. constants: gc_formname_top_of_page type slis_formname value 'TOP_OF_PAGE_01'. data: ls_event type slis_alv_event. call function 'REUSE_ALV_EVENTS_GET' exporting i_list_type = 0 importing et_events = pgt_events. read table pgt_events with key name = slis_ev_top_of_page into ls_event. if sy-subrc = 0. move gc_formname_top_of_page to ls_event-form. append ls_event to pgt_events. endif. endform. " EVENTTAB_BUILD_01 *&---------------------------------------------------------------------* *& Form INIT_FIELDCAT *&---------------------------------------------------------------------* * text *----------------------------------------------------------------------* * --> p1 text * <-- p2 text *----------------------------------------------------------------------* form init_fieldcat . refresh: gt_fieldcat. clear w_posi. * nombre del Programa g_repid = sy-repid. w_posi = w_posi + 1. gt_fieldcat-tabname = 'ALV_OUT'. gt_fieldcat-fieldname = 'PERNR'. gt_fieldcat-outputlen = 15. gt_fieldcat-reptext_ddic = 'Nro personal'. gt_fieldcat-seltext_l = 'Nro personal'. gt_fieldcat-ddictxt = 'L'. gt_fieldcat-col_pos = w_posi. append gt_fieldcat. clear gt_fieldcat. w_posi = w_posi + 1. gt_fieldcat-tabname = 'ALV_OUT'. gt_fieldcat-fieldname = 'CNAME'. gt_fieldcat-outputlen = 40. gt_fieldcat-reptext_ddic = 'Compañia'. gt_fieldcat-seltext_l = 'Compañia'. gt_fieldcat-ddictxt = 'L'. gt_fieldcat-col_pos = w_posi. append gt_fieldcat. clear gt_fieldcat. w_posi = w_posi + 1. gt_fieldcat-tabname = 'ALV_OUT'. gt_fieldcat-fieldname = 'NOMBRE'. gt_fieldcat-outputlen = 40. gt_fieldcat-reptext_ddic = 'Nombre'. gt_fieldcat-seltext_l = 'Nombre'. gt_fieldcat-ddictxt = 'L'. gt_fieldcat-col_pos = w_posi. append gt_fieldcat. clear gt_fieldcat. endform. " INIT_FIELDCAT *&---------------------------------------------------------------------* *& Form INIT_LAYOUT *&---------------------------------------------------------------------* * text *----------------------------------------------------------------------* * --> p1 text * <-- p2 text *----------------------------------------------------------------------* form init_layout . gs_layout-colwidth_optimize = 'X'. gs_layout-zebra = 'X'. gs_layout-no_input = ' '. endform. " INIT_LAYOUT *&---------------------------------------------------------------------* *& Form INIT_SORT *&---------------------------------------------------------------------* * text *----------------------------------------------------------------------* * --> p1 text * <-- p2 text *----------------------------------------------------------------------* form init_sort . refresh: gt_sort.clear gt_sort. clear w_posi. * Sortear por Código de Sociedad w_posi = w_posi + 1. gt_sort-spos = w_posi. gt_sort-tabname = 'ALV_OUT'. gt_sort-fieldname = 'PERNR'. append gt_sort. clear gt_sort. endform. " INIT_SORT *&---------------------------------------------------------------------* *& Form MOSTRAR_ALV_01 *&---------------------------------------------------------------------* * text *----------------------------------------------------------------------* * --> p1 text * <-- p2 text *----------------------------------------------------------------------* form mostrar_alv_01 . * Inicialización de Variante de Trabajo ls_vari-report = sy-repid. ls_vari-handle = space. ls_vari-log_group = space. ls_vari-username = space. ls_vari-variant = space. ls_vari-text = space. ls_vari-dependvars = space. call function 'REUSE_ALV_GRID_DISPLAY' exporting i_callback_program = g_repid is_layout = gs_layout it_fieldcat = gt_fieldcat[] it_sort = gt_sort[] it_excluding = gt_exclude[] is_variant = ls_vari it_events = gt_events[] tables t_outtab = alv_out exceptions program_error = 1 others = 2. if sy-subrc <> 0. message id sy-msgid type sy-msgty number sy-msgno with sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4. endif. endform. " MOSTRAR_ALV_01 |
Husos Horarios son GMT. La hora en este momento es 13:25:44. |
