Problema con disp+work.exe no corre esta parado (stop
Amigos expertos, gracias de antemano, soy nuevo con SAP y les solicito ayuda, tengo problemas con el disp+work detenido y este es el archivo dev_disp:
Adiciono la actualización del archivo: ------------------------------------------------ trc file: "dev_disp", trc level: 1, release: "721" --------------------------------------------------- sysno 00 sid PRB systemid 562 (PC with Windows NT) relno 7210 patchlevel 0 patchno 402 intno 20020600 make multithreaded, Unicode, 64 bit, optimized profile \\PruebaSapPRB\sapmnt\PRB\SYS\profile\PRB_DVEBMGS00_PruebaSapPRB pid 2852 kernel runs with dp version 139000(ext=121000) (@(#) DPLIB-INT-VERSION-139000-UC) length of sys_adm_ext is 592 bytes *** SWITCH TRC-HIDE on *** ***LOG Q00=> DpSapEnvInit, DPStart (00 2852) [dpxxdisp.c 1323] shared lib "dw_xml.dll" version 402 successfully loaded shared lib "dw_xtc.dll" version 402 successfully loaded shared lib "dw_stl.dll" version 402 successfully loaded shared lib "dw_gui.dll" version 402 successfully loaded shared lib "dw_mdm.dll" version 402 successfully loaded shared lib "dw_rndrt.dll" version 402 successfully loaded shared lib "dw_abp.dll" version 402 successfully loaded shared lib "dw_sym.dll" version 402 successfully loaded shared lib "dw_aci.dll" version 402 successfully loaded rdisp/softcancel_sequence : -> 0,5,-1 use internal message server connection to port 3901 rdisp/dynamic_wp_check : 1 rdisp/calculateLoadAverage : 1 Wed Feb 17 10:39:33 2016 *** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 5 seconds ***LOG GZZ=> 1 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 6525] MtxInit: 30000 0 0 DpSysAdmExtInit: ABAP is active DpSysAdmExtInit: VMC (JAVA VM in WP) is not active display_tcp_ip: 0 Set Check Logoff Flags to 0x0 DpIPCInit2: write dp-profile-values into sys_adm_ext DpIPCInit2: start server >PruebaSapPRB_PRB_00 < DpShMCreate: sizeof(wp_adm) 40608 (2256) DpShMCreate: sizeof(tm_adm) 5517056 (27448) DpShMCreate: sizeof(wp_ca_adm) 64000 (64) DpShMCreate: sizeof(appc_ca_adm) 64000 (64) DpCommTableSize: max/headSize/ftSize/tableSize=500/16/1392064/1392080 DpShMCreate: sizeof(comm_adm) 1392080 (2768) DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0 DpShMCreate: sizeof(slock_adm) 0 (296) DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0 DpShMCreate: sizeof(file_adm) 0 (80) DpShMCreate: sizeof(vmc_adm) 0 (2160) DpShMCreate: sizeof(wall_adm) (41664/42896/64/192) DpShMCreate: sizeof(gw_adm) 48 DpShMCreate: sizeof(j2ee_adm) 3952 DpShMCreate: SHM_DP_ADM_KEY (addr: 0000000000210050, size: 7180576) DpShMCreate: allocated sys_adm at 0000000000210060 DpShMCreate: allocated wp_adm_list at 00000000002130B0 DpShMCreate: allocated wp_adm at 00000000002132A0 DpShMCreate: allocated tm_adm_list at 000000000021D150 DpShMCreate: allocated tm_adm at 000000000021D1A0 DpShMCreate: allocated wp_ca_adm at 00000000007600B0 DpShMCreate: allocated appc_ca_adm at 000000000076FAC0 DpShMCreate: allocated comm_adm at 000000000077F4D0 DpShMCreate: