Error al instalar Sap IDES 6
Buen día, en estos momentos estoy tratando de instalar SAP ECC v6.0 SR3 IDES Oracle 10.2.0.2 el instalador de SAP Inst realiza el proceso de creación base de datos, tablas, pero en la comprobación del patch de Oracle se genera un erros, coloco a su disposición el log que se generó.
Agradezco su pronta colaboración. INFO 2016-02-02 05:09:37.234 Creating file C:\Program Files\sapinst_instdir\x. INFO 2016-02-02 05:09:37.234 Removing file C:\Program Files\sapinst_instdir\x. INFO 2016-02-02 05:09:56.015 Creating file C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP\x. INFO 2016-02-02 05:09:56.015 Removing file C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP\x. INFO 2016-02-02 05:09:59.781 Creating file C:\Program Files\sapinst_instdir\x. INFO 2016-02-02 05:09:59.781 Removing file C:\Program Files\sapinst_instdir\x. INFO 2016-02-02 05:10:02.218 Copied file 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.xml' to 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.27.xml'. INFO 2016-02-02 05:10:06.437 Copied file 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.xml' to 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.28.xml'. WARNING 2016-02-02 05:10:20.375 Unable to get information about path \\LABEL.ASC\ using GetVolumeInformation. Operating system error message: The filename, directory name, or volume label syntax is incorrect. INFO 2016-02-02 05:10:25.125 Copied file 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/inifile.xml' to 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/inifile.11.xml'. INFO 2016-02-02 05:10:25.546 Execute step Component W2K_ServicePack_Check|ind|ind|ind|ind Preprocess of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Step s|ind|ind|ind|ind|0|0|W2K_ServicePack_Check|ind|in d|ind|ind|2|0 INFO 2016-02-02 05:10:39.671 Copied file 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/keydb.xml' to 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/keydb.10.xml'. INFO 2016-02-02 05:10:39.843 Copied file 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.xml' to 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.29.xml'. INFO 2016-02-02 05:10:39.921 Execute step CheckOraclePatchInstalled of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Onehost_Sy stem|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|in d|ind|ind|10|0|NW_CreateDB|ind|ind|ind|ind|0|0|NW_ OraDBCheck|ind|ind|ind|ind|0|0|NW_OraDBMain|ind|in d|ind|ind|0|0|NW_OraDBStd|ind|ind|ind|ind|3|0|NW_O raPatch|ind|ind|ind|ind|10|0 INFO 2016-02-02 05:10:44.640 Removing file C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP\ora_query3_tmp0_1.sql. INFO 2016-02-02 05:10:44.656 Creating file C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP\ora_query3_tmp0_1.sql. INFO 2016-02-02 05:10:44.750 Switched to user: zapadm. INFO 2016-02-02 05:10:44.750 Working directory changed to C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP. INFO 2016-02-02 05:10:44.843 Switched to user: zapadm. INFO 2016-02-02 05:10:44.843 Working directory changed to C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP. INFO 2016-02-02 05:10:44.968 Switched to user: zapadm. INFO 2016-02-02 05:10:44.968 Working directory changed to C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP. ERROR 2016-02-02 05:10:45.125 CJS-00084 SQL statement or script failed. DIAGNOSIS: Error message: ORA-16032: parameter LOG_ARCHIVE_DEST destination string cannot be translated ORA-09291: sksachk: invalid device specified for archive destination OSD-04018: Unable to access the specified directory or device. O/S-Error: (OS 3) The system cannot find the path specified. Disconnected . SOLUTION: For more information, see ora_sql_results.log and the Oracle documentation. ERROR 2016-02-02 05:10:45.125 MUT-03025 Caught ESAPinstException in Modulecall: ORA-16032: parameter LOG_ARCHIVE_DEST destination string cannot be translated ORA-09291: sksachk: invalid device specified for archive destination OSD-04018: Unable to access the specified directory or device. O/S-Error: (OS 3) The system cannot find the path specified. Disconnected . ERROR 2016-02-02 05:10:45.125 FCO-00011 The step CheckOraclePatchInstalled with step key |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Onehost_Sy stem|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|in d|ind|ind|10|0|NW_CreateDB|ind|ind|ind|ind|0|0|NW_ OraDBCheck|ind|ind|ind|ind|0|0|NW_OraDBMain|ind|in d|ind|ind|0|0|NW_OraDBStd|ind|ind|ind|ind|3|0|NW_O raPatch|ind|ind|ind|ind|10|0|CheckOraclePatchInsta lled was executed with status ERROR ( Last error reported by the step :Caught ESAPinstException in Modulecall: ORA-16032: parameter LOG_ARCHIVE_DEST destination string cannot be translated ORA-09291: sksachk: invalid device specified for archive destination OSD-04018: Unable to access the specified directory or device. O/S-Error: (OS 3) The system cannot find the path specified. Disconnected .). INFO 2016-02-02 07:11:53.281 An error occured and the user decided to stop.\n Current step "|NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Onehost_S ystem|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|i nd|ind|ind|10|0|NW_CreateDB|ind|ind|ind|ind|0|0|NW _OraDBCheck|ind|ind|ind|ind|0|0|NW_OraDBMain|ind|i nd|ind|ind|0|0|NW_OraDBStd|ind|ind|ind|ind|3|0|NW_ OraPatch|ind|ind|ind|ind|10|0|CheckOraclePatchInst alled". INFO 2016-02-02 07:12:17.828 Creating file C:\Program Files\sapinst_instdir\.lastInstallationLocation. INFO 2016-02-02 07:12:18.000 Creating file C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP\__instana_tmp.xml. gracias. |
De dónde lo descargaste?
No estará mal el instalador? |
Husos Horarios son GMT. La hora en este momento es 15:59:33. |
