Máximo de registros en una tabla interna
Hola, buenas tardes!.
Alguien sabe cual es el tope máximo de registros que puede almacenar una tabla interna? Creo que tiene que ver con algo de configuración de memoria por usuario, pero no estoy seguro. Saludos. |
No hay un limite como tal en el numero de registros de una tabla interna
Depende de la memoria RAM disponible y del parámetro OCCURS Los parámetros del sistema para determinar la memoria disponible en cada sesión: "o ztta/roll_area (1.000.000 - 15.000.000) Classic roll area per user and internal mode usual amount of roll area per user and internal mode o ztta/roll_extension (10.000.000 - 500.000.000) Amount of memory per user in extended memory (EM) o abap/heap_area_total (100.000.000 - 1.500.000.000) Amount of memory (malloc) for all users of an application server. If several background processes are running on one server, temporary bottlenecks may occur. Of course, the amount of memory (in bytes) must also be available on the machine (main memory or file system swap). Caution: The operating system must be set up so that there is also enough memory for each process. Usually, the maximum address space is too small. Ask your hardware manufacturer or your competence center about this. In this case, consult your hardware vendor abap/heap_area_dia: (10.000.000 - 1.000.000.000) Restriction of memory allocated to the heap with malloc for each dialog process. Parameters for background processes: abap/heap_area_nondia: (10.000.000 - 1.000.000.000) Restriction of memory allocated to the heap with malloc for each background process. Other memory-relevant parameters are: em/initial_size_MB: (35-1200) Extended memory area from which all users of an application server can satisfy their memory requirement. |
Muchas gracias por tu excelente y pronta respuesta Crounly.
Saludos!!. |
Husos Horarios son GMT. La hora en este momento es 22:10:01. |