system runs without slock table DpShMCreate: system runs without file table DpShMCreate: allocated vmc_adm_list at 00000000008D32B0 DpShMCreate: system runs without vmc_adm DpShMCreate: allocated gw_adm at 00000000008D3360 DpShMCreate: allocated j2ee_adm at 00000000008D33A0 DpShMCreate: allocated ca_info at 00000000008D4320 DpShMCreate: allocated wall_adm at 00000000008D43B0 DpCommAttachTable: attached comm table (header=000000000077F4D0/ft=000000000077F4E0) DpSysAdmIntInit: initialize sys_adm rdisp/test_roll : roll strategy is DP_NORMAL_ROLL dia token check not active (10 token) MBUF state OFF DpCommInitTable: init table for 500 entries DpRqQInit: keep protect_queue / slots_per_queue 0 / 2001 in sys_adm rdisp/queue_size_check_value : -> on,50,30,40,500,50,500,80 EmInit: MmSetImplementation( 2 ). MM global diagnostic options set: 0 <ES> client 0 initializing .... <ES> EsILock: use Mutex for locking <ES> InitFreeList <ES> block size is 4096 kByte. <ES> Info: em/initial_size_MB( 8115MB) not multiple of em/blocksize_KB( 4096KB) <ES> Info: em/initial_size_MB rounded up to 8116MB Using implementation view <EsNT> Using memory model view. <EsNT> Memory Reset disabled as NT default <ES> 2028 blocks reserved for free list. ES initialized. mm.dump: set maximum dump mem to 192 MB mm.dump: set global maximum dump mem to 192 MB EsRegisterEmCheck: Register EmGetEsHandles at 000007F6C03CB1E0 DpVmcSetActive: set vmc state DP_VMC_NOT_ACTIVE MPI: dynamic quotas disabled. MPI init: pipes=4000 buffers=1279 reserved=383 quota=10% rdisp/http_min_wait_dia_wp : 1 -> 1 ***LOG CPS=> DpLoopInit, ICU ( 4.0.1 4.0.1 5.1) [dpxxdisp.c 1709] ***LOG Q0K=> DpMsAttach, mscon ( PruebaSapPRB) [dpxxdisp.c 12944] MBUF state LOADING DpStartStopMsg: send start message (myname is >PruebaSapPRB_PRB_00 <) DpStartStopMsg: start msg sent to message server o.k. CCMS: Initialized monitoring segment of size 60000000. CCMS: Initialized CCMS Headers in the shared monitoring segment. Wed Feb 17 10:39:34 2016 CCMS: Checking Downtime Configuration of Monitoring Segment. CCMS: AlMsUpload called by wp 1024. CCMS: AlMsUpload successful for E:\usr\sap\PRB\DVEBMGS00\log\ALMTTREE.DAT (755 MTEs). CCMS: start to initalize 3.X shared alert area (first segment). DpMBufHwIdSet: set Hardware-ID ***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c 1296] MBUF state ACTIVE DpWpBlksLow: max wp blocks in queue is 800 (80 %) MBUF component UP DpMsgProcess: 1 server in MBUF DpAppcBlksLow: max appc blocks in queue is 500 (50 %) Wed Feb 17 10:41:13 2016 *** ERROR => DpHdlDeadWp: W4 (pid 3068) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W10 (pid 2496) died (severity=0, status=0) [dpxxwp.c 1746] Wed Feb 17 10:41:33 2016 *** ERROR => DpHdlDeadWp: W7 (pid 2400) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W9 (pid 948) died (severity=0, status=0) [dpxxwp.c 1746] Wed Feb 17 10:41:53 2016 *** ERROR => DpHdlDeadWp: W0 (pid 2324) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W1 (pid 2572) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W2 (pid 