Dump con sentencia SUBMIT
Hola a todos, estoy teniendo este problema, se genera un dump en esta sentencia:
SUBMIT (p_name) VIA SELECTION-SCREEN AND RETURN. y lo unico "raro" de la misma, en todo caso, es el valor que llega ahi a p_name, que es '/1BCDWB/DBVBAK'. Esta correcto que sea asi ese literal? O el dump se debe a las / del contenido? Este es parte del dump: The current ABAP program "SAPLZBC004" had to be terminated because it has come across a statement that unfortunately cannot be executed. The following syntax error occurred in program "/1BCDWB/DBVBAK " in include "/1BCDWB/DBVBAK " in line 1090: "Campo "%_ENQU_VBAK" desconocido: No está incluido en una de las tablas" " indicadas ni definido mediante una sentencia "DATA" ." " " " " The include has been created and last changed by: Created by: "SAP* " Last changed by: "SAP* " Error in the ABAP Application Program The current ABAP program "SAPLZBC004" had to be terminated because it has come across a statement that unfortunately cannot be executed. .errores The following syntax error was found in the program /1BCDWB/DBVBAK : "Campo "%_ENQU_VBAK" desconocido: No está incluido en una de las tablas" " indicadas ni definido mediante una sentencia "DATA" ." " " " " |
Husos Horarios son GMT. La hora en este momento es 04:41:59. |
