Status del IDOC
Hola muchachos... alguno de uds tiene documentación sobre la descripción de cada uno de los estados que puedo tomar los IDOCS al ser procesados???.. agradeceré cualquier tipo de información
Gracias Nos vemos |
te paso esta lista, espero y sea de tu ayuda...
Saludos Status Description. 0 Not used, only R/2 1 IDoc created 2 Error passing data to port 3 Data passed to port OK 4 Error within control information of EDI subsystem 5 Error during translation 6 Translation OK 7 Error during syntax check 8 Syntax check OK 9 Error during interchange handling 10 Interchange handling OK 11 Error during dispatch 12 Dispatch OK 13 Retransmission OK 14 Interchange Acknowledgement positive 15 Interchange Acknowledgement negative 16 Functional Acknowledgement positive 17 Functional Acknowledgement negative 18 Triggering EDI subsystem OK 19 Data transfer for test OK 20 Error triggering EDI subsystem 21 Error passing data for test 22 Dispatch OK, acknowledgement still due 23 Error during retransmission 24 Control information of EDI subsystem OK 25 Processing despite syntax error (outbound) 26 Error during syntax check of IDoc (outbound) 27 Error in dispatch level (ALE service) 28 Not used 29 Error in ALE service 30 IDoc ready for dispatch (ALE service) 31 Error - no further processing 32 IDoc was edited 33 Original of an IDoc which was edited 34 Error in control record of IDoc 35 IDoc reloaded from archive 36 Electronic signature not performed (timeout) 37 IDoc added incorrectly 38 IDoc archived 39 IDoc is in the receiving system (ALE service) 40 Application document not created in receiving system 41 Application document created in receiving system 42 IDoc was created by test transaction 50 IDoc added 51 Error: Application document not posted 52 Application document not fully posted 53 Application document posted 54 Error during formal application check 55 Formal application check OK 56 IDoc with errors added 57 Test IDoc: Error during application check 58 IDoc-Copy from an R/2 connection 59 Not used 60 Error during syntax check of IDoc (inbound) 61 Processing despite syntax error (inbound) 62 IDoc passed to application 63 Error passing IDoc to application 64 IDoc ready to be transferred to application 65 Error in ALE service 66 IDoc is waiting for predecessor IDoc (serialization) 67 Not used 68 Error - no further processing 69 IDoc was edited 70 Original of an IDoc which was edited 71 IDoc reloaded from archive 72 Not used, only R/2 73 IDoc archived 74 IDoc was created by test transaction |
Gracias, pero me refería si existía una descripción mas profundo de los estados.... alguien sabe??
Gracias |
Husos Horarios son GMT. La hora en este momento es 03:31:28. |
