Database startup failed
Buen día,
Alguien puede apoyarme, no puedo levantar sap, y no se mucho de basis ni soy dba este es el error que me marca Gracias !! Starting SAP-Collector Daemon ------------------------------ *********************************************************************** * This is Saposcol Version COLL 20.79 03/08/22 46D - V3.40 64Bit * Usage: saposcol -l: Start OS Collector * saposcol -k: Stop OS Collector * saposcol -d: OS Collector Dialog Mode * saposcol -s: OS Collector Status * The OS Collector is already running ..... ************************************************************************ saposcol already running Checking SAP R/3 ALU Database ------------------------------ Database is not available via /usr/sap/ALU/SYS/exe/run/R3trans -d -w Starting SAP R/3 ALU Database ------------------------------ Startup-Log is written to /oracle/ALU/startdb.log Database startup failed ! See /oracle/ALU/startdb.log for details ********************************************************* ********************************************************* Este archivo tiene el siguiente contenido: ********************************************************* ********************************************************* ------------------------------ Mon Oct 24 10:15:48 CDT 2011 LOGFILE FOR STARTING ORACLE ------------------------------ Mon Oct 24 10:15:48 CDT 2011 checking required environment variables ORACLE_HOME is >/oracle/ALU/817_32< ORACLE_SID is >ALU< ------------------------------ Mon Oct 24 10:15:48 CDT 2011 check initora ------------------------------ Mon Oct 24 10:15:48 CDT 2011 check initora ------------------------------ Mon Oct 24 10:15:48 CDT 2011 checking V2 connect TNS Ping Utility for Solaris: Version 8.1.7.4.0 - Production on 24-OCT-2011 10:1 5:48 (c) Copyright 1997 Oracle Corporation. All rights reserved. Attempting to contact (ADDRESS=(COMMUNITY=SAP.WORLD)(PROTOCOL=TCP)(HOST=alu890)( PORT=1527)) OK (10 msec) tnsping: V2 connect to ALU ------------------------------ Mon Oct 24 10:15:48 CDT 2011 Connect to the database to check the database state: R3trans: connect check finished with return code: 12 Database not available ------------------------------ Mon Oct 24 10:15:48 CDT 2011 Shutdown database First trying to shutdown the database - May be, the database is in the nomount or mount state ------------------------------ Mon Oct 24 10:15:48 CDT 2011 starting database Oracle Server Manager Release 3.1.7.0.0 - Production Copyright (c) 1997, 1999, Oracle Corporation. All Rights Reserved. Oracle8i Enterprise Edition Release 8.1.7.4.0 - Production With the Partitioning option JServer Release 8.1.7.4.0 - Production Connected. ORACLE instance started. Total System Global Area 294473888 bytes Fixed Size 73888 bytes Variable Size 133001216 bytes Database Buffers 161054720 bytes Redo Buffers 344064 bytes Database mounted. Database opened. Server Manager complete. ------------------------------ Mon Oct 24 10:15:57 CDT 2011 Connect to the database to verify, that the database is now open R3trans check finished with return code: 12 *** ERROR: Startup of database failed Notify Database Administrator. ------------------------------ Mon Oct 24 10:15:59 CDT 2011 /usr/sap/ALU/SYS/exe/run/startdb: Terminating with error code 2 |
nadie ? helpp, alguna idea ?
Husos Horarios son GMT. La hora en este momento es 12:25:24. |
