como crear una entrada de mercancias, usando BAPI_GOODSMVT_CREATE
Nose por donde empezar, se que tengo que crear una entrada de mercancías a través de la transaccion MB01, con mov. 101.
Puedo usar las BAPIS: BAPI_GOODSMVT_CREATE BAPI_TRANSACTION_COMMIT No tengo ni idea por donde empezar, necesito ayuda por favor. Gracias. |
Te tiro un codigo de ejemplo... tal vez te de una idea:
data:s_goodsmvt_header type BAPI2017_GM_HEAD_01, s_goodsmvt_code type BAPI2017_GM_CODE, * v_testrun LIKE BAPI2017_GM_GEN-TESTRUN, s_goodsmvt_headret type BAPI2017_GM_HEAD_RET, s_materialdocument type BAPI2017_GM_HEAD_RET-MAT_DOC, s_matdocumentyear type BAPI2017_GM_HEAD_RET-DOC_YEAR, i_goodsmvt_item type standard table of BAPI2017_GM_ITEM_CREATE with header line, i_goodsmvt_serialnumber type standard table of BAPI2017_GM_SERIALNUMBER with header line, i_return type standard table of bapiret2 with header line. * Cabecera S_GOODSMVT_HEADER-PSTNG_DATE = '20081226'. S_GOODSMVT_HEADER-DOC_DATE = '20081226'. S_GOODSMVT_HEADER-HEADER_TXT = 'Texto de cab'. S_GOODSMVT_CODE-GM_CODE = '04'. * Posicion I_GOODSMVT_ITEM-MATERIAL = 'TMGARNK06101VIR'. I_GOODSMVT_ITEM-PLANT = 'A000'. I_GOODSMVT_ITEM-BATCH = 'NUEVO'. I_GOODSMVT_ITEM-MOVE_TYPE = '309'. I_GOODSMVT_ITEM-SPEC_STOCK = 'W'. I_GOODSMVT_ITEM-CUSTOMER = '0000000542'. I_GOODSMVT_ITEM-ENTRY_QNT = 1. I_GOODSMVT_ITEM-MOVE_MAT = 'TMGARNK06101VIR'. I_GOODSMVT_ITEM-MOVE_PLANT = 'A000'. I_GOODSMVT_ITEM-MOVE_BATCH = 'NUEVO'. I_GOODSMVT_ITEM-MOVE_VAL_TYPE = 'NUEVO'. i_goodsmvt_item-SERIALNO_AUTO_NUMBERASSIGNMENT = 'X'. append I_GOODSMVT_ITEM. * Numero de serie I_GOODSMVT_SERIALNUMBER-MATDOC_ITM = 1. I_GOODSMVT_SERIALNUMBER-SERIALNO = '676867'. append I_GOODSMVT_SERIALNUMBER. CALL FUNCTION 'BAPI_GOODSMVT_CREATE' EXPORTING GOODSMVT_HEADER = S_GOODSMVT_HEADER GOODSMVT_CODE = S_GOODSMVT_CODE TESTRUN = ' ' IMPORTING GOODSMVT_HEADRET = S_GOODSMVT_HEADRET MATERIALDOCUMENT = S_MATERIALDOCUMENT MATDOCUMENTYEAR = S_MATDOCUMENTYEAR TABLES GOODSMVT_ITEM = I_GOODSMVT_ITEM GOODSMVT_SERIALNUMBER = I_GOODSMVT_SERIALNUMBER RETURN = I_RETURN . |
Husos Horarios son GMT. La hora en este momento es 07:07:03. |