2712) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W3 (pid 2808) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W5 (pid 1228) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W6 (pid 1784) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W8 (pid 2192) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W11 (pid 1960) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W12 (pid 1624) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W13 (pid 1388) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W14 (pid 3024) died (severity=0, status=0) [dpxxwp.c 1746] *** ERROR => DpHdlDeadWp: W15 (pid 2688) died (severity=0, status=0) [dpxxwp.c 1746] *** DP_FATAL_ERROR => DpWPCheck: no more work processes *** DISPATCHER EMERGENCY SHUTDOWN *** increase tracelevel of WPs NiWait: sleep (10000ms) ... NiISelect: timeout 10000ms NiISelect: maximum fd=1021 NiISelect: read-mask is NULL NiISelect: write-mask is NULL Wed Feb 17 10:42:03 2016 NiISelect: TIMEOUT occured (10000ms) dump system status Workprocess Table (long) Wed Feb 17 15:12:03 2016 ======================== No Type Pid Status Cause Start Rstr Err Sem Time Program Cl User Action Table ------------------------------------------------------------------------------------------------------------------------------- 0 DIA -1 Ended no no 1 0 0 NO_ACTION 1 DIA -1 Ended no no 1 0 0 NO_ACTION 2 DIA -1 Ended no no 1 0 0 NO_ACTION 3 DIA -1 Ended no no 1 0 0 NO_ACTION 4 DIA -1 Ended no no 1 0 0 NO_ACTION 5 DIA -1 Ended no no 1 0 0 NO_ACTION 6 DIA -1 Ended no no 1 0 0 NO_ACTION 7 DIA -1 Ended no no 1 0 0 NO_ACTION 8 DIA -1 Ended no no 1 0 0 NO_ACTION 9 DIA -1 Ended no no 1 0 0 NO_ACTION 10 UPD -1 Ended no no 1 0 0 NO_ACTION 11 BTC -1 Ended no no 1 0 0 NO_ACTION 12 BTC -1 Ended no no 1 0 0 NO_ACTION 13 BTC -1 Ended no no 1 0 0 NO_ACTION 14 SPO -1 Ended no no 1 0 0 NO_ACTION 15 UP2 -1 Ended no no 1 0 0 NO_ACTION Dispatcher Queue Statistics Wed Feb 17 15:12:03 2016 =========================== +------+--------+--------+--------+------------+------------+ | Typ | now | high | max | writes | reads | +------+--------+--------+--------+------------+------------+ | NOWP | 0 | 2 | 2000 | 6 | 6 | +------+--------+--------+--------+------------+------------+ | DIA | 7 | 7 | 2000 | 7 | 0 | +------+--------+--------+--------+------------+------------+ | UPD | 0 | 0 | 2000 | 0 | 0 | +------+--------+--------+--------+------------+------------+ | ENQ | 0 | 0 | 2000 | 0 | 0 | +------+--------+--------+--------+------------+------------+ | BTC | 0 | 0 | 2000 | 0 | 0 | +------+--------+--------+--------+------------+------------+ | SPO | 1 | 1 | 2000 | 1 | 0 | +------+--------+--------+--------+------------+------------+ | UP2 | 0 | 0 | 2000 | 0 | 0 | +------+--------+--------+--------+------------+------------+ max_rq_id 13 wake_evt_udp_now 0 wake events total 11, udp 8 ( 72%), shm 3 ( 27%) since last update total 11, udp 8 ( 72%), shm 3 ( 27%) DpGetLoadAverage: la1[1] = 2.500000 / -1.000000 % DpGetLoadAverage: la5[1] = 0.800000 / -1.000000 % DpGetLoadAverage: