Creation through SmartForm file as .word
Hi all,
I am creating for transaction IW51 and IW52 differents forms to print them. And currently they are configurated with smartform, so the file obtained is .pdf, but as requirement of our customer, it has to be done in word. In order that some section and texts could be completed modify, deleted or include new lines, so the only possibility shoudl be that previously to create this document as pdf, it could be created as word to modify manually by user. It is possible with SAP??? Could anyone tell me any alternative. Thanks and regards. |
Hi Cristina.
Check the following link. The idea is send the smartforms to spool, get it with function "RSPO_RETURN_ABAP_SPOOLJOB" and after that send it to CLIPBOARD with function "CLPB_EXPORT" and paste the contains in a word document created with the help of ole2_object. |
Hello.
this way to export smartform to word format, operates correctly, but I've a problem with the format. How i can fix retaining the format? thanks in advanced |
Husos Horarios son GMT. La hora en este momento es 15:32:56. |