la15[1] = 0.344444 / -1.000000 % Dispatcher Load Statistics +------+---------+---------+---------+ | Typ | LA1 | LA5 | LA15 | +------+---------+---------+---------+ | DIA | 2.500 | 0.800 | 0.344 | +------+---------+---------+---------+ DpGetLoadAverage: la1[2] = 0.000000 / -1.000000 % DpGetLoadAverage: la5[2] = 0.000000 / -1.000000 % DpGetLoadAverage: la15[2] = 0.000000 / -1.000000 % | UPD | 0.000 | 0.000 | 0.000 | +------+---------+---------+---------+ DpGetLoadAverage: la1[3] = 0.000000 / -1.000000 % DpGetLoadAverage: la5[3] = 0.000000 / -1.000000 % DpGetLoadAverage: la15[3] = 0.000000 / -1.000000 % | ENQ | 0.000 | 0.000 | 0.000 | +------+---------+---------+---------+ DpGetLoadAverage: la1[4] = 0.000000 / -1.000000 % DpGetLoadAverage: la5[4] = 0.000000 / -1.000000 % DpGetLoadAverage: la15[4] = 0.000000 / -1.000000 % | BTC | 0.000 | 0.000 | 0.000 | +------+---------+---------+---------+ DpGetLoadAverage: la1[5] = 0.500000 / -1.000000 % DpGetLoadAverage: la5[5] = 0.100000 / -1.000000 % DpGetLoadAverage: la15[5] = 0.044444 / -1.000000 % | SPO | 0.500 | 0.100 | 0.044 | +------+---------+---------+---------+ DpGetLoadAverage: la1[6] = 0.000000 / -1.000000 % DpGetLoadAverage: la5[6] = 0.000000 / -1.000000 % DpGetLoadAverage: la15[6] = 0.000000 / -1.000000 % | UP2 | 0.000 | 0.000 | 0.000 | +------+---------+---------+---------+ Dump of tm_adm structure: Wed Feb 17 15:12:03 2016 ========================= Term uid man user term lastop mod wp ta a/i (modes) Workprocess Comm. Area Blocks Wed Feb 17 15:12:03 2016 ============================= Slots: 1000, Used: 1, Max: 2 +------+--------------+----------+-------------+ | id | owner | pid | eyecatcher | +------+--------------+----------+-------------+ | 0 | DISPATCHER | -1 | 0xdeadbeef | NiWait: sleep (5000ms) ... NiISelect: timeout 5000ms NiISelect: maximum fd=1021 NiISelect: read-mask is NULL NiISelect: write-mask is NULL Wed Feb 17 10:42:08 2016 NiISelect: TIMEOUT occured (5000ms) DpHalt: shutdown server >PruebaSapPRB_PRB_00 < (normal) DpJ2eeDisableRestart DpMBufRead: read server list from MBUF (1 entries) DpMBufMod: name [PruebaSapPRB_PRB_00 ], types 187 state 3 (0x0 0x0 0x0 0x0) DpMBufMod: call hooks for event MBUF_DPEVT_DSTATE (5->3) AdGetSelfIdentRecord: > < AdCvtRecToExt: opcode 60 (AD_SELFIDENT), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 60 AdCallRegisteredCvtToExt: opcode 60 call 000007F6BFA2CC70 AdCallRegisteredCvtToExt: opcode 60 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K DpWpBlksLow: wp_blks_in_queue/threshold/max = 1/800/1000 DpLockWpBlkEx: lock wp ca_blk 1 make DISP owner of wp_ca_blk 1 DpRqIPutIntoQ: put elem in queue DIA, elems=8 DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 14) MBUF server state SHUTDOWN DpModState: change state STARTING -> SHUTDOWN NiBufSend starting Wed Feb 17 10:42:09 2016 NiIWrite: hdl 17 sent data (wrt=110,pac=1,MESG_IO) MsINiWrite: sent 110 bytes MsIModState: change state to SHUTDOWN DpModState: change server state from STARTING to SHUTDOWN DpHalt: switch off Shared memory profiling ShmProtect( 57, 3 ) ShmProtect(SHM_PROFILE, SHM_PROT_RW ShmProtect( 57, 1 ) ShmProtect(SHM_PROFILE, SHM_PROT_RD DpWakeUpWps: wake up all wp's DpHalt: stop work processes DpHalt: stop gateway killing process (1680) (SOFT_KILL) DpHalt: stop icman killing process (1944) (SOFT_KILL) DpHalt: terminate gui connections DpHalt: wait for end of work processes DpHalt: wait for end of gateway [DpProcDied] Process lives (PID:1680 HANDLE:836) DpHalt: waiting for termination of gateway ... NiWait: sleep (1000ms) ... NiISelect: timeout 1000ms NiISelect: maximum fd=1021 NiISelect: read-mask is NULL NiISelect: write-mask is NULL Wed Feb 17 10:42:10 2016 NiISelect: TIMEOUT occured (1000ms) *** ERROR => [DpProcDied] Process died (PID:1680 HANDLE:836 rc:0x0) [dpnttool2.c 147] DpHalt: wait for end of icman [DpProcDied] Process lives (PID:1944 HANDLE:860) DpHalt: waiting for termination of icman ... NiWait: sleep (1000ms) ... NiISelect: timeout 1000ms NiISelect: maximum fd=1021 NiISelect: read-mask is NULL NiISelect: write-mask is NULL Wed Feb 17 10:42:11 2016 NiISelect: TIMEOUT occured (1000ms) [DpProcDied] Process lives (PID:1944 HANDLE:860) DpHalt: waiting for termination of icman ... NiWait: sleep (1000ms) ... NiISelect: timeout 1000ms NiISelect: maximum fd=1021 NiISelect: read-mask is NULL NiISelect: write-mask is NULL Wed Feb 17 10:42:12 2016 NiISelect: TIMEOUT occured (1000ms) [DpProcDied] Process lives (PID:1944 HANDLE:860) DpHalt: waiting for termination of icman ... NiWait: sleep (1000ms) ... NiISelect: timeout 1000ms NiISelect: maximum fd=1021 NiISelect: read-mask is NULL NiISelect: write-mask is NULL Wed Feb 17 10:42:13 2016 NiISelect: TIMEOUT occured (1000ms) *** ERROR => [DpProcDied] Process died (PID:1944 HANDLE:860 rc:0x0) [dpnttool2.c 147] DpStartStopMsg: send stop message (myname is >PruebaSapPRB_PRB_00 <) DpStartStopMsg: Write AD_STARTSTOP message with type= 0, name=PruebaSapPRB_PRB_00 , sapsysnr= 0, hostname=PruebaSapPRB AdGetSelfIdentRecord: > < AdCvtRecToExt: opcode 60 (AD_SELFIDENT), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 60 AdCallRegisteredCvtToExt: opcode 60 call 000007F6BFA2CC70 AdCallRegisteredCvtToExt: opcode 60 exit rc=SAP_O_K AdCvtRecToExt: opcode 4 (AD_STARTSTOP), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 4 AdCallRegisteredCvtToExt: opcode 4 call 000007F6BFA4F6B0 AdCallRegisteredCvtToExt: opcode 4 exit rc=SAP_O_K DpConvertRequest: net size = 189 bytes NiBufIAlloc: malloc MSLIB-BUF, to 32110 bytes NiBufSend starting NiIWrite: hdl 17 sent data (wrt=562,pac=1,MESG_IO) MsINiWrite: sent 562 bytes MsISndTypeOnce: send msg (ms hdr/msg 110/452 bytes) to MSG_SERVER, type 1 DpStartStopMsg: stop msg sent to message server o.k. NiBufIAlloc: malloc MSLIB-BUF, to 32110 bytes NiBufIAlloc: malloc NIBUF-IN, to 32110 bytes NiIRead: hdl 17 received data (rcd=274,pac=1,MESG_IO) NiBufIIn: NIBUF len=274 NiBufIIn: packet complete for hdl 17 NiBufReceive starting MsINiRead: received 274 bytes MsIReceive: received msg (ms hdr/msg 110/164 bytes), flag 1, from MSG_SERVER , typ 0, key - DpHalt: received 164 bytes from message server NiIRead: hdl 17 recv would block (errno=EAGAIN) NiIRead: read for hdl 17 timed out (0ms) DpHalt: more messages from the message server DpHalt: send keepalive to synchronize with the message server NiBufSend starting NiIWrite: hdl 17 sent data (wrt=114,pac=1,MESG_IO) MsINiWrite: sent 114 bytes MsISnd2: send msg (ms hdr/msg 110/4 bytes) to name MSG_SERVER, type 0, key - MsSndName: MS_NOOP ok Send 4 bytes to MSG_SERVER NiBufIAlloc: malloc MSLIB-BUF, to 32110 bytes NiIRead: hdl 17 recv would block (errno=EAGAIN) NiIPeek: peek successful for hdl 17 (r) NiBufIAlloc: malloc NIBUF-IN, to 32110 bytes NiIRead: hdl 17 received data (rcd=114,pac=1,MESG_IO) NiBufIIn: NIBUF len=114 NiBufIIn: packet complete for hdl 17 NiBufReceive starting MsINiRead: received 114 bytes MsIReceive: received msg (ms hdr/msg 110/4 bytes), flag 3, from MSG_SERVER , typ 0, key - Received 4 bytes from MSG_SERVER Received opcode MS_NOOP from msg_server, reply MSOP_OK MsOpReceive: ok MsISendKeepalive : keepalive sent to message server NiIRead: hdl 17 recv would block (errno=EAGAIN) Wed Feb 17 10:42:14 2016 NiIPeek: peek for hdl 17 timed out (r; 1000ms) NiIRead: read for hdl 17 timed out (1000ms) DpHalt: no more messages from the message server DpHalt: sync with message server o.k. DpHalt: detach from message server ***LOG Q0M=> DpMsDetach, ms_detach () [dpxxdisp.c 13344] NiBufSend starting NiIWrite: hdl 17 sent data (wrt=110,pac=1,MESG_IO) MsINiWrite: sent 110 bytes MsIDetach: send logout to msg_server (PruebaSapPRB / 3901) MsIDetach: call exit function DpMsShutdownHook called NiBufISelUpdate: new MODE -- (r-) for hdl 17 in set0 SiSelNSet: set events of sock 872 to: --- NiBufISelRemove: remove hdl 17 from set0 SiSelNRemove: removed sock 872 (pos=2) SiSelNRemove: removed sock 872 NiSelIRemove: removed hdl 17 DpDelSocketInfo: del info for nihdl 17 (pos/type=2/4) MBUF state OFF AdGetSelfIdentRecord: > < AdCvtRecToExt: opcode 60 (AD_SELFIDENT), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 60 AdCallRegisteredCvtToExt: opcode 60 call 000007F6BFA2CC70 AdCallRegisteredCvtToExt: opcode 60 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0 AdCallRegisteredCvtToExt: opcode 40 AdCallRegisteredCvtToExt: opcode 40 call 000007F6C0063CB0 AdCallRegisteredCvtToExt: opcode 40 exit rc=SAP_O_K DpWpBlksLow: wp_blks_in_queue/threshold/max = 2/800/1000 DpLockWpBlkEx: lock wp ca_blk 2 make DISP owner of wp_ca_blk 2 DpRqIPutIntoQ: put elem in queue DIA, elems=9 DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 17) MBUF component DOWN NiICloseHandle: shutdown and close hdl 17/sock 872 NiBufIClose: clear extension for hdl 17 MsIDetach: detach MS-system (PruebaSapPRB / 3901) DpHalt: cleanup EM EsCleanup( ) EsCleanup .... EmCleanup() -> 0 Es2Cleanup: Cleanup ES2 ***LOG Q05=> DpHalt, DPStop ( 2852) [dpxxdisp.c 11819] DpHalt: Good Bye ..... |
Muéstranos el dev_w4 y el dev_w10 para ver que sucede.
Saludos, |
Husos Horarios son GMT. La hora en este momento es 19:22:16. |
